M'n stats zijn er!
  • 125 views sinds 30-01-2008
  • RvV
  • Laatst online: 23:57
Ja hoor, ze zijn er! (maar voor hoe lang)...
Y'24
Laat zien dan
De mijne niet :(
same here :(
  • RvV
het was ook niet voor lang... nu krijg ik:
There was an error processing your request
The server was unable to complete your request.
This is most likely due to one of two reasons. Either the system is offline for the daily update, or Nugget is mucking about in the database again.
Either way, it's probably not anything you should be concerned about. I suggest you head to the kitchen and raid the fridge. Maybe have a nice loose-meat sandwich and a wholesome glass of milk (<dbaker> or two yummy cans of Dr. Pepper </dbaker>).
By the time you're back, the server will probably be finished and you can check your stats. If it's not, the situation will seem a lot less important if you've got a full stomach.
Thanks for your patience.
Y'24
De mijne staan er:):):P:P
Kijk ik nog eens lees ik dit:
Data shown reflects all blocks received as of 7-Nov-2000 at 23:59 UTC
ach.. de OGR stats zijn wel tm 9-11 :)
  • punica
punica
Longtime Member
Vannacht om 02.30 waren ze er wel hoor.!!!!
  • mvliet
  • Laatst online: 13-04 09:27
Jippie !!!
10:42 de stats zijn d'r weer !!!!
www.cenobytes.nl Noize Party's & industrialnation.nl
