Geen graphics-memory meer beschikbaar na installatie DX9.0
  • 48 views sinds 30-01-2008
  • langgelee2002
  • Laatst online: 27-06-2018
Hallo allemaal,
Aangezien ik net een topic heb gepost op rage3d over mijn probleem in het engels hier een copie van wat ik daar heb gepost. In het engels dus :]
After in installed DX9.0 on my winXP-pro/SP1 together with the latest Cat3.0 for my 8500 i found that there was no graphics memory available (in DXdiag and Powerstrip).
I roled back to DX8.1 with a little tool (DX9_Uninstall_Pak_WinXP) and reinstalled the Cat2.5 drivers. After i did this i found out that i still had no graphics memory available.
As i also have a backupdrive with a secondary winXP-pro/SP1 partition i decided to check this one out too. This partition was unchanged and had DX8.2/Cat2.5 installed just like my primary XP-boot had before i installed DX9.0.
I found that also on this XP-partition I had no graphics memory available anymore...
I started testing on my secondary bootdisk and found that there were no problems with the Cat2.3 driver-/controlpanel-set and those before Cat2.3.
Therefore i conclude that there is a problem with the smartgart utility, from which as far as i know, the 'final' versions are installed in the Cat2.4 set and above.
Conclusion: the problem is hardware-based. Which is very weird because i had no problems whatsoever before i installed DX9.0 on my primary XP-boot..
So, [I]DX9.0 screwed something up in my hardware[/I] , as far as i can conclude.
Did anyone have the same problem, and if yes what was it caused by, what did you to solve it.
Wie herkent dit, enig idee waar het probleem zit ?
Laat het me weten.
Tx
Promoter of no cheats and fair play
  • sdomburg
  • Laatst online: 03-09-2024
Dit is een Nederlands forum, vertaal dus eerst maar.
  • Buzzman
Juist ja.. wie don't spiek inglisj zegmaar :)
