Fotmelding bij Retrun to Castle Wolfenstein
Hoi hoi,
Ik heb net Wolfenstein geinstalleerd en krijg een rare foutmelding namelijk dit:
Wolf 1.0.0 win-x86 Nov 13 2001
----- FS_Startup -----
Current search path:
C:\GAMES\RETURN~1\main\sp_pak2.pk3 (232 files)
C:\GAMES\RETURN~1\main\sp_pak1.pk3 (1342 files)
C:\GAMES\RETURN~1\main\pak0.pk3 (4775 files)
C:\GAMES\RETURN~1/main
6349 files in pk3 files
execing default.cfg
couldn't exec language.cfg
couldn't exec wolfconfig.cfg
execing autoexec.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found Intel Pentium III
Bypassing CD checks
----- Client Initialization -----
Cmd_AddCommand: map_restart already defined
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\System32\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using desktop display depth of 32
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...50 PFDs found
...hardware acceleration found
...PIXELFORMAT 8 selected
...creating GL context: failed
...failed hard
...restoring display settings
...WARNING: could not set the given mode (3)
...using colorsbits of 16
...calling CDS: ok
----- CL_Shutdown -----
RE_Shutdown( 1 )
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL ): failed
...releasing DC: failed
...destroying window
...resetting display
...shutting down QGL
...unloading OpenGL DLL
Q_strncpyz: NULL src
Volgens mij heeft het iets met OpenGL te maken,
Heeft iemand dit ook al eens gehad en/of kan iemand mij hiermee helpen?
Alvast bedankt...
Roy
  • Tux
  • Laatst online: 20-10 22:36
Tux
Drivers van je videokaart of OpenGL opnieuw installeren :?
The NS has launched a new space transportation service, using German trains which were upgraded into spaceships.
Welke videokaart heb je?
Ik heb een Geforce4 64MB videokaart.
Dan moet je vanaf www.nvidia.com even de nieuwste driver downloaden en installeren.
