Acer al707 17" TFT
  • Robbeke
  • Laatst online: 29-12-2018
Ik zou graag wat ervaringen krijgen ivm dit tft schermpje...
kben al half uur aan het zoeken op google, alltheweb en vind enkel de technische aspecten... Heb de search op tweakers en neowin.net al geprobeert maar kon niets vinden. aub geen slotje :> , kvind echt niets... :(
Specs:
Resolutie: 1280x1024 >:)
Helderheid: 250cd/m2
Contrastverh: 500/1
Weergavehoek: 150°
Reactietijd: Tr20ms/20ms (wil dit dan zegge 20ms of 40ms?
prijs: 412€
http://www.tweakers.net/gallery/sys/2314
Afbeeldingslocatie: http://www.acer.be/vi/upload/E0Entity3/Acer_AL707_Normal.jpg
Display size 17", 338 X 270mm
Display Type TFT (thin film transistor) active matrix
Resolution 1280 X 1024
Brightness 250 cd/m2
Color 16.7M colors, RGB 8-bit data
Pixel pitch 0.264mm
Pixel clock 135MHz
Display Area (H x W ) 338 x 270 mm
Contrast Ratio 500:1(typ.)
Response rate 20ms
Horizontal frequency 31.5 ~ 80KHz
Vertical frequnecy 56.3 ~ 75Hz
Horizontal viewing angle 130°
Vertical viewing Angle 110°
Backlight 4 Lamps
Ambient illumination 300-500 Lux
Interface Analog RGB.
Input Connector 15-pin D-Sub,
Tilt base rotation Tilt-up 35 + 1° / down 5 + 1°
Wall-mount VESA wall-mount (no parts included)
Front Panel Controls Power On/Off, Select Up/ Down, Adjust Value +/ -,
User controls Contrast, Brightness, H-Position, V-Position, Pixel Adjust, Recall Defaults, Auto Adjust, Clock, 5 Languages, OSD Position, Information, YUV Adjustment,Color Balance
Dimension(H x W x D) 407 x 434 x 173 mm
Net Weight 5.8 kg
Power Saving VESA DPMS standard
Power Consumption AC 45W
Input signal H + .3 kHz, V + 1 Hz
AC Adaptor AC 100V - AC 240V
'Plug & Play' VESA DDC2B
Temperature ranges - operating 5° C to 40° C
Temperature ranges - non -operating -20° C to 60° C
Humidity - non & operating 20% to 90%
Compliance & Approvals ISO 13406-2, UL, EN60950, EN - 55022, MPR 1990, CSA, CB, TUV-GS, FCC-B, CE, TCO'99
2 min werk...
  • dreeke
  • Laatst online: 31-10-2025
dreeke
outdated icon
@ Karimo: Hij vraagt niet om de specs, maar om de ervaringen met dat ding.
Heb je www.kieskeurig.nl al geprobeerd?
Bij gebrek aan uw reclame staat hier mijn handtekening.
hij kon geen technische aspecten vinden
dus ik help em even
[ Voor 35% gewijzigd door Verwijderd op 10-02-2003 00:45 ]
  • Robbeke
jah die technische specificaties heb ik ook... alleen er zijn zovele TFTz en weet niet meer wat te kopen... kwil goed beeld en goeie kwaliteit...
op basis van specificaties lijkt het mij ok, maar ik zou graag bevestiging krijgen van iemand die er ervaring mee heeft, of iets in zelfde prijsklasse dat er uitsteekt... (al hebk zoiets nog niet echt gevonden)
  • Robbeke
*schop*
@ dreeke ik ben daar gaan kijken maar ACER staat er niet tussen.
anyone?
  • CyBeRSPiN
  • Laatst online: 12:15
CyBeRSPiN
sinds 2001
Hmm, keb ook wel interesse in die TFT, maar geen flauw idee of het wat is. Winkel heeft dat scherm niet op voorraad :(
De responsetijd, het contrast en de inkijkhoek zijn iig slechter dan de 712 en 722 (beide zo'n €100,- duurder), maar goed..
  • CyBeRSPiN
CyBeRSPiN
sinds 2001
Dat zijn dus de verkeerde specs :X
