Asus P4S8X-X Clock?
goede dag mensen.
Kheb dus een P4S8X-X mobo.En die staat nu op 2,61 ghz ( twas 2,4) })
Nu vraag ik mij af, hoe ken ik nu meer eruit slepen.
Multiplyer: 18x
xternal frequency: 142/36
oja en weet iemand hoe je een Dell 4100( |:( ) Intel D815EEA 800 mhz ken unlocken? Kan namelijk niks in de bios doen 8)7
Hartelijk dank alvast
SiSoftware Sandra
Processor(s)
Model : Intel(R) Pentium(R) 4 CPU 2.40GHz
Co-Processor (FPU) : Built-in
Speed : 2.61GHz
Performance Rating : PR2871 (estimated)
Type : Standard
Packaging : FC µPGA478
Rated Speed/FSB : 2400MHz / 4x 133MHz
Multiplier : 18x
Generation : 7th (7x86)
Model Information : P4N (Northwood) Pentium 4 1.6-3G 1.5-1.6V
Revision/Stepping : 2 / 7 (9)
Stepping Mask : C1
Microcode : MU0F2724
Core Voltage Rating : 1.525V
Processor Cache(s)
Internal Data Cache : 8kB synchronous write-thru (4-way sectored, 64 byte line size)
Internal Trace Cache : 12kµops synchronous write-thru (8-way, 64 byte line size)
L2 On-board Cache : 512kB ECC synchronous ATC (8-way sectored, 64 byte line size)
L2 Cache Multiplier : 1/1x (equiv. 2610MHz)
Host Interface(s)
Front Side Bus Speed : 4x 145MHz (580MHz data rate)
Upgradeability
Socket/Slot : PGA 478
Upgrade Interface : ZIF Socket
Supported Speed(s) : 3.20GHz (or more)
Features
FPU - Co-Processor Built-in : Yes
VME - Virtual Mode Extensions : Yes
DE - Debugging Extension : Yes
PSE - Page Size Extension : Yes
TSC - Time Stamp Counter : Yes
MSR - Model Specific Registers : Yes
PAE - Physical Address Extension : Yes
MCE - Machine Check Exception : Yes
CX8 - Compare & Exchange Instruction : Yes
APIC - Local APIC Built-in : Yes
CID - Context ID : No
SEP - Fast System Call : Yes
MTRR - Memory Type Range Registers : Yes
PGE - Page Global Enable : Yes
MCA - Machine Check Architecture : Yes
CMOV - Conditional Move Instruction : Yes
PAT - Page Attribute Table : Yes
PSE36 - 36-bit Page Size Extension : Yes
PSN - Unique Serial Number : No
CLF - Cache Line Flush Support : Yes
Unknown : No
DS - Debug Trace & EMON Store : Yes
ACPI - Software Clock Control : Yes
MMX Technology : Yes
FXSR - Fast Float Save & Restore : Yes
SSE Technology : Yes
SSE2 Technology : Yes
SS - Self Snoop : Yes
HTT - Hyper-Threading Technology : No
TM - Thermal Monitor : Yes
PBE - Pending Break Enable : Yes
IA-64 Technology : No
DAZ - Denormals Are Zero : Yes
Advanced Settings
Data Error Checking : No
Fast Strings : Yes
x86 FPU Compatibility Mode : No
Prefetch Queue : Yes
Branch Trace Storage : Yes
In Order Queue Depth : 12 req(s)
Thermal Monitor Enabled : Yes
Machine Check Architecture Settings
No. Reporting Banks : 4 bank(s)
Extended Machine Check Support : Yes
No. Extended Reporting Banks : 12 bank(s)
Variable Range MTRR Settings
MTRR 0 : 00000000-1FFFFFFF (0MB-512MB) WB
MTRR 1 : 20000000-2FFFFFFF (512MB-768MB) WB
MTRR 2 : E0000000-E7FFFFFF (3584MB-3712MB) WC
PAT Settings
PAT 0 : WB
PAT 1 : WC
PAT 2 : UC-
PAT 3 : UC
PAT 4 : WB
PAT 5 : WC
PAT 6 : UC-
PAT 7 : UC
Performance Tips
Tip 210 : Mainboard supports faster CPUs, so the CPU can be upgraded when needed.
Notice 224 : SMBIOS/DMI information may be inaccurate.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
  • jvvv
  • Laatst online: 25-10 14:19
voltage naar boven... en nogmaals, het is niet omdat je buurman meer oc dan met hetzelfde HW dat jij dat kan.
in het nederlands.
Je kan proberen je voltage (van cpu) naar boven te doen. En ik herhaal: Het is niet omdat de buurman met het zelfde mobo en cpu op een fsb van 151 kan dat jij dat kan.
[ Voor 48% gewijzigd door jvvv op 13-02-2003 22:27 ]
ff in het nederlands graag
enne wat bedoel je met buurman?
[ Voor 41% gewijzigd door Verwijderd op 13-02-2003 22:28 ]
Wat voor voltage raad je me aan?
Maar dit ding moet tog wel op de 2,8 te kunnen krijgen zijn?
[ Voor 64% gewijzigd door Verwijderd op 13-02-2003 22:43 ]
  • Sorcerer8472
  • Laatst online: 06:09
Sorcerer8472
Mens sana?
koelen en voltmodden...
Maar dat doe je NIET zonder dat je er verstand van hebt, want zo sloop je em dus redelijk makkelijk als je niet weet wat je doet :)
daarom hoopte ik dat het op een noob manier nog verder kon clocken.ALs jullie het mij simpel uitleggen
  • jvvv
lees even de faq. Daar wordt je wat wijzer van.
