[ASP.net] Zoek de fout :)
  • 52 views sinds 30-01-2008
oke eerst ff de code:
Visual Basic .NET:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
<%@ Page Language="VB" Debug="True" %>
<%@ import Namespace="System.IO" %>
<%@ import Namespace="System.Data" %>
<%@ import Namespace="System.Data.OLEDB" %>
<%@ import Namespace="microsoft.visualbasic" %>
<%@ import Namespace="System.Drawing" %>
<script runat="server">
Sub UploadBtn_Click(Sender as Object, E as EventArgs)
Dim imgStream as Stream
Dim imgLen as Integer
Dim imgName_value as string
Dim imgContentType as String
Dim imgUploadedName as String
imgStream = UploadFile.PostedFile.InputStream
imgLen = UploadFile.PostedFile.ContentLength
imgUploadedName = UploadFile.PostedFile.FileName
Dim imgBinaryData(imgLen) as Byte
imgContentType = UploadFile.PostedFile.ContentType
imgName_value = imgName.Value
Try
If imgName_value.Length < 1 then
imgName_value = GetLastRightOf("\",imgUploadedName )
End if
Catch myEx as Exception
End Try
Dim n as Integer = imgStream.Read(imgBinaryData, 0, imgLen)
Dim NumRowsAffected as Integer = MyDatabaseMethod(imgName_value, imgBinaryData, imgContentType)
If NumRowsAffected > 0 then
Response.Write ( "<BR> Yeaaaahhhhhhhhh tis gelukt!!! " )
Else
Response.Write ( "<BR> Daammnn, mislukt " )
End if
End Sub
Function GetLastRightOf(LookFor as String, myString as String) as String
Dim StrPos as Integer
StrPos = myString.LastIndexOf(LookFor)
Return myString.SubString(StrPos + 1)
End Function
Function MyDatabaseMethod(imgName As String, imgbin As Byte(), imgcontenttype as String) As Integer
Dim strConnection As String = "Provider=Microsoft.Jet.OleDb.4.0;data source=" & server.mappath("\bin\games.mdb") & ";"
Dim connection As OleDbConnection = New OleDbConnection(strConnection)
Dim command as New OleDbCommand( "Insert into Screens (Image, contenttype, Beschrijving) Values ( @Image, @Contenttype, @Beschrijving )", connection )
command.Parameters.Add( "@Image", imgbin )
command.Parameters.Add( "@Beschrijving", imgName )
command.Parameters.Add( "@Contenttype", imgcontenttype )
connection.Open()
Dim numRowsAffected as Integer = command.ExecuteNonQuery()
connection.Close()
Return numRowsAffected
End Function
</script>
<html>
<head>
<title>Upload Images to a Database</title>
</head>
<body>
<form id="form1" name="form1" enctype="multipart/form-data" runat="server">
Den titel plz:
<input id="imgName" type="text" runat="server" />&nbsp;<br />
En welk bestandje?&nbsp;<input id="UploadFile" type="file" runat="server" />
<asp:button id="Button1" onclick="UploadBtn_Click" runat="server" Text="En me een beetje geluk.."></asp:button>
</form>
</body>
</html>
Den Error
Syntax error in INSERT INTO statement.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Data.OleDb.OleDbException: Syntax error in INSERT INTO statement.
Source Error:
Line 62:
Line 63: connection.Open()
Line 64: Dim numRowsAffected as Integer = command.ExecuteNonQuery()
Line 65: connection.Close()
Line 66:
En nu de vraag?
Er is iets mis met mijn INSERT commando maar ik vind het niet |:(
Het moet weer zoiets stoms zijn - zoals meestal!
Ik heb al een paar keer alles doorlopen en de code herschreven maar niets...
Wat moet ik veranderen het gaat dus over de Functie in mijn code!
[ Voor 10% gewijzigd door Verwijderd op 15-01-2003 21:19 ]
  • whoami
  • Laatst online: 11:02
Zoek de fout topics hebben we hier niet graag. ;)
Doe eens wat de error-melding zegt: review the stacktrace
Verder: doe ook eens aan wat debugging.
Maar: allereerst, lees ff de P&W Quickstart.
Post in het vervolg ook enkel de relevante code ipv bijna 100 regels code. Dit zorgt er alleen maar voor dat niemand uw topic leest.
Print je SQL string eens naar het scherm, bekijk hoe hij eruit ziet. Voor dat SQL commando zo eens in in de database, dus zonder je code etc....
Succes. ;)
https://fgheysels.github.io/
