v7700 en win2k
ik heb nu net een v7700 van asus gekregen met 32 mb ddr.
maar hij wil niet open_gl draaien.
ik wil namelijk mohaa spelen, maar dan krijg ik dit:
[quote]
--- Common Initialization ---
Medal of Honor Allied Assault 1.00 win-x86 Dec 6 2001
----- FS_Startup -----
Current search path:
D:\PROGRA~1\EAGAME~1\MOHAA\main\Pak5.pk3 (259 files)
D:\PROGRA~1\EAGAME~1\MOHAA\main\Pak4.pk3 (593 files)
D:\PROGRA~1\EAGAME~1\MOHAA\main\Pak3.pk3 (669 files)
D:\PROGRA~1\EAGAME~1\MOHAA\main\Pak2.pk3 (4722 files)
D:\PROGRA~1\EAGAME~1\MOHAA\main\Pak1.pk3 (772 files)
D:\PROGRA~1\EAGAME~1\MOHAA\main\Pak0.pk3 (11175 files)
D:\PROGRA~1\EAGAME~1\MOHAA/main
18190 files in pk3 files
execing default.cfg
execing menu.cfg
execing newconfig.cfg
Config: unnamedsoldier.cfg
execing configs/unnamedsoldier.cfg
couldn't exec localized.cfg
execing autoexec.cfg
Unknown command "fov"
couldn't exec custom.cfg
...detecting CPU, found Intel Pentium III
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
------- Input Initialization Complete ------- 38
You are now setup for easy mode.
----- Client Initialization -----
Called FadeSound with: 0.000000
----- Initializing Renderer ----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'D:\WINNT\System32\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using colorsbits of 16
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...GLW_ChoosePFD failed
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
GLW_StartOpenGL() - could not load OpenGL subsystem
[/qoute]
heeft iemand een idee hoe ik het moet oplossen??
ik heb de nieuwste detonator drivers geprobeerd en ook die van asus, maar hij doet nog erg weinig in open_gl...
  • McKaamos
McKaamos
Master of the Edit-button
geprobeerd het spel weg te mikken en opnieuw te installen?
staat het spel in de verkeerde reso?
...initializing QGL
of toevallig de verkeerde driver ingesteld (3Dfx voodoo driver?)
  • mistaoutlaw
  • Laatst online: 18-08 12:18
www.guru3d.com download hier de nieuwste drivers, kijk of alles goed ingesteld staat in het spelletje.
I was born intelligent - education ruined me
