[ISP] Postfix + OpenLDAP + Courier + ISPman
  • Eastern
  • Laatst online: 01-10 09:34
Ik heb een SlackWare 8.1 Server met Postfix, Apache, MySQL, OpenLDAP, Courier en ISPMan.
Courier werkt goed, maar Postfix wil de mail niet in de courier boxen afleveren.
Feb 8 10:48:38 smuggler postfix/smtpd[385]: connect from pc-04.stations.eastern.local[192.168.2.188]
Feb 8 10:48:38 smuggler postfix/smtpd[385]: E0E2FD4078: client=pc-04.stations.eastern.local[192.168.2.188]
Feb 8 10:48:39 smuggler postfix/cleanup[386]: E0E2FD4078: message-id=<3E44D274.1050507@ok2web.nl>
Feb 8 10:48:39 smuggler postfix/qmgr[249]: E0E2FD4078: from=<erikvoost@ok2web.nl>, size=600, nrcpt=3 (queue active)
Feb 8 10:48:39 smuggler postfix/virtual[389]: E0E2FD4078: to=<erikvoost_ok2web_nl@smuggler.eastern.local>, orig_to=<erikvoost@ok2web.nl>, relay=virtual, delay=1, status=bounced (unknown user: "erikvoost_ok2web_nl@smuggler.eastern.local")
Feb 8 10:48:39 smuggler postfix/smtpd[385]: disconnect from pc-04.stations.eastern.local[192.168.2.188]
Ik heb op internet gezocht, maar kon niks vinden over deze combinatie. De overige services (Apache, FTP enzo ) werken wel goed.
Apache 1.3.27
Postfix 2.0.0.2
Courier 1.7.0
MySQL (irrelevant) 3.23.54
OpenLDAP 2.0.27 (2.1.12 werkt niet)
ISP Man 0.9.7
postfix main.cf (beetje lang, maar dan heb je vast wat info)
# if you are using this confing file, then you dont have to generate any map files.
# everything will be looked up dynamically from LDAP
# Too expensive for the ldap server
# Reasonable if you are replicating LDAP to this host and using it only for searching
queue_directory = /var/spool/postfix
program_directory = /usr/libexec/postfix
command_directory = /usr/sbin
daemon_directory = /usr/libexec/postfix
mail_owner = postfix
default_privs = nobody
myhostname = smuggler
mydomain = eastern.local
mynetworks = /etc/postfix/mynetworks
myorigin = $mydomain
inet_interfaces = all
alias_database = hash:/etc/postfix/aliases
alias_maps = hash:/etc/postfix/aliases, nis:mail.aliases
mydestination = $mydomain, $myhostname, localhost.$mydomain, /etc/postfix/destination, ldap:ldapdomain
relay_domains = $mydomain, $myhostname, localhost.$mydomain, /etc/postfix/destination, ldap:ldaprelaydomain
canonical_maps = hash:/etc/postfix/canonical, ldap:ldapcanonical
virtual_maps = hash:/etc/postfix/virtual, ldap:ldapvirtual
virtual_mailbox_base = /
default_transport = smtp
ldapdomain_server_host = localhost
ldapdomain_server_port = 389
ldapdomain_bind_dn = o=ispman
ldapdomain_search_base = o=ispman
ldapdomain_query_filter = (&(objectclass=ispmanDomain)(ispmanDomain=%s)(ispmanDomainService=mail))
ldapdomain_result_attribute = ispmanDomain
ldaprelaydomain_server_host = localhost
ldaprelaydomain_server_port = 389
ldaprelaydomain_bind_dn = o=ispman
ldaprelaydomain_search_base = o=ispman
ldaprelaydomain_query_filter = (&(objectclass=ispmanDomain)(ispmanDomain=%s))
ldaprelaydomain_result_attribute = ispmanDomain
ldapcanonical_server_host = localhost
ldapcanonical_bind_dn = o=ispman
ldapcanonical_search_base = o=ispman
ldapcanonical_query_filter = (&(objectclass=ispmanDomain)(ispmanDomainType=replica)(mailLocalAddress=%s))
ldapcanonical_result_attribute = mailForwardingAddress
ldapvirtual_server_host = localhost
ldapvirtual_server_port = 389
ldapvirtual_bind_dn = o=ispman
ldapvirtual_bind = no
ldapvirtual_timeout = 5
ldapvirtual_search_base = o=ispman
ldapvirtual_query_filter = (|(mailLocalAddress=%s)(mailAlias=%s))
ldapvirtual_result_attribute = mailRoutingAddress,mailForwardingAddress
ldapvirtual_lookup_wildcards = no
ldapmailbox_timeout = 10
ldapmailbox_server_host = localhost
ldapmailbox_search_base = o=ispman
ldapmailbox_server_port = 389
#ldapmailbox_domain = mycoll.edu, hash:/etc/postfix/searchdomains
ldapmailbox_query_filter = (|(mailLocalAddress=%s)(mailAlias=%s))
ldapmailbox_result_attribute = homeDirectory
ldapmailbox_bind = no
ldapmailbox_bind_dn = o=ispman
relocated_maps = hash:/etc/postfix/relocated
smtpd_sender_restrictions = hash:/etc/postfix/access
transport_maps = hash:/etc/postfix/transport
#mailbox_transport = cyrus
virtual_domains=/etc/postfix/virtual
smtpd_banner = $myhostname ESMTP $mail_name ($mail_version)
local_destination_concurrency_limit = 2
local_recipient_maps = ldap:ldapmailbox
virtual_mailbox_maps = ldap:ldapmailbox
local_transport = virtual
default_destination_concurrency_limit = 10
debug_peer_level = 2
debugger_command =
PATH=/usr/bin:/usr/X11R6/bin
  • Mark
  • Laatst online: 16:18
En hoe ziet je LDAP vulling eruit ?
hier stond onzin, sorry :X
[ Voor 94% gewijzigd door Verwijderd op 09-02-2003 20:38 ]
  • Mark
Verwijderd schreef op 08 February 2003 @ 17:37:
Ik heb hier ook postfix met courier draaien, maar zonder LDAP en MYSQL ondersteuning, dus opmerkingen hieronder zijn onder voorbehoud:
Heb je wel de mailboxen voor courier aangemaakt?
Nee, dit hoeft niet als je MySQL of LDAP gebruikt waarin je users zitten. De zaken die courier nodig heeft wanneer iemand de mail ophaalt (maildir path, usernaam en password) kan hij namelijk gewoon uit LDAP of MySQL halen.
  • Eastern
Het probleem is inmiddels bijna opgelost. De mail wordt nu in de home-Directory afgeleverd. Dat heb ik gedaan met de volgende config:
myhostname = smuggler.eastern.local
relay_domains = $mydomain, $myhostname, localhost.$mydomain, ldap:ldaprelaydomain
canonical_maps = ldap:ldapcanonical
virtual_uid_maps = ldap:ldapuid
virtual_gid_maps = ldap:ldapgid
home_mailbox = Maildir/
virtual_alias_domains=/etc/postfix/virtual
virtual_mailbox_domains = ldap:ldapdomain
# LDAP instellingen
ldapuid_timeout = 10
ldapuid_server_host = localhost
ldapuid_search_base = o=ispman
ldapuid_server_port = 389
#ldapuid_domain = mycoll.edu, hash:/etc/postfix/searchdomains
ldapuid_query_filter = (|(mailLocalAddress=%s)(mailAlias=%s))
ldapuid_result_attribute = uidNumber
ldapuid_bind = no
ldapuid_bind_dn = o=ispman
ldapgid_timeout = 10
ldapgid_server_host = localhost
ldapgid_search_base = o=ispman
ldapgid_server_port = 389
#ldapgid_domain = mycoll.edu, hash:/etc/postfix/searchdomains
ldapgid_query_filter = (|(mailLocalAddress=%s)(mailAlias=%s))
ldapgid_result_attribute = gidNumber
ldapgid_bind = no
ldapgid_bind_dn = o=ispman
debugger_command =
Nu moet hij echter achter de homeDirectory nog Maildir/ voegen om de mail in een appart mapje te krijgen. Is dat zonder moeilijkheden mogelijk? Of moet ik dan perse maildrop gaan gebruiken?
Je bedoelt dat je email wilt gaan filteren? Dan heb je inderdaad maildrop of procmail nodig. Over welke imap client hebben we het hier?
  • Eastern
het is courier.
Ik heb dit gevonden : virtual_maildir_suffix ; maar dat werkt (nog) niet.
Inmiddels heb ik het gevonden. Het staat hier: http://www.oav.net/~kiwi/postfix/
De patch heb ik gedownload en toegepast. Nu werkt het naar behoren.
de main.cf ziet er nu zo uit.
# i you are using this confing file, then you dont have to generate any map files.
# I use Courier IMAP compatibles files.
virtual_maildir_extended = yes
# Usefull for Courier IMAP..
virtual_maildir_suffix = Maildir/
# Generate maildirsize files or not
virtual_create_maildirsize = yes
# LDAP instellingen
ldapuid_bind = no
ldapgid_bind = no
debugger_command =
[ Voor 96% gewijzigd door Eastern op 10-02-2003 14:20 ]
