FreeBSD 4.7 probleem i.c.m. portupgrade
  • 36 views sinds 30-01-2008
Hey,
Ik krijg deze melding/error:
29
30
31
32
33
34
35
localhost# portsupgrade -ra
portsupgrade: Command not found.
localhost# portupgrade -ra
--->  Upgrading 'ruby-1.6.8.p3' to 'ruby-1.6.8' (lang/ruby)
--->  Building '/usr/ports/lang/ruby'
===>  Cleaning for ruby-1.6.8
===>  Extracting for ruby-1.6.8
>> Checksum mismatch for ruby/ruby-1.6.8.tar.gz.
Make sure the Makefile and distinfo file (/usr/ports/lang/ruby/distinfo)
are up to date.  If you are absolutely sure you want to override this
check, type "make NO_CHECKSUM=yes [other args]".
*** Error code 1
Stop in /usr/ports/lang/ruby.
** Command failed [exit code 1]: /usr/bin/script -qa
/tmp/portupgrade1840.5 make
** Fix the problem and try again.
Skipping 'lang/ruby16-shim-ruby18'
(ruby-shim-ruby18-1.7.3.2002.12.11_1) because 'lang/ruby'
(ruby-1.6.8.p3) failed
Skipping 'databases/ruby-bdb1' (ruby-bdb1-0.1.7)
because 'lang/ruby' (ruby-1.6.8.p3) failed
Skipping 'sysutils/portupgrade' (portupgrade-20021216)
because 'lang/ruby16-shim-ruby18'
(ruby-shim-ruby18-1.7.3.2002.12.11_1) failed
** The following packages were not installed or upgraded
(*:skipped / !:failed)
        ! lang/ruby (ruby-1.6.8.p3)     (checksum mismatch)
        * lang/ruby16-shim-ruby18 (ruby-shim-ruby18-1.7.3.2002.12.11_1)
        * databases/ruby-bdb1 (ruby-bdb1-0.1.7)
        * sysutils/portupgrade (portupgrade-20021216)
Nou, dit is erg vervelend dus nu ging ik naar de dir /usr/ports/lang/rugy en nu kreeg ik dit:
localhost# make clean install
*** Error code 1
Ik heb een cvsup gedaan, maar ik weet niet hoe ik dit moet oplossen!
[ Voor 29% gewijzigd door Verwijderd op 31-12-2002 10:58 . Reden: lay-out fix ]
[rml]-=[ Nieuw in NOS? Eerst dit lezen! GEEN HELPDESK! ]=-[/rml]
Ik zie nergens in je post dat je zelf al gezocht hebt. Lees bovenstaande draad eens door.
Op slot.
