Ppp probleem met FreeBSD 4.7
Ha,
Ik heb planet en een adsl speedtouch usb modem, nog zo'n oude. Nu valt internet na een tijdje uit en ik heb 't idee dat dit niet aan planet ligt maar aan ppp. Ik zal nu plakken wat ik me logs te zien krijg als internet uitvalt, ik kan d'r niet veel mee. (Ik heb mijn ip even veranderd naar xxx.xxx.xxx.xxx)
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
Jan 12 11:48:28 bsdfreak ppp[12876]: tun0:
Phase: Signal 15, terminate.
Jan 12 11:48:28 bsdfreak ppp[12876]: tun0: IPCP:
deflink: LayerDown: xxx.xxx.xxx.xxx
Using trigger address 0.0.0.0
deflink: SendTerminateReq(4) state = Opened
deflink: State change Opened --> Closing
Jan 12 11:48:31 bsdfreak ppp[12876]: tun0: IPCP:
deflink: SendTerminateReq(4) state = Closing
Jan 12 11:48:37 bsdfreak last message repeated 2 times
Jan 12 11:48:39 bsdfreak ppp[12876]: tun0:
Phase: deflink: read (0): Connection reset by peer
Jan 12 11:48:39 bsdfreak ppp[12876]: tun0: CCP:
deflink: State change Stopped --> Closed
deflink: State change Closed --> Initial
Jan 12 11:48:39 bsdfreak ppp[12876]: tun0: Phase:
deflink: open -> lcp
Jan 12 11:48:39 bsdfreak ppp[12876]: tun0: IPCP:
deflink: LayerFinish.
Connect time: 44857 secs: 120624079 octets in, 6602011 octets out
90704 packets in, 63112 packets out
total 2836 bytes/sec, peak 66242 bytes/sec on Sat Jan 11 23:34:22 2003
deflink: State change Closing --> Initial
Phase: bundle: Terminate
Phase: deflink: Disconnected!
Phase: deflink: lcp -> logout
Phase: deflink: logout -> hangup
Phase: deflink:
Connect time: 44857 secs: 120697730
octets in, 6928430 octets out
tun0: Phase: deflink: 92837 packets in, 65254 packets out
Phase:  total 2845 bytes/sec, peak 66772 bytes/sec on
tun0: Phase: deflink: HUPing 12878
tun0: Phase: deflink: hangup -> closed
tun0: Phase: bundle: Dead
tun0: Phase: PPP Terminated (normal).
En dan hier nog mijn /etc/ppp.conf
default:
 ident user-ppp VERSION (built COMPILATIONDATE)
 set log Phase Chat IPCP CCP tun command
adsl:
 set authname username@adsl-comfort
 set authkey password
 set device !"pppoa2 -vpi 8 -vci 48 -v 1"
 accept pap
 set speed sync
 set timeout 0
 enable lqr
 set lqrperiod 5
 #set redial 768 1024
 #set dial ""
 set ifaddr 10.0.0.1/0 10.0.0.2/0 255.255.255.0 0.0.0.0
 add default HISADDR
 enable dns
Google heeft mij ook niet veel te melden en man ppp ook niet. Ik denk gewoon bijna zeker dat dit aan ppp moet liggen en niet aan planet internet. Ik hoop genoeg informatie te hebben gegeven.
[ Voor 6% gewijzigd door Verwijderd op 12-01-2003 12:01 . Reden: Lay-out... ]
  • active2
  • Laatst online: 21:19
active2
Google is your friend
Jij zegt dat het USB is he ?
Kijk is naar logs met alle USB meldingen erin meestal wil USB ook nog weleens problemen geven en als je er kans toe ziet kijk dan of je een ethernet modem kunt krijgen da's een stuk beter en sneller.
Google, Het mirakel van de 21e eeuw!!!!
  • arikkert
  • Laatst online: 31-08 15:41
heb ik ook dat verbinding af en toe wegvalt bij mxstream mbv freebsd pptp.
ligt denk ik niet aan bsd en heb het zelf opgelost dmv een wrapper die de verbinding weer opzet als die weggevallen is.
arikkert schreef op 13 January 2003 @ 15:22:
Zou je dit kunnen uitleggen? Ik weet daar helemaal niets van! En, een ethernet is gewoon geen oplossing, betaal jij?
  • arikkert
deze processen draaien bij mij als mxstream verbinding er is :
bash-2.05a$ ps ax |grep pptp |grep adslmod
66642  ??  S     34:15.20 /usr/local/sbin/pptp adslmod adsl
66644  ??  S      0:05.64 /usr/local/sbin/pptp adslmod adsl
bash-2.05a$
en met dit is mijn wrapper scriptje:
bash-2.05a$ more mxstream_wrapper
# mxstream_wrapper
while true
do
        result=`ps ax | grep pptp | grep adslmod`
        if [ -z "$result" ]
        then
                /usr/local/etc/mxstream.sh
                echo "mxstream restarted at `date`" >> /var/log/mxstream_wrapper
.log
        fi
        sleep 60
done
bash-2.05a$
dit is een indicatie hoe vaak die door de wrapper automatisch ge-restart wordt (ook wel door recente computer reboots overigens)
bash-2.05a$ tail /var/log/mxstream_wrapper.log
mxstream restarted at Tue Jan  7 16:20:10 CET 2003
mxstream restarted at Tue Jan  7 16:23:55 CET 2003
mxstream restarted at Tue Jan  7 16:25:26 CET 2003
mxstream restarted at Tue Jan  7 16:38:59 CET 2003
mxstream restarted at Wed Jan  8 23:19:00 CET 2003
mxstream restarted at Wed Jan  8 23:20:30 CET 2003
mxstream restarted at Thu Jan  9 00:21:08 CET 2003
mxstream restarted at Thu Jan  9 00:22:38 CET 2003
mxstream restarted at Sat Jan 11 10:02:58 CET 2003
mxstream restarted at Sat Jan 11 20:01:18 CET 2003
bash-2.05a$
Wat ik me dus afvraag, of het mogelijk is om pppoa3 te gebruiken en pppd call adsl. Onder linux had ik tot voorheen geen problemen. En bij mij valt niet pppoa2 uit of, ppp -background adsl maar internet werkt gewoon niet meer:) En ik kan nog wel gewoon mijn ip pingen, maar geen externe ip's! Dit is dan meestal zo he :D
[ Voor 20% gewijzigd door Verwijderd op 13-01-2003 21:22 ]
Maar, heeft iemand een idee waarvoor ik wel mijn eigen ip kan pingen maar niet bijv. tweakers.net? Inet valt dan soort van uit, maar ik heb m'n ip nog:S
  • arikkert
geen idee waarom Internet bij jou uitvalt, maar wrapper oplossing is universeel he: restart progie als progie het niet meer doet en hopen dat die het dan weer wel doet.
freebsd 5.0 is 17 jan uit. Misschien nieuwe ronde nieuwe kansen :)
