Athlon XP Mods for Fsb of 166Mhz and 220MHz
  • 63 views sinds 30-01-2008
  • ocbar
http://www.m3dzone.com/mo...ews&file=article&sid=1449
Hardware: AMD Athlon XP Mods for Fsb of 166Mhz and 220MHz
Posted on Tuesday, December 31 @ 13:14:23 CET by sensemann
Modifying A 133 Fsb T-bred B Into 166 Fsb
We mentioned earlier that there differences between Barton and TBred-B in terms of their L12 bridges. The difference can also be seen with the Athlon XP 2700+ and 2800+, which share a 166MHz FSB. Would it be possible to go straight to a 166MHz FSB by changing the L12 bridges? We decided to test this with a TBred-B Athlon XP 2200+....
To reconnect the two severed L12 bridges, we will use the same method used to unlock the multiplier. Apply correction fluid to the gap in the second bridge from the right (the bridge we will attempt to connect), then tape the adjacent bridges to prevent short-circuiting. Then connect the bridges using a conductive silver pen. PC booted and the BIOS quite clearly shows a 166MHz FSB. A simple L12 connection to unlock 166MHz FSB speeds seems to be well worth the effort – if you choose to unlock the multiplier, unlock this higher FSB setting as well to give a significant performance boost.
Possible Solution for Running High FSB
On my 2700 and other new chips, they ran cut-connected-connected-connected. These bridges set the default FSB, with the former being 133, and the latter being 166. To test whether this affected the chip being able to run a high FSB in this board, I connected the third L12 bridge (one away from the "L12") on Aceman's 2200 - This would in effect make it look like a new XP2800 (166x13.5). We began testing and the chip was defaulting to a 166 FSB.
Source | neowin
interesant of niet :)
en wie weet er meer van
Anders om heb ik wel van gehoord omdat ie dan beter te oc-en zou zijn?
Op een Abit NF7-S wou ie niet ver oc'en als ie op 166 stond dus moest je em terug zetten naar 133.
Ik snap het nut hier niet echt van aangezien bijna alle mobo's tegenwoordig wel een optie hebben om de fsb aan te passen...
En als je het niet hebt dan moet je ook nog moeilijk doen met bruggen om die te veranderen zodat je de multiplier kan veranderen, want als je de FSB niet kan regelen dan kan je de multiplier zeker niet regelen.
Oftewel dan wordt het heel erg lastig... en de vraag is maar of een mobo wat alleen een fsb van 100 of 133 heeft (wisselbaar dmv een jumper) wel een fsb van 166 aankan...
Beetje nutteloos denk ik zo...
[ Voor 4% gewijzigd door Verwijderd op 04-01-2003 15:30 ]
Beetje al wat vaker langsgekomen ook al....
