Line Message
22 The tag: "body" doesn't have an attribute: "height:100%;" in currently active versions.
22 The tag: "body" doesn't have an attribute: "bottommargin" in currently active versions.
22 The tag: "body" doesn't have an attribute: "leftmargin" in currently active versions.
22 The tag: "body" doesn't have an attribute: "topmargin" in currently active versions.
22 The tag: "body" doesn't have an attribute: "marginheight" in currently active versions.
22 The tag: "body" doesn't have an attribute: "marginwidth" in currently active versions.
23 The tag: "table" doesn't have an attribute: "vertical-align:top;" in currently active versions.
23 The tag: "table" doesn't have an attribute: "height:100%;" in currently active versions.
23 The tag: "table" doesn't have an attribute: "bordercolor" in currently active versions.
26 The tag: " tr" is invalid inside tag: "tr". The "tr" end tag is optional. Validation will proceed as if the tag were ended.
31 The tag: "table" doesn't have an attribute: "height" in currently active versions.
54 middle is not a valid value for the "align" attribute in HTML32. Valid values for this attribute are: Dynamic expression, center, left, right.
54 middle is not a valid value for the "align" attribute in HTML4. Valid values for this attribute are: Dynamic expression, center, char, justify, left, right.
54 middle is not a valid value for the "align" attribute in any of the currently active versions. See the above warnings for more details.
56 The tag: "table" doesn't have an attribute: "height" in currently active versions.
65 In HTML 4.0, FONT is deprecated. It may become obsolete in future versions, consider using style sheets instead.
96 "100%" is not a valid value for the "height" attribute in HTML32. Valid values for this attribute are: Dynamic expression, positive non zero integer.
96 "100%" is not a valid value for the "height" attribute in any of the currently active versions. See the above warnings for more details.
97 "100%" is not a valid value for the "height" attribute in HTML32. Valid values for this attribute are: Dynamic expression, positive non zero integer.
97 "100%" is not a valid value for the "height" attribute in any of the currently active versions. See the above warnings for more details.
98 The tag: "table" doesn't have an attribute: "height" in currently active versions.
100 The tag: "td" doesn't have an attribute: "bordercolor" in currently active versions.
103 "#000099"BORDERCOLOR="#FFFFFF" is not a valid value for the "bgcolor" attribute in HTML4. Valid values for this attribute are: 16 color names, Dynamic expression, sRGB, CFML six digit HEX.
103 "#000099"BORDERCOLOR="#FFFFFF" is not a valid value for the "bgcolor" attribute in any of the currently active versions. See the above warnings for more details.
106 The tag: "td" doesn't have an attribute: "bordercolor" in currently active versions.
111 The tag: "td" doesn't have an attribute: "bordercolor" in currently active versions.
116 The tag: "td" doesn't have an attribute: "bordercolor" in currently active versions.
121 The tag: "td" doesn't have an attribute: "bordercolor" in currently active versions.
126 The tag: "td" doesn't have an attribute: "bordercolor" in currently active versions.
131 The tag: "td" doesn't have an attribute: "bordercolor" in currently active versions.
136 The tag: "td" doesn't have an attribute: "bordercolor" in currently active versions.
141 The tag: "td" doesn't have an attribute: "bordercolor" in currently active versions.
146 The tag: "td" doesn't have an attribute: "bordercolor" in currently active versions.
151 The tag: "td" doesn't have an attribute: "bordercolor" in currently active versions.
155 The tag: "td" doesn't have an attribute: "bordercolor" in currently active versions.
160 The tag: "td" doesn't have an attribute: "bordercolor" in currently active versions.
163 The tag:"form" is not allowed within: "tbody" It is only allowed within: del, fieldset, iframe, ins, noframes, noscript, object, td, th.
165 The tag:"form" is not allowed within: "tbody" It is only allowed within: del, fieldset, iframe, ins, noframes, noscript, object, td, th.
165 The value
HTTP://PCDB.BBNED.NL/ADSL2.PHP3 is not valid for the "action" attribute in HTML20. The value is valid if double quoted.
165
HTTP://PCDB.BBNED.NL/ADSL2.PHP3 is not a valid value for the "action" attribute in any of the currently active versions. See the above warnings for more details.
170 "100%" is not a valid value for the "height" attribute in HTML32. Valid values for this attribute are: Dynamic expression, positive non zero integer.
170 "100%" is not a valid value for the "height" attribute in any of the currently active versions. See the above warnings for more details.
170 The tag: "td" doesn't have an attribute: "background" in currently active versions.
171 The tag: "table" doesn't have an attribute: "height" in currently active versions.
171 The tag: "table" doesn't have an attribute: "background" in currently active versions.
173 The tag: "th" doesn't have an attribute: "border" in currently active versions.
173 The tag: "th" doesn't have an attribute: "bordercolor" in currently active versions.
177 "100%" is not a valid value for the "height" attribute in HTML32. Valid values for this attribute are: Dynamic expression, positive non zero integer.
177 "100%" is not a valid value for the "height" attribute in any of the currently active versions. See the above warnings for more details.
177 The tag: "td" doesn't have an attribute: "border" in currently active versions.
177 The tag: "td" doesn't have an attribute: "bordercolor" in currently active versions.
188 "100%" is not a valid value for the "height" attribute in HTML32. Valid values for this attribute are: Dynamic expression, positive non zero integer.
188 "100%" is not a valid value for the "height" attribute in any of the currently active versions. See the above warnings for more details.
193 The tag: "table" doesn't have an attribute: "height" in currently active versions.
198 middle is not a valid value for the "align" attribute in HTML32. Valid values for this attribute are: Dynamic expression, center, left, right.
198 middle is not a valid value for the "align" attribute in HTML4. Valid values for this attribute are: Dynamic expression, center, char, justify, left, right.
198 middle is not a valid value for the "align" attribute in any of the currently active versions. See the above warnings for more details.
199 middle is not a valid value for the "align" attribute in HTML32. Valid values for this attribute are: Dynamic expression, center, left, right.
199 middle is not a valid value for the "align" attribute in HTML4. Valid values for this attribute are: Dynamic expression, center, char, justify, left, right.
199 middle is not a valid value for the "align" attribute in any of the currently active versions. See the above warnings for more details.
202 middle is not a valid value for the "align" attribute in HTML32. Valid values for this attribute are: Dynamic expression, center, left, right.
202 middle is not a valid value for the "align" attribute in HTML4. Valid values for this attribute are: Dynamic expression, center, char, justify, left, right.
202 middle is not a valid value for the "align" attribute in any of the currently active versions. See the above warnings for more details.
203 middle is not a valid value for the "align" attribute in HTML32. Valid values for this attribute are: Dynamic expression, center, left, right.
203 middle is not a valid value for the "align" attribute in HTML4. Valid values for this attribute are: Dynamic expression, center, char, justify, left, right.
203 middle is not a valid value for the "align" attribute in any of the currently active versions. See the above warnings for more details.
205 The tag: "table" doesn't have an attribute: "height" in currently active versions.
210 middle is not a valid value for the "align" attribute in HTML32. Valid values for this attribute are: Dynamic expression, center, left, right.
210 middle is not a valid value for the "align" attribute in HTML4. Valid values for this attribute are: Dynamic expression, center, char, justify, left, right.
210 middle is not a valid value for the "align" attribute in any of the currently active versions. See the above warnings for more details.
210 The tag: "td" doesn't have an attribute: "background" in currently active versions.
212 In HTML 4.0, FONT is deprecated. It may become obsolete in future versions, consider using style sheets instead.
237 No starting tag found for: "pre", or it was closed too many times
237 No starting tag found for: "xmp", or it was closed too many times
237 No starting tag found for: "noscript", or it was closed too many times
219 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using &#copy; instead.
