[XML] ruw xml wel, maar na parsen niet
  • Scharnout
  • Laatst online: 23-08 12:39
Een bestand zoals bv de turbotracker zie ik wel in mijn browser als xml , maar als ik die ga bewerken met hetvolgende:
<%@ Language=VBScript %>
option explicit
dim sXMLFilename
dim sXSLFilename
sXMLFilename = "http://www.tweakers.net/turbotracker.dsp"
sXSLFilename = "style.xsl"
TransformXMLtoHTML sXMLFilename, sXSLFilename
sub TransformXMLtoHTML(sXMLFilename, sXSLFilename)
  dim objXMLDoc
  dim objXSLDoc
  set objXMLDoc = Server.CreateObject("Microsoft.XMLDOM")
  objXMLDoc.async = false
  objXMLDoc.load(sXMLFilename)
  set objXSLDoc = Server.CreateObject("Microsoft.XMLDOM")
  objXSLDoc.async = false
  objXSLDoc.load(Server.MapPath(sXSLFilename))
  Response.Write(objXMLDoc.transformNode(objXSLDoc))
end sub
en
<?xml version="1.0" ?>
<xsl:stylesheet xmlns:xsl="http://www.w3.org/TR/WD-xsl">
  <xsl:template match="/">
  <HTML>
  <BODY alink="#000000" vlink="#000000" link="#000000" text="#000000">
 <TABLE width="100%" border="0" cellspacing="0" cellpadding="0">
    <TR>
    <TD width="150" bgcolor="black"><FONT size="2" face="Arial" color="white"><B>Titel</B></FONT></TD>
    <TD width="150" bgcolor="black"><FONT size="2" face="Arial" color="white"><B>Tijd</B></FONT></TD>
    <TD width="200" bgcolor="black"><FONT size="2" face="Arial" color="white"><B>Editor</B></FONT></TD>
    <TD width="200" bgcolor="black"><FONT size="2" face="Arial" color="white"><B>cat.</B></FONT></TD>
    </TR>
  <xsl:for-each select="TurboTracker/nieuwsposting">
    <TR>
    <TD><FONT size="2" face="Arial"><a><xsl:attribute name="HREF">http://www.tweakers.net/nieuws/<xsl:value-of select="id"/></xsl:attribute><xsl:value-of select="titel"/></a></FONT></TD>
    <TD><FONT size="2" face="Arial"><xsl:value-of select="tijd"/></FONT></TD>
    <TD><FONT size="2" face="Arial"><xsl:value-of select="editor"/></FONT></TD>
      <TD><FONT size="2" face="Arial"><xsl:value-of select="categorie"/></FONT></TD>
    </TR>
  </xsl:for-each>
  </TABLE>
  </BODY>
  </HTML>
  </xsl:template>
</xsl:stylesheet>
Krijg ik maar geen output in mijn browsers (Phoenix en IE5 en IE6.
Ik draai dit allemaal op een win2k Server-server binnen mijn netwerk. Te proberen op www.denssolutions.nl/tweakers.asp Of is er nog iets wat ik moet instaleren? Of doe ik iets fout.
[ Voor 52% gewijzigd door Scharnout op 09-02-2003 17:48 ]
And Bob's your uncle ...
Voeg "Call objXMLDoc.setProperty("ServerHTTPRequest", true)" toe voor je "objXMLDoc.load(sXMLFilename)" call en hij werkt wel :)
  • Scharnout
echt niet :)
ASP:
option explicit
dim objXMLDoc
objXMLDoc.load("http://www.tweakers.net/turbotracker.dsp")
Response.write "output=" & objXMLDoc.Text
Dit doet bij jou dus niets?
  • Scharnout
ja dat wel
Zie maar onder www.denssolutions.nl/tweakers2.asp
Ik ben echt he-le-maal clueless
  • akakiwi
  • Laatst online: 20-03 11:13
akakiwi
I believe in the ruling class.
Heb je MSXML4.exe op je bak geinstalleerd staan??
Dat programmaatje moet je even installeren om XML bestanden goed te laten parsen, anders snapt ie er geen hout van. ;)
Succes :)
| Life is a game (and games are fun) | homepage |
Scharnout schreef op 09 February 2003 @ 22:55:
ja dat wel
Hmmm, zet dan nog even een Response.write bladiebla.Text na het laden van de XML en XSL file in je echte asp pagina, dan weet je tenminste zeker dat beide goed geladen worden.
En voor de zekerheid als je mn eerste reactie niet goed begreep; Het volgende stuk code werkt dus bij jou echt niet:
ASP:
option explicit
dim sXMLFilename
dim sXSLFilename
  dim objXMLDoc
  dim objXSLDoc
  Response.write objXMLDoc.Text
end sub
  • Scharnout
Het bovenstaande script staat op www.denssolutions.nl/tweakers2.asp en werkt dus wel. MSXML4 is geinstalleerd op mijn webserverbak.
Scharnout schreef op 10 februari 2003 @ 10:12:
Ik weet niet of dit ook een reactie was op mij maar www.denssolutions.nl/tweakers2.asp is het eerste scriptje dat ik gaf; dat laatste script heb ik nog niet op je server gezien.
  • Scharnout
Eindelijk!
Mijn dank is onnoemelijk :)
Nu proberen of ik ook andere xml-bestanden kan benaderen ... en weer een weekend prutsen opgelost :)
