[deb.woody] xf86 config
hoi
op mijn laptop,een toshiba satellite 4030cds,heb ik debian woody draaien.
maar het probleem is dat er spookbeelden}), 3 zelfs,verschijnen "onder" xfree
dit hangt misschien samen met een of andere xfree config.
nu heb ik op internet iemand gevonden met weliswaar de zelfde laptop(4030cdt),maar dan de tft versie&z'n xfree config is van xfree 3.3.5
ik heb dstn ofzoiets.ik en mijn xfree config is op sommige punten anders .
heeft dit met TFT v.s DSTN(?)te maken , of kan ik die setting wel proberen.
/edit/ elke info over dit verschijnsel zou welkom zijn
/edit/
mijn xf86
# To change things within the debconf section, run the command:
# dpkg-reconfigure xserver-xfree86
# as root. Also see "How do I add custom sections to a dexconf-generated
# XF86Config or XF86Config-4 file?" in /usr/share/doc/xfree86-common/FAQ.gz.
Section "Files"
FontPath "unix/:7100" # local font server
# if the local font server has problems, we can fall back on these
FontPath "/usr/lib/X11/fonts/misc"
FontPath "/usr/lib/X11/fonts/cyrillic"
FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/Type1"
FontPath "/usr/lib/X11/fonts/Speedo"
FontPath "/usr/lib/X11/fonts/100dpi"
FontPath "/usr/lib/X11/fonts/75dpi"
EndSection
Section "Module"
Load "GLcore"
Load "bitmap"
Load "dbe"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "pex5"
Load "record"
Load "speedo"
Load "type1"
Load "vbe"
Load "xie"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "keyboard"
Option "CoreKeyboard"
Option "XkbRules" "xfree86"
Option "XkbModel" "pc104"
Option "XkbLayout" "us"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/psaux"
Option "Protocol" "PS/2"
Option "Emulate3Buttons" "true"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Generic Mouse"
Driver "mouse"
Option "SendCoreEvents" "true"
Option "Device" "/dev/input/mice"
Option "Protocol" "ImPS/2"
EndSection
Section "Device"
Identifier "Generic Video Card"
Driver "trident"
EndSection
Section "Monitor"
Identifier "Generic Monitor"
HorizSync 28-38
VertRefresh 43-72
Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Generic Video Card"
Monitor "Generic Monitor"
DefaultDepth 16
SubSection "Display"
Depth 1
Modes "800x600"
EndSubSection
Depth 4
Modes "800x600"
EndSubSection
Depth 8
Modes "800x600"
EndSubSection
Depth 15
Modes "800x600"
EndSubSection
Depth 16
Modes "800x600"
EndSubSection
Depth 24
Modes "800x600"
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
InputDevice "Generic Mouse"
EndSection
Section "DRI"
Mode 0666
EndSection
### END DEBCONF SECTION
xf86 3.3.5 tft laptop:
# File generated by XConfigurator.
# Provides correct-ish settings for Trident Cyber 9525 DVD, on a Toshiba
# 4030 CDT
# Matt Gumbley, matt@gumbley.demon.co.uk
# 18/03/99
# Modifications
# 01/10/99 MJG Now suitable for XFree86 3.3.5: uses accelerated mode;
# allows an external mouse to be connected after the system
# is booted (commented out for now). Removed cyber_shadow
# option.
# Refer to the XF86Config(4/5) man page for details about the format of
# this file.
# Files section. This allows default font and rgb paths to be set
Section "Files"
# The location of the RGB database. Note, this is the name of the
# file minus the extension (like ".txt" or ".db"). There is normally
# no need to change the default.
RgbPath "/usr/X11R6/lib/X11/rgb"
# Multiple FontPath entries are allowed (they are concatenated together)
FontPath "/usr/X11R6/lib/X11/fonts/misc:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi:unscaled"
FontPath "/usr/share/fonts/default/TrueType"
FontPath "/usr/share/fonts/default/URW"
FontPath "/usr/X11R6/lib/X11/fonts/Type1"
FontPath "/usr/X11R6/lib/X11/fonts/Speedo"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi"
EndSection
# Server flags section.
Section "ServerFlags"
# Uncomment this to cause a core dump at the spot where a signal is
# received. This may leave the console in an unusable state, but may
# provide a better stack trace in the core dump to aid in debugging
#NoTrapSignals
# Uncomment this to disable the <Crtl><Alt><BS> server abort sequence
# This allows clients to receive this key event.
#DontZap
# Uncomment this to disable the <Crtl><Alt><KP_+>/<KP_-> mode switching
# sequences. This allows clients to receive these key events.
#DontZoom
EndSection
# Input devices
# This section allows an external PS/2 mouse to be connected after the system
# has booted. It requires a restart of X (Ctrl-Alt-Backspace) and no more.
# It loses the "click both buttons to get middle button" emulation on middle
# mouse. If you add the Emulate commands to this section, the external mouse
# stops responding.
# Until someone sends me a working section for this, it's commented out.
#Section "XInput"
# Subsection "Mouse"
# Protocol "ps/2"
# Device "/dev/mouse"
# AlwaysCore # without this you won't get two simultaneous mice
# EndSubsection
#EndSection
# Jon Wikne sent this to the list - it's commented out, try it!
# >>> Start
# "The best I have found follows below. It works with the internal
# pointer and buttons, and an external, three-button mouse of the PS/2
# type. The external mouse can be removed and replugged after boot,
# restarting X (or starting a new X session) is sufficient to get
# it going. Requires "simultaneous" pointing device setting in the
# BIOS.
# NB! I have _never_, with any code that has been suggested on this
# list, been able to connect the mouse first time after boot. Maybe
# it is just my bad luck, others report having achieved this."
# Pointer section
# Section "Pointer"
# Protocol "ps/2"
# Emulate3Buttons is an option for 2-button Microsoft mice
# Emulate3Timeout is the timeout in milliseconds (default is 50ms)
# Works for the builtin pointer buttons of Toshiba Satellite 40xx
# Emulate3Buttons
# Emulate3Timeout 50
# EndSection
# >>> End of Jon Wikne's Pointer section
# Keyboard section
Section "Keyboard"
Protocol "Standard"
# when using XQUEUE, comment out the above line, and uncomment the
# following line
#Protocol "Xqueue"
AutoRepeat 500 5
# Let the server do the NumLock processing. This should only be
# required when using pre-R6 clients
#ServerNumLock
# Specify which keyboard LEDs can be user-controlled (eg, with xset(1))
#Xleds 1 2 3
#To set the LeftAlt to Meta, RightAlt key to ModeShift,
#RightCtl key to Compose, and ScrollLock key to ModeLock:
LeftAlt Meta
RightAlt Meta
ScrollLock Compose
RightCtl Control
# To disable the XKEYBOARD extension, uncomment XkbDisable.
# XkbDisable
# To customise the XKB settings to suit your keyboard, modify the
# lines below (which are the defaults). For example, for a non-U.S.
# keyboard, you will probably want to use:
# XkbModel "pc102"
# If you have a US Microsoft Natural keyboard, you can use:
# XkbModel "microsoft"
# Then to change the language, change the Layout setting.
# For example, a german layout can be obtained with:
# XkbLayout "de"
# or:
# XkbLayout "de"
# XkbVariant "nodeadkeys"
# If you'd like to switch the positions of your capslock and
# control keys, use:
# XkbOptions "ctrl:swapcaps"
# These are the default XKB settings for XFree86
# XkbRules "xfree86"
# XkbModel "pc101"
# XkbLayout "us"
# XkbVariant ""
# XkbOptions ""
XkbKeycodes "xfree86"
XkbTypes "default"
XkbCompat "default"
XkbSymbols "us(pc101)"
XkbGeometry "pc"
XkbRules "xfree86"
XkbModel "pc101"
XkbLayout "gb"
EndSection
# Pointer section
Section "Pointer"
Protocol "ps/2"
Device "/dev/mouse"
# When using XQUEUE, comment out the above two lines, and uncomment
# the following line.
# Protocol "Xqueue"
# Baudrate and SampleRate are only for some Logitech mice
# BaudRate 9600
# SampleRate 150
Emulate3Buttons
Emulate3Timeout 50
# ChordMiddle is an option for some 3-button Logitech mice
# ChordMiddle
EndSection
# Monitor section
# Any number of monitor sections may be present
Section "Monitor"
Identifier "LCD Panel 1024x768"
VendorName "Unknown"
ModelName "Unknown"
# HorizSync is in kHz unless units are specified.
# HorizSync may be a comma separated list of discrete values, or a
# comma separated list of ranges of values.
# NOTE: THE VALUES HERE ARE EXAMPLES ONLY. REFER TO YOUR MONITOR'S
# USER MANUAL FOR THE CORRECT NUMBERS.
# Matt's original settings - very strict.
HorizSync 31.5-53.7
VertRefresh 60
# Jon Wikne's settings, used for his new ModeLines
# NOTE: May not work on ALL 4030CDT's
# HorizSync 31.5-63.7
# VertRefresh 50-83
# VertRefresh is in Hz unless units are specified.
# VertRefresh may be a comma separated list of discrete values, or a
# 800x600 @ 60Hz, not quite perfect, as the display is shifted up-left
# a bit, and xvidtune wouldn't move it back. I don't use 800x600 anyway,
# so if you do, and you get it working perfectly, please let me know, and
# I'll change this...
Modeline "800x600" 39.79 800 840 968 1056 600 601 605 628
# Matt's original modeline for 1024x768. I hadn't tested this on a CRT.
# Works OK on TFT.
# 1024x768 @ 60Hz
Modeline "1024x768" 61.96 1024 1048 1208 1264 768 776 784 817
# Posted to the list by Jon Wikne. Thanks, Jon. Makes external CRT use much
# better.
# 1024x768 @ 76 Hz, 62.5 kHz hsync
# Modeline "1024x768" 85.00 1024 1032 1152 1360 768 784 787 823
EndSection
# Graphics device section
# Any number of graphics device sections may be present
Section "Device"
Identifier "Generic VGA"
BoardName "Unknown"
Chipset "generic"
# VideoRam 256
# Clocks 25.2 28.3
EndSection
# Device configured by Xconfigurator:
Section "Device"
Identifier "My Video Card"
BoardName "Unknown"
VideoRam 2048
Chipset "cyber9525"
# Insert Clocks lines here if appropriate
EndSection
# Screen sections
# The Colour SVGA server
Section "Screen"
Driver "svga"
# Use Device "Generic VGA" for Standard VGA 320x200x256
#Device "Generic VGA"
Device "My Video Card"
Monitor "LCD Panel 1024x768"
Subsection "Display"
Depth 8
# Omit the Modes line for the "Generic VGA" device
Modes "1024x768" "800x600"
ViewPort 0 0
# Use Virtual 320 200 for Generic VGA
Virtual 1024 768
EndSubsection
Depth 16
ViewPort 0 0
Virtual 1024 768
EndSubsection
Depth 32
ViewPort 0 0
Virtual 800 600
EndSubsection
EndSection
# The 16-color VGA server
Section "Screen"
Driver "vga16"
Modes "640x480" "800x600"
ViewPort 0 0
Virtual 800 600
EndSubsection
EndSection
# The Mono server
Section "Screen"
Driver "vga2"
ViewPort 0 0
Virtual 800 600
EndSubsection
EndSection
# The accelerated servers (S3, Mach32, Mach8, 8514, P9000, AGX, W32, Mach64
# I128, and S3V)
Section "Screen"
Driver "accel"
Depth 8
Modes "1024x768"
ViewPort 0 0
Virtual 1024 768
EndSubsection
Depth 16
Modes "1024x768"
ViewPort 0 0
Virtual 1024 768
EndSubsection
Depth 32
Modes "800x600"
ViewPort 0 0
Virtual 800 600
EndSubsection
EndSection
[ Voor 102% gewijzigd door Verwijderd op 31-01-2003 00:21 ]
wat voor 'spookbeelden'?
Idd. Misschien kun je een screenshot maken en/of het omschrijven.
Wat voor grafische kaart zit er in? Is de resolutie wel goed, werkt de muis ok?
Foutmeldingen uit /var/log/XFree86.?.log ?
die lijst was wel erg lang :D
hier een screenshot:
Afbeeldingslocatie: http://zenit.xs4all.nl/pics/lapshot2.jpg
in m'n log zie ik geen foutmeldingen.
/edit is dit duidelijk genoeg?/
[ Voor 13% gewijzigd door Verwijderd op 31-01-2003 11:28 ]
  • Blauw
  • Laatst online: 08-09 21:47
Blauw
De Schreeuw
Het is wel een beetje klein, maar bedoel je die drie schermpjes in het midden van het scherm? :?
* Blauw is een ontzettende n00b, maar misscien Xfree updaten naar versie 4.0.3 :?
ja, het zij een soort mini zwartwit cloontjes van de bovenkant van m'n scherm.
er valt mij trouwens iets op.als ik ksnapshot heb draaien valt het bijna weg.
heeft dit te maken met refreshrates ofzo .
(p.s. kan wel ff een iets groter plaatje droppen ?)
@Jozzz: dat andere figuur had het lopen onder xf 3.3.5,daarom d8 c.q. hoop ik dat dit ook gaat lukken.
[ Voor 18% gewijzigd door Verwijderd op 31-01-2003 11:56 ]
voor de liefhebbers hier een link naar een grotere screendump + /var/log output
http://zenit.xs4all.nl/pics/xf86_got.html
[ Voor 29% gewijzigd door Verwijderd op 31-01-2003 13:44 ]
Link gefixed. Titel verbeterd.
  • deadinspace
  • Laatst online: 09-09 13:51
deadinspace
The what goes where now?
[nohtml]
Verwijderd schreef op 30 January 2003 @ 23:45:
XFree86 3.x configuraties zijn niet compatible met 4.x configuraties, dus zomaar zijn config proberen gaat niet, of je moet al XFree 3.3.6 installeren.
Met TFT (Thin Film Transistor) vs DSTN (Double SuperTwisted Nematic) heeft het weinig te maken lijkt me, aangezien je er een screenshot van kunt maken. Screenshots komen uit het videogeheugen, en TFT vs DSTN heeft te maken met hoe het videogeheugen op het scherm gezet wordt.
Het lijkt me eerder een driver probleem.
Section "Device"
    Driver      "trident"
EndSection
Je zou eens kunnen proberen "trident" te vervangen door "vesa". Als je dan XFree herstart (of eerst probeert door als root een tweede XFree te starten dmv "X :1") en het is dan wel goed, dan ligt het dus aan de trident driver.
Merk wel op dat de vesa driver niet optimaal is; hij kan (aanmerkelijk) trager zijn, en dingen als Xvideo kun je vergeten.
Het was btw handiger geweest als je die configs binnen [ code ] tags geplaatst had, dat verhoogt de leesbaarheid nogal.
Jozzz schreef op 31 januari 2003 @ 11:31:
* deadinspace is een ontzettende n00b, maar misscien Xfree updaten naar versie 4.0.3 :?
Hij heeft al 4.1.0. Althans, dat is de versie die standaard bij Woody zit. Updaten naar 4.2.0 of 4.2.1 helpt misschien.
Verwijderd schreef op 31 januari 2003 @ 12:24:
Het plaatje werkt niet. Jouw browser kan misschien bij file://///SUN/website/html/pics/snapshot2.jpg, maar de mijne in ieder geval niet ;)
ik heb trident vervangen door vesa,en de spoken zijn verdwenen.driverprob dus.
het gekke is dat met de trident driver ik alleen maar ksnapshot hoef te starten en 99%
van de problemen zijn weg. is hier een of andere relatie te leggen :?
(btw de link naar het plaatje is gefixt)
  • _JGC_
  • Laatst online: 01:19
Ik zou XFree86 4.2.1 eens installeren. Voor Woody kan je die wel vinden op http://www.apt-get.org
uit mn hoofd:
deb http://www.fs.tum.de/~bunk/debian woody/bunk-1 main contrib non-free
Die gebruik ik voor al mn woody installaties, werkt allemaal perfect. Heb je ook direct OpenOffice 1.0.2 en Mozilla 1.2.1 als je die wilt (en die wil je, geloof me maar ;))
wel het probleem is opgelost,
ik heb eerst zoals ge apt upgrade naar xf 4.2.1-1.
dat ging prima,maar na de x restart was het erger dan voorheen.
wat wel hielp was het ophogen van de refresh rate .
p.s. _JGC_ kan je die apt link ff bevestigen,deze werkt niet maar lijkt wel handig.
p.s.2 voor toshiba linux users:http://linux.toshiba-dme.co.jp/linux/
heeft veel nuttige hardware&user info ,waar je op de toshiba website te
vergeefs naar zoekt |:(
