[bind] dns server beveiligen?
  • 36 views sinds 30-01-2008
Ik heb mijn DNS server draaien op mijn Debian bak... Maar hoe kan ik de DNS server beveiligen? Zodat, alleen mijn interne netwerk er gebruik van kan maken?
  • yeadder
firewall ??? zodat het internet geen verbinding meer kan maken met port 53 (geloof ik).
  • M4RTiN
  • Laatst online: 24-11-2024
kan je niet met je firewall instellingen of zelf in de conf file van je dns server zelf ff instellen dat alleen 192.168.0/24 ofzoiets kan luisteren op poort 53 ?
  • Steije
  • Laatst online: 29-08 10:48
options {
  allow-query {
     192.168.0.0/24
Some people manage by the book, even though they don't know who wrote the book or even what book.
dit is mijn named.conf
options {
         allow-query { 192.168.1.0/24; localhost; };
         directory "/etc/bind";
        // Uncommenting this might help if you have to go through a
        // firewall and things are not working out.  But you probably
        // need to talk to your firewall admin.
        // query-source port 53;
controls {
        inet 127.0.0.1 allow { localhost; } keys { rndc_key; };
key rndc_key {
    algorithm "hmac-md5";
    secret "OoC7ckPCySRctaEx1XgEf4qFBl0q1aldV1wk3QYZyqkNs5wXMVslRSt7hFJ0rv7+el649QB8RwYsnLHOGAkwfA==";
zone "." {
        type hint;
        file "/etc/bind/root.cache";
dit is mijn firewall
IPTABLES=/sbin/iptables
echo "Enabling forwarding"
echo "1" > /proc/sys/net/ipv4/ip_forward
echo "Enabling DynamicAddr..."
echo "1" > /proc/sys/net/ipv4/ip_dynaddr
echo "Clearing any existing rules and setting default policy"
$IPTABLES -P INPUT ACCEPT
$IPTABLES -F INPUT
$IPTABLES -P OUTPUT ACCEPT
$IPTABLES -F OUTPUT
$IPTABLES -P FORWARD DROP
$IPTABLES -F FORWARD
$IPTABLES -T nat -F
echo "Allowing host in and out"
$IPTABLES -A FORWARD -i eth0 -o eth1 -m state --state ESTABLISHED,RELATED,NEW -j ACCEPT
$IPTABLES -A FORWARD -i eth1 -o eth0 -j ACCEPT
$IPTABLES -A FORWARD -j LOG
$IPTABLES -t nat -A POSTROUTING -o eth0 -j MASQUERADE
$IPTABLES -A FORWARD -i eth0 -m state --state INVALID -j DROP
$IPTABLES -A OUTPUT -m state -p icmp --state INVALID -j DROP
De topicstart is te mager. Op deze wijze is er weinig nuttigs van te zeggen lijkt me. Bovendien is het wel de bedoeling dat je eerst eens zelf gaat zoeken of je je probleem kunt oplossen.
[rml]-=[ Nieuw in NOS? Eerst dit lezen! GEEN HELPDESK! ]=-[/rml]
Op slot.
