[P4T-E] Hoe zit het met de WoL?
  • 106 views sinds 30-01-2008
WoL site:
http://www.madge.com/_ass...dvFeat/WonLAN/WonLAN2.htm
Wake-On-LAN
Wake-On-LAN is IBM's initial strategy for remotely powering on and configuring a PC through a network management application. Whereas ACPI's remote wake-up capability utilises the PCI bus to send the wake-up signal from the LAN connection to the PC system, Wake-On-LAN requires a cable connection inside the PC from the network adapter to the motherboard.
Wake-on-LAN uses a special 3-wire cable fitted to the adapter and the computer motherboard to supply the adapter with auxiliary power when the computer is shutdown and to enable the adapter to signal wake-up events to the computer. Computers which support the latest PCI power management specification support an extra PCI bus (PME) which the adapter can use to signal wake-up events rather than requiring a Wake-on-LAN cable.
Asus site:
http://www.asus.com/prog/spec.asp?m=P4T-E
Processor Intel Socket 478 Pentium®4: 1.4GHz ~2.4GHz+
400MHz Intel® NetBurst™ Micro-Architecture System Bus
Chipset Intel 82850 Memory Controller Hub (MCH)
Intel 82801 I/O Controller Hub 2 (ICH2)
Supports 4X AGP, PC800 RDRAM and UltraDMA/100
FSB 400MHz
Memory 4 x RIMM Sockets
Dual Channel RDRAM Support: Max. 2GB PC800/PC600 ECC/non-ECC RDRAM Memory
Max. Transfer Speed 3.2GB/s
Expansion Slots 1 x AGP Pro/AGP 4X
5 x PCI
1 x CNR
IDE Ports 2 x UltraDMA/100/66/33
Audio (Optional) AC '97 Compliant Audio
SPDIF out Interface
LAN (Optional) Chipset Integrated LAN Controller
Special Features Power Loss Restart, ASUS JumperFree, CPU Throttle, STR (Suspend-to-RAM), Vcore Adjustable
Back Panel I/O 2 x USB
1 x Parallel
2 x Serial
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x Audio I/O (Optional)
1 x Game/MIDI (Optional)
On Board I/O One USB Header Supports 2 Additional USB Ports
CPU/Chassis/Power Fan
ATX 12V Power Connectors
CD/AUX/Modem Audio In (Optional)
SPDIF out (Optional)
BIOS 2Mb Award BIOS with PnP, ACPI, SMBIOS2.3, Green, Boot Block BIOS
Industrial Standard PCI 2.2, USB 1.1
Manageability WfM2.0, DMI2.0, WOL, WOR, Chassis Intrusion
Accessories User's Manual
Driver CD
ASUS PC Probe
UltraDMA/100 & Floppy Cable
2-Port USB Bracket
2x C-RIMM Continuity Models
CPU Retention Module
Board Size ATX Form Factor Size : 30.5cm x 24.4cm (12.0" x 9.6")
WOL dus, en die optie is er inderdaad in het BIOS... Alleen, de 3 WOL pinnetje
zijn afgesoldeerd! Moet ik het nu dus met die "moderne techniek" doen? Of is
dit gewoon weer speciale editie van mobo, die ik NIET had moeten hebben?
Ik wil nog 3Com 1 Gigabit NIC kopen, die dat dan waarschijnlijk wel aankan...
Maar kan mijn mobo dit dus? Kortom:
Hoe werkt de WoL op mijn Asus P4T-E?
  • Flappie
  • Laatst online: 22:40
Volgens mij kan dat ook via het PCI slot. Dat weet ik alleen niet zeker :)
Flappie schreef op 16 December 2002 @ 20:09:
En hoe kom je daar dan zo bij dat dat zou kunnen? Waar haal je die info vandaan?
Iemand? Hoe hebben de andere P4T-E bezitters dit gedaan?
  • Rick2001
  • Laatst online: 09-08 01:10
Rick2001
9950X delidded en direct die
Heb je dit dan echt nodig ?
MESHIFY 2XL - MSI X670E CARBON - 9950X - 32GB DDR5 LEXAR 6400 - RX 9070 - GIGABYTE M32UC 4K 160HZ - ALPHACOOL UT60 420 & 360 & 1080 - LAING DDC1+ - TECHN CPU - CORSAIR AX850 - 3x9100PRO 4TB - 2x850PRO 2TB - U.2 7.68TB + OPTANE P5800X + KINGSTON G5 8TB
  • job
  • Laatst online: 07-09 21:16
job
in elk geval Wake on Lan nog even activeren in je bios.
je ziet het dan aan je nic, omdat het lampje blijft branden.
maar hoe je dan die pc aandoet?? via een commando over het netwerk misschien?
heb je al gegoogled?
neem aan dat je daar software voor nodig hebt.
even gegoogled, je zou normaal gesproken een kabel moeten hebben, die je aansluit tussen netwerkkaart en moederbord.
misschien dat de moderene moederborden dit ook via de pci poort kunnen?
staat er niets over in je handleiding?
ik heb in windows xp in elk geval een optie gevonden op wol aan te zetten.
die optie kan je vinden in systeembeheer. en dan bij de eigenschappen van je nic.
ook op mijn mobo zitten er geen connectoren voor WOL
en mijn mobo zou dat ook moeten ondersteunen.
misschien dat het dan wel werkt via de pci poort
[ Voor 68% gewijzigd door job op 21-12-2002 01:29 ]
Ja, weet jij hoe het moet?
En dat BIOS dat jij hebt, kun je mij die mailen aub? :)
damster schreef op 21 december 2002 @ 00:44:
- WOL in BIOS staat aan...
- Als het kán, krijg ik de pc wel aan over het netwerk
- Die kabel kán ik er dus niet tussen zetten...
- Of dat via de PCI poort kan op dit mobo is dus inderdaad mijn vraag, want die 3
WOL pinnetjes zijn dus afgesoldeerd ;(
En ja, ik heb uiteraard gezocht en de handleiding gelezen (zie quotes in opening)
Kan een Realtek 8139B met WOL ondersteuning het ook via PCI?
  • Rick2001
Rick2001
Verwijderd schreef op 21 december 2002 @ 09:55:
Als je WOL in je bios hebt ingeschakeld, dan moet je zowieso nog een kabeltje aansluiten op je mainboard.
De aansluiting hiervoor zit onder PCI slot 5.
Rick2001 schreef op 21 december 2002 @ 22:01:
En die is dus afgesoldeerd bij mij :(
  • BalusC
BalusC
Carpe diem
Is WOL niet gewoon optioneel :?
Ik heb zelf een Asus A7V266-E, die had WOL ondersteuning maar geen pinnetjes. Uiteindelijk bleek dat de WOL in het pci-slot zelf zit. Het enige wat je hiervoor nodig hebt ik een netwerkkaart die WOL ondersteunt maar geen connector heeft. Deze kunnen WOL-len via pci.
  • Merlin T
  • Laatst online: 06-09 22:02
Ik heb ook een P4T-E zonder pinnetjes voor WOL, maar als ik mijn pc uitzet blijft het lampje op de switch wel gewoon branden. Dus het zou moeten werken, ik moet nu alleen nog even de goede software zoeken.
  • Redje
  • Laatst online: 18-08 21:30
Mijn P4T-E heeft dus geen LAN :)
BalusC schreef op 22 December 2002 @ 11:28:
Dat weet ik dus niet :)
Verwijderd schreef op 22 December 2002 @ 11:31:
Daar hoop ik dus op :)
Merlin T schreef op 22 December 2002 @ 15:36:
Kijk daar maar ff dan :) En test et aub :)
Redje schreef op 22 December 2002 @ 15:49:
Die van mij ook niet :+
  • Merlin T
Sorry voor de late reactie. Maar het werkt bij mij nu. Ik gebruik gewoon AMD Magicpacket. Mijn moederbord heeft dus geen aparte connector voor WOL en mijn netwerkkaart heeft wel een aparte connector voor WOL, maar zonder dat ik dat dus aansluit werkt het wel. :)
/me heeft ondertussen een Asus P4T533 waar WOL via PCI op zit :)
  • Glashelder
Glashelder
Anti Android
Flappie schreef op 16 december 2002 @ 20:09:
Klopt. Hier werkt WOL ook via het PCI slot zonder een WOL-kabeltje.
Blateraars hierzo soms :+ :
Rick2001 schreef op 21 December 2002 @ 22:01:
[ Voor 34% gewijzigd door Glashelder op 09-03-2003 12:21 ]
