[deb.woody] DHCP-server wil niet werken
  • 97 views sinds 30-01-2008
  • jojo70
  • Laatst online: 13-05-2025
Ik krijg thuis een debain router niet werkend; alles werkt na mijn inzicht behalve de DHCP-server. Die geeft de volgende fout:
No subnet declaration for eth3 (213.93.9.60).
Please write a subnet declaration in your dhcpd.conf file for the
netwerking segment to which interface eth3 is attached.
Wat doe ik fout?
dhcpd.conf ziet er zo uitt:
# dhcpd.conf
# Sample configuration file for ISC dhcpd
# option definitions common to all supported networks...
#option domain-name "otherweb";
default-lease-time 6000;
max-lease-time 7200;
subnet 192.168.1.0 netmask 255.255.255.0 {
range 192.168.1.2 192.168.1.100;
option subnet-mask 255.255.255.0;
option broadcast-address 192.168.1.255;
option routers 192.168.1.1;
# option domain-name-servers 192.168.1.1;
subnet 192.168.2.0 netmask 255.255.255.0 {
range 192.168.2.2 192.168.2.100;
option broadcast-address 192.168.2.255;
option routers 192.168.2.1;
# option domain-name-servers 192.168.2.1;
subnet 192.168.3.0 netmask 255.255.255.0 {
range 192.168.3.2 192.168.3.100;
option broadcast-address 192.168.3.255;
option routers 192.168.3.1;
# option domain-name-servers 192.168.3.1;
Ifconfig ziet er zo uit waarbij eth3 de chello aansluiting naar buiten is.
eth0 Link encap:Ethernet HWaddr 00:10:A7:0C:66:08
inet addr:192.168.1.1 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1574 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:100
RX bytes:122251 (119.3 KiB) TX bytes:0 (0.0 b)
Interrupt:9 Base address:0xcc00
eth1 Link encap:Ethernet HWaddr 00:50:BF:1C:2D:97
inet addr:192.168.2.1 Bcast:192.168.2.255 Mask:255.255.255.0
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
Interrupt:9 Base address:0xe400
eth2 Link encap:Ethernet HWaddr 00:50:04:3C:8D:74
inet addr:192.168.3.1 Bcast:192.168.3.255 Mask:255.255.255.0
Interrupt:10 Base address:0x300
eth3 Link encap:Ethernet HWaddr 00:01:02:B2:79:38
inet addr:213.93.9.60 Bcast:255.255.255.255 Mask:255.255.255.192
RX packets:2165 errors:0 dropped:0 overruns:0 frame:0
TX packets:1748 errors:0 dropped:0 overruns:0 carrier:1
RX bytes:2899941 (2.7 MiB) TX bytes:129894 (126.8 KiB)
Interrupt:11 Base address:0xf880
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:8 errors:0 dropped:0 overruns:0 frame:0
TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:560 (560.0 b) TX bytes:560 (560.0 b)
Iemand ideeën?
otherweb // the other place on the web
  • blackd
Klinkt opzich erg logisch, aangezien je daar ook geen dhcpd hoeft te draaien lijkt me? :)
Anyway, start dhcpd zo op, dat hij alleen op eth0 t/m eth2 luistert. That should do it I guess.
9000Wp o/w SolarEdge SE6K - Panasonic 5kW bi-bloc - gasloos sinds 17-7-2023
  • jojo70
Hoe doe ik dat dan?
/etc/int.d/dhcp start ?
dhcpd --help en pas eventueel het opstartscript aan. Maar dit had je prima zelf kunnen vinden.
[rml]-=[ Nieuw in NOS? Eerst dit lezen! GEEN HELPDESK! ]=-[/rml]
