Van de windows 2000 help(het gaat om het vergedrukte stukje, en niet om hibernation)
To automatically put your computer into hibernation
Open Power Options in Control Panel.
Click the Hibernate tab, select the Enable hibernate support check box, and then click Apply.
If the Hibernate tab is unavailable, your computer does not support this feature.
Click the APM tab, click Enable Advanced Power Management support, and then click Apply.
The APM tab is unavailable on ACPI-compliant computers. ACPI automatically enables Advanced Power Management, which disables the APM tab.
Click the Power Schemes tab, and then select a time in System hibernates.
Notes
You must be logged on as an administrator or a member of the Administrators group in order to complete this procedure. If your computer is connected to a network, network policy settings may also prevent you from completing this procedure.
To open a Control Panel item, click Start, point to Settings, click Control Panel, and then double-click the appropriate icon.
Your computer hibernates after it has been idle for the time period specified in System hibernates.
When you put your computer into hibernation, everything in computer memory is saved on your hard disk, and your computer is switched off. When you turn the computer back on, all programs and documents that were open when you turned the computer off are restored on the desktop.
To put your computer into hibernation, you must have a computer that is set up by the manufacturer to support this option.
Using Power Options in Control Panel, you can adjust any power management option that your computer's hardware configuration supports. Because these options may vary widely from computer to computer, the options described may differ from those available on your computer. Power Options automatically detects what is available on your computer and shows you only the options that you can control.
Gevonden via start>help>search
Intikken APM, vervolgens 1ste antwoord
Voor 3% gewijzigd door
MWP op 04-01-2003 18:25
