[UT] zeroping mutator
  • 53 views sinds 30-01-2008
Met die mutator installed lijkt het idd.. of je ping 0 hebt als je schiet, maar hoe werkt dit tooltje iig.. hoe komt het dat net lijkt of je ping 0 hebt maar voor hetzelfde geld ping 120 hebt.
  • The Will
  • Registratie: Mei 2001
Op http://zeroping.home.att.net/readme.html is te lezen:
What is Zeroping?
Zeroping is a mutator that replaces Unreal Tournament's normal, server-side hit test code with client-side routines. Since Zeroping checks to see if your shot was a hit on your own computer, your weapons will fire instantly, and be much easier to aim. You'll still see a lag between your shot and your victim's death, but that won't affect your accuracy at all.
What Zeroping Does
Zeroping optimizes the primary fire modes of the following weapons:
Sniper Rifle
Shock Rifle
Instagib rifle
Enforcer
These weapons will fire the instant you press fire, no matter what your ping is, and they'll hit whatever is in your crosshairs. Zeroping makes these weapons as accurate as they are on a LAN.
What Zeroping Does Not Do
Zeroping does not:
Affect your movement.
Enhance rapid-fire weapons. A later version will.
Enhance projectile weapons like the rocket launcher. The idea behind Zeroping just doesn't apply to them.
Reduce your ping. Zeroping just makes your ping seem low.
Work with Last Man Standing. Instagib LMS works fine with Zeroping, though.
Voortaan zelf zoeken, dit was de eerste hit bij google, met als keywords: Unreal Tournament Zeroping mutator.
There is no magic.
