Ik heb vrijdag een nieuwe dvd brander gehaald de philipsRW228. Alleen de cd die je erbij krijgt met de drivers en de software werkte niet. Eerst dacht ik van nou het ligt aan de cd en kreeg een nieuwe vandaag! Maar tot mijn verbazing kreeg ik de zelfde error. Maar bij philips op de cd zit een setup analyser en dan kan je zien wat er mis ging.
En dit is wat ik kreeg :
[IS ] ========================================================
[IS ] ====== Log started on Jan 7, 2003 at 18:59:13 ======
[IS ] Version (2.1.5)
[IS ph1] Write registry [SOFTWARE\Philips\CD-RW\SetupBusy] : 1
[IS ph1] Write registry [SOFTWARE\Philips\CD-RW\Flowcontrol\current]: 100
[IS ph1] File NeroWnaspi32.dll copied from C:\DOCUME~1\Michael\LOCALS~1\Temp\{FC1A2C73-5182-11D4-88D6-00C04F82136B}\ to C:\DOCUME~1\Michael
[IS ph1] \LOCALS~1\Temp\
[IS ph1] File dfw.dll copied from C:\DOCUME~1\Michael\LOCALS~1\Temp\{FC1A2C73-5182-11D4-88D6-00C04F82136B}\ to C:\WINDOWS\System32\
[IS ph1] File Info <dfw.dll>
[IS ph1] Location : C:\WINDOWS\System32\
[IS ph1] Version : 2.1.5.0
[IS ph1] Date/Time: 2002\08\21; 18:8:6
[IS ph1] Attrib : Normal
[IS ph1] Size : 208 KB (212992 bytes)
[DfwInt ] Init dll actions called.
[DfwInt ] *** Diagnose Frame Work version (2.1.5) ***
[DfwInt ] Operating System: Windows XP Service Pack 1, Build 2600
[DfwInt ] Nero <WNASPI32.DLL> Library loaded v(2.0.1.45).
[DfwInt ] [Init : Device info]
[DfwInt ] Number of Host Adapters found via ASPI = 4
[DfwInt ] Devices Found:
[DfwInt ] Host adapter <0> maxSCSItargets <8>
[DfwInt ] Host adapter <0> id <PrecSim>
[DfwInt ] Dev0: G: Image Simulation 1.0g (dev type: 5, Adapter type: SCSI)
[DfwInt ] Host adapter <1> maxSCSItargets <8>
[DfwInt ] Host adapter <1> id <atapi>
[DfwInt ] Dev1: C: MAXTOR 4K040H2 A08. (HA id: 1, target id: 0, dev type: 0, Adapter type: IDE, Dma: 3)
[DfwInt ] Dev2: D: WDC WD600BB-00CAA1 17.0 (HA id: 1, target id: 1, dev type: 0, Adapter type: IDE, Dma: 3)
[DfwInt ] Host adapter <2> maxSCSItargets <8>
[DfwInt ] Host adapter <2> id <atapi>
[DfwInt ] Dev3: E: PLEXTOR CD-R PX-W2410A1.04 (HA id: 2, target id: 0, dev type: 5, Adapter type: IDE, Autorun: 1, Dma: 3)
[DfwInt ] Dev4: F: PHILIPS DVDRW228 1.38 (HA id: 2, target id: 1, dev type: 5, Adapter type: IDE, Autorun: 1, Dma: 3)
[DfwInt ] Host adapter <3> maxSCSItargets <8>
[DfwInt ] Host adapter <3> id <>
[DfwInt ] Error - Device(3,0) SCSICommand <SCSI_INQUIRY> : 4 (SCSI/ATAPI request completed with error).
[DfwInt ] Error - DLL initialization failed.
[DfwInt ] [Applications currently running - START]
[DfwInt ] [Applications currently running - END]
[DfwInt ] Init dll actions completed.
[IS ph1] File dfw.dll loaded into memory
[IS ph1] Wizard set to the foreground
[IS ph1] Selected language for setup : Dutch
[DfwInt ] Function <DLL_CheckStatus> called.
[DfwInt ] Function <DLL_CheckStatus> completed.
[IS ph1] Error : Dfw dll is not properly initialised
[IS ph1] Warning : Setup will exit
[IS ph1] Write registry [SOFTWARE\Philips\CD-RW\SetupBusy] : 0
[DfwInt ] Exit dll actions called.
[DfwInt ] Nero <WNASPI32.DLL> Library removed from memory.
[DfwInt ] Exit dll actions completed.
[IS ph1] Loaded DLL "C:\WINDOWS\System32\dfw.dll" removed from memory
====== Log ended on Jan 7, 2003 at 18:59:16 ======
Ik zie dat het iets te maken heeft met de dwf.dll maar ik zou niet weten wat ik hiermee aan moet.
Weet iemand misschien hoe ik dit probleem kan oplossen?? Want hier word ik helemaal knetter van
Instagram | Flickr | Nikon D500 -> Sigma Art 18-35MM F/1.8 | NIKKOR AF-S 50MM F/1.8G | TAMRON 70-200MM G2 F2.8 | TAMRON 150-600MM G2 F/5-6.3
