[vmware]modulemaken
ik heb net vmware ge-emerged
daarnaa vmware-config.pl gedraait maar ik krijg deze fout melding
29
30
31
32
33
34
35
36
37
38
39
make: Entering directory `/tmp/vmware-config4/vmmon-only'
make[1]: Entering directory `/tmp/vmware-config4/vmmon-only'
make[2]: Entering directory `/tmp/vmware-config4/vmmon-only/driver-2.4.19'
In file included from ../linux/driver.c:11:
../linux/driver-config.h:38:31: warning: linux/modversions.h: No such file or directory
In file included from ../linux/hostif.c:19:
In file included from ../common/hostif.h:34,
                 from ../common/vmx86.c:19:
                 from ../common/task.c:36:
                 from ../common/memtrack.c:20:
                 from ../common/phystrack.c:21:
                 from ../common/cpuid.c:15:
make[2]: Leaving directory `/tmp/vmware-config4/vmmon-only/driver-2.4.19'
../linux/driver-config.h:38:31: linux/modversions.h: No such file or directory
make[2]: *** [driver.o] Error 1
make[1]: *** [driver] Error 2
make[1]: Leaving directory `/tmp/vmware-config4/vmmon-only'
make: *** [auto-build] Error 2
make: Leaving directory `/tmp/vmware-config4/vmmon-only'
Unable to build the vmmon module.
For more information on how to troubleshoot module-related problems, please
visit our Web site at "http://www.vmware.com/download/modules/modules.html" and
"http://www.vmware.com/support/reference/linux/prebuilt_modules_linux.html".
Execution aborted.
het bestand modversions.h bestaat wel maar staat in een andere map namelijk
/lib/modules/2.4.19/build/include/linux
raar dus
ik gebruik gcc 3.2
  • mpol
  • Laatst online: 19-01 18:45
mpol
root@localhost
Wat staat er in de Makefile precies als het include pad?
Hij zou niet moeten linken naar include/modversions.h, oftewel /usr/include/...., dat is deel van kernelheaders oftewel glibc-headers.
Hij moet linken naar je /lib/modules/2.4.19/build/include/linux of je /usr/src/linux/include/linux wat als het goed is hetzelfde is.
https://timelord.nl
  • _nethack
  • Laatst online: 12-09 11:03
_nethack
We're all MAD here
Heb je wel je kernel source in /usr/src/linux staan?
Sometimes you just have to sit back, relax, and let the train wreck itself
die kernel headers kloppen
als ik namelijk een verkeerd pad opgeef zegt hij dat heij de headers niet kan vinden
het bestand modversions.h staat gewoon in /lib/modules/2.4.19/build/include/linux
  • pistole
  • Laatst online: 10:00
pistole
Frutter
kijk anders even met strace waar hij daadwerkelijk die headers vandaag probeert te halen
Ik frut, dus ik epibreer
strace ?? zegt me nix
hoe werkt dat precies
heb het wel net gemerged
  • pistole
pistole
Frutter
man strace :)
Je kan daarmee de system calls zien enzo. Dus ook welke bestanden er geopend worden (of pogingen daartoe)
  • igmar
  • Laatst online: 09-09 19:53
igmar
ISO20022
Verwijderd schreef op 25 december 2002 @ 01:03:
raar dus
ik gebruik gcc 3.2
Gewoon /lib/modules/2.4.19/build/include als pad opgeven ipv /usr/include/linux....
standaart staat hij al op /lib/modules/2.4.19/build/include
