[RTCW] probleem met opstarten
  • 119 views sinds 30-01-2008
  • chaozz
  • Laatst online: 21-09 23:02
chaozz
Dreamers, they never learn
ik krijg deze error:
Wolf 1.0 win-x86 Nov 13 2001
----- FS_Startup -----
Current search path:
C:\PROGRA~1\RETURN~1\main\mp_pak2.pk3 (3 files)
C:\PROGRA~1\RETURN~1\main\mp_pak1.pk3 (308 files)
C:\PROGRA~1\RETURN~1\main\mp_pak0.pk3 (783 files)
C:\PROGRA~1\RETURN~1\main\pak0.pk3 (4775 files)
C:\PROGRA~1\RETURN~1/main
5869 files in pk3 files
execing default.cfg
couldn't exec language.cfg
couldn't exec wolfconfig_mp.cfg
execing autoexec.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found AMD w/ 3DNow!
Bypassing CD checks
----- Client Initialization -----
----- Initializing Renderer ----
Loaded 680 translation strings from scripts/translation.cfg
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\System32\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using desktop display depth of 32
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...GLW_ChoosePFD failed
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...using colorsbits of 16
...calling CDS: ok
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...35 PFDs found
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
ik draai xp pro. heb een geforce2 440mx 64mb en gebruik de nvidia detonator drivers.. iemand ideeen?
chaozz.nl
Euhm... Ten eerste: Games & Discussies --> problemen en vragen
Ten tweede: heb je mogelijkerwijs nog oude voodoo drivers op je computer staan? zo ja, alles verwijderen via zoeken van windows (glide2x, glide3x.dll, etc...)
Ook: zorg dat je z-buffer is ingesteld om alle drie modi (16,24,32) weer te geven.
Ook: wees zeker van je bureaublad instellingen (32 of 16 bit kleur, en waarin het spel opstart)
Er is een probleem met het pixelformat, dat is igg duidelijk.
Ook een paar keer meegemaakt.
RTCW opnieuw installen gaf bij mij een oplossing later bleek het een rotte partitie tabel. :(
Dus checkdisk en andere hd tools ff gebruiken.
  • M@NIC
  • Laatst online: 23-09 09:24
  • naiko
  • Laatst online: 10-10 18:48
heb dit ook gehad, nadat ik beta Directx 9 installed had, en dan weer naar 8.1 ging, gewoon ff alles van rtcw wegdoen, zelfs de dirs deleten, gewoon rtcw weer installen en alles liep weer perfect
PSN: nicovc
probeer eens je video drivers opnieuw te installeren had ik eerst ook met RTCW (kewl spel :) ) nu is het over.
  • The Will
  • Registratie: Mei 2001
  • Laatst online: 17:45
"iemand ideeen?"
Ja de search, geloof dat dit probleem 50% van alle topics in SPV is :{
There is no magic.
