eMule 0.26b Releashed
  • 60 views sinds 30-01-2008
En ja hoor, er is weer een nieuwe eMule. Het solved een groot aantal bugs en de layout is ook een beetje veranderd.
Als je nog met 0.24 aan het klooien bent stop dit dan nu en download hem hier:
http://prdownloads.source...6b-Installer.exe?download --> eMule 02.6b
Dit is de lijst van gefixte bugs sinds v.0.26a:
Ornis:Fixed Webservices in Searchview
Unk: Fixed secutity hole. (bluecow/zegzav)
Ornis:Fixed running preview [jicxicmic]
Unk: Few bug fixes. Stats now have a packet counter.
Ornis:little GUI fixes
Bug fixes, help from ZegZav, Bluecow, Ese Juani, jicxicmic
Optimizations, help from ichi, Maella, zz
Unk: Converted a lot of char[] to CStrings to help avoid buffer overruns.
Ozon: Changed packing alignment for most structs/classes (not the critical ones :), still 1 byte) to 8 bytes. (can improve preformance...)
Unk: If hashset is found to have problems, it now reasks for it.
Ozon: Added persistent backups of .part.met files
Ornis:added IP-ranges client-filtering (blacklist), using cDonkeys filter-file-format, basic filtering, more to come:)
Ornis:added own IP:Port to MyInfo-Window
Unk: Serverlist and Friendlist are now saved during runtime too
Ornis:Using list with columns for comments-dialog- looks better
Ozon: Backup of Clients.met is now done every time emule starts.
En dit zijn de bugs die verholpen zijn bij het updaten naar v.0.26a:
Ornis: fixed reset serverlog crash
Unk: Fixed security hole. (beef2k)
Unk: Created a new algorithm to smooth out the spikeing TCP connections. This will help several things..
-Spiking CPU & Bandwidth when many sources are added or reasked.
-Help with conflicts between Source Exchange and UDP file reasks allowing UDP to be used more lowering the need for TCP and overhead.
Unk: Irc: Fixed another bug that could cause a crash when you close a channel.
Unk: Queue size is now adjustable.. (FYI: Contrary to belief, queue size has NOTHING to do with the amount of bandwidth overhead..)
Unk: File buffer size is now adjustable. If you are one of them people that is having problems with the buffer, try lowering it.
Unk: Download file priorities are now usable for rechecking sources.
Unk: Some clients may be reporting completed file status. Did some changes to hopefully stop this.
Unk: Added queue rank of Hybrid eDonkey clients.
Unk: Fixed protocol to allow eMule to stay in the Hybrid's queue.
Unk: Changing IP shouldn't force you to move to the end of the queue anymore.
Unk: Redid sorting of Download list one more time.
Unk: Sources with a full queue is now treated the same as 'No Needed Parts'.. (means: they will be replaced by other sources when you reach source limit)
Unk: Fixed a bug that displayed eDonkey & eMule versions incorrectly.
Unk: We now detect eDonkey Hybrid Clients and Added Stats in Statistics.
Ornis: Filecompletion in seperate thread [Lord KiRon]
Ornis: added modified socket reading [by Jordy]
Ornis: support for Opcode 0x48 (OP_FILEREQANSNOFILE) of the protocol. [references: DoubleT,eMule+/Tarod]
Ornis: used videoplayer is now selectable
Unk: Did a complete rewrite with the Update functions in Queue and Upload list to speed things up.
Unk: Redid the Overhead meter. (I no longer try to estimate the TCP and UDP headers) Also added some Overhead statistics.
Ornis: optimized internal sources-handling, for reduced cpu-load
Ornis: various runtime optimization for reduced cpu-load (statstree, tray&maindlg, GUI) [coop. with EseJuani]
Ornis: Shared files list now supports more multiselect-commands
Ornis: versioncheck at startup (optional) or manually
Ornis: full customizable Web Services for files
Ozon: Fixed crash when trying to access statusbar before it was created (AddLogLine)
Unk: Added protcol to allow you to see what chunks a downloader has of the file. (both clients must use eMule 0.26 or higher)
Ornis: indicate files with ratings/comments by an icon in front of the filename (green/red,rating dependend)
Ornis: downloadlist: added sources-viewfiltering using modifier keys (see faq or help for usage!) [xrmb+Ese Juani]
Unk: IRC:Reconnect crash should be fixed.
Unk: Small change to downloadlist..
Unk: A client's server is now added with you first connect to him, Now, all client's servers you connect to are added to the server list.
Ornis: languages in selectionbox now labeled in local-language [pooz]
Ornis: fixed Toolbarbuttons always growing when changing languages [pooz]
Lijken me genoeg redenen >:)
  • KeeZ
  • Laatst online: 25-04-2022
KeeZ
Deze plek is te koop.
deze crasht bij mij tenminste niet na 7 uur lopen..... maar na 13 uur |:(
  • Zoefff
  • Laatst online: 17-06 08:32
Zoefff
Wat doet dit hier nu weer!?
Ten eerste is er een groot eMule topic, eMule opensource eDonkey, deel 4
Ten tweede is versie 0.26b al een paar dagen uit
Ten derde is er ook nog de meuktracker....
[ Voor 79% gewijzigd door Zoefff op 11-02-2003 11:46 ]
FotoblogWerkaandemuur.nlMoestuincursus.nlTwitter
  • blackd
Downloadlinks & release notes kunnen richting meuktracker, discussie kan in 't emule draadje eMule opensource eDonkey, deel 4 :)
9000Wp o/w SolarEdge SE6K - Panasonic 5kW bi-bloc - gasloos sinds 17-7-2023
