Handwriting recognition onder XP
  • SonyEricsson
  • Laatst online: 22:38
Hoi deze optie is dus om met je muis chinees/japans te kunnen schrijven onder windows XP
dit heb ik van de Windows techsite gehaald
To add handwriting recognition
Handwriting recognition is normally added automatically as a text service when it is installed. Use this procedure only if it you removed it as a text service and want to add it again.
Open Regional and Language Options in Control Panel.
On the Languages tab, under Text services and input languages, click Details.
Under Installed services, click Add.
In the Input language list, click a language.
Select the Handwriting recognition check box, and then click an option in the list.
Important
Handwriting recognition engines are language-specific. The first five Microsoft engines that are available are Simplified Chinese, Traditional Chinese, English, Japanese, and Korean. Engines for other languages will become available.
Notes
To open Regional and Language Options, click Start, click Control Panel, click Date, Time, Language, and Regional Options, and then click Regional and Language Options.
If a language does not appear in the Input language list, the fonts for that language might not be installed. For information about installing East Asian and complex script languages, click Related Topics.
Remove handwriting recognition if you are not using it, because it uses computer memory and can slow performance.
Click the Help button on the Language bar for more detailed information about using handwriting recognition.
het gaat vooral om dit stukje
Important
Ik heb dat gedaan ....
wil 1 van de ondersteunende talen installeren (chinees taiwan) maar ik zie helemaal geen HANDWRITING recognition checkbox
alleen welke keyboardlayout ik wil kiezen ..maar daar staat tie ook niet bij
(heb meerdere talen geprobeerd zonder resultaat)
kan misschien iemand met een engels winxp kijken of zij deze optie wel hebben?
want ik heb winxp dutch
misschien ligt het daar aan
  • FireWire
FireWire
I taste like chicken...
Uhh als ik het goed heb begrepen op de HCC schreeuwde die gast dat het alleen op een tabled pc mogelijk was oid..
Dus als ik het goed begreep was het alleen mogelijk om op een normale pc die reut te bekijken, je kan die addon overigens downloaden vanaf de Windows Update.
Suc6 verder en laat het even weten als ik iets stoms heb gezegt :)
\__________________________________Niet verwarren met IEEE 1394__________________________________/
  • SonyEricsson
FireWire schreef op 04 februari 2003 @ 10:55:
nee ..het is ook mogelijk zonder tablet
heb het zelf een keer gezien (met een muis) en ik heb alle updates al van het internet afgehaald , maar toch zit die optie er niet bij
Handwriting recognition zit niet in de Nederlandse versie van Windows XP.
