[Win2K]: NT Legacy/APM device blijft fout geven
  • arnova
  • Laatst online: 09-09 09:11
arnova
weet veel, maar niet alles
Ik heb, vanwege problemen met IRQ's & ACPI, mijn Win2K veranderd van "Advanced Configuration And Power Interface (ACPI) PC" naar "Normal PC" (in de device manager. Dit werkt op zich goed, alleen had ik zoals zovelen problemen met het feit dat mijn computer niet automatisch meer wou afsluiten. Ik dacht de oplossing gevonden te hebben, na een search op het forum, en das was namelijk:
- Via Control Panel , Device Manager, View: ?Show hidden devices?, Disable "Microsoft ACPI?
en vervolgens:
- Via Control Panel, ?Add remove hardware?, ?Add new hardware?, ?NT APM/Legacy
support?.
Maar wat ik ook doe er blijft een uitroepteken (code 22) in de NT APM/Legacy device driver system (in de device manager).
Iemand enig idee wat ik kan proberen om dit op te lossen?
ESP PV-Boiler Controller https://github.com/arnova/pvboiler
Code 22 betekent:
Code 22
The text displayed for this error code differs depending on the circumstances.
If this device is disabled because you disabled it using Device Manager, the following text is displayed:
This device is disabled. (Code 22)
Click Enable Device to enable this device.
Solution button: Enable Device
If the device is not started, the following text is displayed:
This device is not started. (Code 22)
Click Start Device to start this device.
Solution button: Start Device
If the device is disabled by a driver or program, the following text is displayed:
You can't enable this device because it has been disabled by a Windows driver.
Solution button: None
This code means that the device is either disabled or has not started.
To resolve this error code, follow the recommended solution. For the third case, try removing the device in Device Manager, then redetecting it using the Add New Hardware wizard. If the problem persists, try a clean boot to rule out software interference. If the error persists, contact the hardware manufacturer.
Bron: Microsoft Knowledge Base Article - 125174 Explanation of Error Codes Generated by Device Manager
  • arnova
arnova
Ik heb het inmiddels zelfs met een clean-install geprobeerd maar ook dit lost het probleem niet op. Behalve dan dat ik nu code 31 krijg voor het NT APM/Legacy-device.
Is het mogelijk dat het systeem alleen powermanagement (APM) via APCI ondersteund? Iemand nog een andere suggestie's?
APM en APCI zijn 2 verschillende dingen. APCI is eigenlijk specifiek voor laptops om zuinig met de batterij om te gaan, door bijv. een HD uit te schakelen om stroom te besparen.
Zowel APM als APCI moeten door je bios ondersteund worden, hier zul je dus zelf even naar moeten kijken. Ik zou hem disabelen :)
