Ik heb mplayer met gui geinstalleerd op Slackware 8.1
Via de command line werkt alles goed divx/mpg/xvid.
Maar als ik de gui start: gmplayer en dan een file selecteer om af te spelen krijg ik een Fatal error!:
Error opening/initializing the selected video_out (-vo) device!
Ik snap er helemaal niets van
Ik heb op GoT en Google niets gevonden wat mijn probleem op kan lossen.
En nog even de output als ik gmplayer via command line start:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
| bash-2.05a# gmplayer
Using GNU internationalization
Original domain: messages
Original dirname: /usr/share/locale
Current domain: mplayer
Current dirname: /usr/local/share/locale
MPlayer 0.90rc2-2.95.3 (C) 2000-2002 Arpad Gereoffy (see DOCS)
CPU: Advanced Micro Devices Athlon 4 PM Palomino/Athlon MP Multiprocessor/Athlon XP eXtreme Performance (Family: 6, Stepping: 2)
CPUflags: MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 1 SSE2: 0
Compiled for x86 CPU with extensions: MMX MMX2 3DNow 3DNowEx SSE
Reading config file /usr/local/etc/mplayer/mplayer.conf: No such file or directory
Reading config file /root/.mplayer/config
[cfg] read config file: /root/.mplayer/gui.conf
Reading config file /root/.mplayer/gui.conf
vo: X11 running at 1024x768 with depth 24 and 32 bpp (":0.0" => local display)
Reading /root/.mplayer/codecs.conf: can't open '/root/.mplayer/codecs.conf': No such file or directory
Reading /usr/local/etc/mplayer/codecs.conf: 49 audio & 125 video codecs
Font /usr/local/share/mplayer/font/font.desc loaded successfully! (233 chars)
Using Linux hardware RTC timing (1024Hz)
Can't open input config file /root/.mplayer/input.conf : No such file or directory
Can't open input config file /usr/local/etc/mplayer/input.conf : No such file or directory
Falling back on default (hardcoded) input config
SKIN dir 1: '/root/.mplayer/Skin'
SKIN dir 2: '/usr/local/share/mplayer/Skin'
Playing /mnt/hd/FTP/MOVIES/VCD/Jackass.The.Movie.SCREENER-TCF/CD1/tcf-cd1.mpg
Detected MPEG-PS file format!
VIDEO: MPEG1 352x240 (aspect 12) 23.98 fps 1437.5 kbps (179.7 kbyte/s)
Opening audio decoder: [mp3lib] MPEG layer-2, layer-3
MP3lib: init layer2&3 finished, tables done
AUDIO: 44100 Hz, 2 ch, 16 bit (0x10), ratio: 28000->176400 (224.0 kbit)
Selected audio codec: [mp3] afm:mp3lib (mp3lib MPEG layer-2, layer-3)
open: No such device
vo_mga: Couldn't open /dev/mga_vid
Error opening/initializing the selected video_out (-vo) device! |
[ Voor 76% gewijzigd door Verwijderd op 15-01-2003 17:35 ]
