Sinds vandaag kan ik mijn eigen ip adres niet meer bereiken (80.100.20.178) vanuit het interne netwerk lukt dat natuurlijk wel want dan antwoord de router direct zonder naar buiten te hebben gecommuniceert als ik nou bijvoorbeeld via www.samspade.org mij zelf een traceroute verkoop krijg ik het volgende te zien.
fia178-20-100.dsl.hccnet.nl resolves to 80.100.20.178
Do not contact either Los Nettos (ln.net) or Centergate Research Group (centergate.com) based on the results of this traceroute.
3 130.152.180.21 5.418 ms isi-1-lngw2-atm.ln.net [AS226] Los Nettos origin AS
4 4.24.4.249 8.955 ms gigabitethernet5-0.lsanca1-cr3.bbnplanet.net [AS1] GTE Internetworking
5 4.24.4.2 9.685 ms p6-0.lsanca1-cr6.bbnplanet.net [AS1] GTE Internetworking
6 4.24.5.49 9.473 ms p6-0.lsanca2-br1.bbnplanet.net [AS1] GTE Internetworking
7 4.24.5.46 8.663 ms p15-0.lsanca2-br2.bbnplanet.net [AS1] GTE Internetworking
8 4.25.111.1 9.918 ms p1-0.lsanca2-cr1.bbnplanet.net [AS1] GTE Internetworking
9 4.24.118.18 6.841 ms laxbrdr-0120-0310-1-3.xlsanca21-qwest.bbnplanet.net [AS1] GTE Internetworking
10 205.171.19.37 5.845 ms lax-core-01.inet.qwest.net (Fake rDNS) [AS209] Qwest Communications
11 205.171.8.43 6.864 ms bur-core-01.inet.qwest.net (Fake rDNS) [AS209] Qwest Communications
12 205.171.205.26 45.594 ms iah-core-02.inet.qwest.net (Fake rDNS) [AS209] Qwest Communications
13 205.171.31.1 46.137 ms iah-core-01.inet.qwest.net (Fake rDNS) [AS209] Qwest Communications
14 205.171.8.206 79.190 ms ewr-core-02.inet.qwest.net (Fake rDNS) [AS209] Qwest Communications
15 205.171.17.130 79.837 ms ewr-brdr-02.inet.qwest.net (Fake rDNS) [AS209] Qwest Communications
16 134.222.254.1 157.432 ms ledn-rou-1003.NL.eurorings.net (DNS error) [AS286] Formerly EUnet International Backbone
17 134.222.96.38 159.326 ms asd2-rou-1001.NL.eurorings.net (DNS error) [AS286] Formerly EUnet International Backbone
18 134.222.199.134 177.934 ms asd-dc2-ias-ur10.nl.kpn.net (DNS error) [AS286] Formerly EUnet International Backbone
19 195.190.227.132 180.281 ms asd-pbw-ias-arg13.nl.kpn.net (DNS error) [AS1136] Upstreams, Peers & BGP-customers
20 62.251.0.254 178.270 ms gw1.hccnet.nl [AS20689] HCCnet Autonomous System
21 62.251.0.221 178.111 ms fia-201.kpn.hccnet.nl [AS20689] HCCnet Autonomous System
22 10.26.1.3 189.197 ms DNS error
blijkbaar wordt de trace naar 10.26.1.3 gestuurd waar samspade het volgende over te zeggen heeft;
10.26.1.3 is an IP address reserved for non-routed networks. That means it may be used on any number of private networks and doesn't connect to the internet at large (except, maybe, via application level gateways or NATs). See RFC 1918 Address Allocation for Private Internets
Even voor de duidelijkheid dit is sinds vandaag en er is verder niks verandert. Ik kan trouwens gewoon internetten. Heeft iemand een idee wat er aan de hand kan zijn, want zoals gebruikelijk geeft HCCnet de schuld aan KPN en andersom.
Alvast bedankt.
Alvast bedankt.
