Ik neem aan dat Pipo de Clown zich afvraagt of andere functies die met APM of ACPI te maken hebben wel werken.
Neem nou maar van mij (en Pip, en BlackD) aan dat dit het is. (Ik heb een Celeron 366 die ook al een ACPI BIOS had... alleen XP installeert (te) vaak de HAL voor een 'standard PC' (zal wel een veilige optie zijn).
Quote van de bovengenoemde site:
"(...) a shutdown problem because Win XP Setup doesn’t enable ACPI by default. SOLUTION: Manually enable ACPI during a Win XP install or reinstall. Correspondent Bill Anderson (based on a solution by “Willy”) gave a lengthy description of how to do this (edited a little bit for space reasons):
Boot the computer from the Win XP CD-ROM.
Win XP Setup says it’s checking hardware. Soon after, at the bottom of the screen, it offers the opportunity to press F5. (If offered the chance to press F6, press F5 instead! – Tip from Mick Stone) Do this at once, and cross your fingers! [Various users report difficulty with this. Apparently, sometimes it works; sometimes not. It may be in the timing of exactly when you press the key. You may have to try repeatedly, or try pressing F5 and F6 repeatedly. – JAE] When successful, you’ll see a two-paragraph instruction that begins, “To specify additional SCSI or other mass storage devices.” Press <ENTER> to brings up a small window that appears to contain only two options, but, in fact, contains more (use the arrow keys to scroll up). If this windows doesn’t appear at this point, you need to start over and do more pressing of F5!
When the small window does appear, use the up-arrow to choose “Advanced Configuration and Power Interface (ACPI).” (It’s the third from the top of the list.)
Next, you may see that two-paragraph SCSI/mass storage instruction again. If so, press <ENTER>. Many drivers will load, then you should see the Win XP installation screen. If you are running this after Win XP is already installed, choose the Repair option."
Deed voor mij de trick bij 3 computers die jouw probleem vertoonden.
Disclaimer: P. aanvaardt geen aansprakelijkheid op grond van dit bericht.
