samba - kan niet schrijven in een map
  • 87 views sinds 30-01-2008
met samba heb ik mijn server gelinkt aan mijn netwerk. Ik kan nu alleen niet schrijven in de map van mijn proftp. Mijn /home/shared folder kan ik wel beschrijven vanaf een andere computer. Mijn samba config staat hieronder:
# Created by Point Clark Networks
# Samba lets this gateway look like a Microsoft machine. Only the local
# network can see the shared folders/printers.
# - Default shares:
# shared - is just an public folder where everyone can put files, create
# directories, and do whatever. If you have a big hard disk,
# you can put all your MP3s here!
# website - if you decide to run your own website, this is where you
# put all your html files. You also have access to the
# cgi-bin if you want to get fancy with scripts.
# cdrom - if the ClarkConnect installation detects a CD-ROM, then
# it will add this as a shared resource.
#======================= Global Settings =====================================
[global]
netbios name = servert
workgroup = cl198a
server string = in de berging
bind interfaces only = True
interfaces=eth1 eth2 192.168.1.1/255.255.255.0
printcap name = /etc/printcap
load printers = yes
max log size = 50
security = share
socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
dns proxy = no
# ClarkConnect - WINS
# Uncomment "wins support" if you want this server to become a WINS server.
#wins support = yes
#domain master = yes
#local master = yes
#preferred master = yes
#os level = 65
# ClarkConnect - IPsec network
# See documentation on website
#remote announce = 192.168.10.1
#remote browse sync = 192.168.10.1
#============================ Share Definitions ==============================
[shared]
comment = Shared Folder
path = /home/shared
writable = yes
public = yes
printable = no
# **** Do not be tempted to make this WebDAV folder writable :) ****
# File locking issues may cause grief, so it's just a bad idea.
[configuratie]
comment = Configuratie bestanden server
path = /
writable = yes
public = yes
printable = no
hosts allow = 192.168.1.2
hosts deny = ALL
[FTP server]
comment = inhoud ftp server
path = /var/ftp
writable = yes
public = yes
printable = yes
[website]
comment = Web Site
path = /var/www
writable = yes
public = yes
printable = no
create mask = 0755
[printers]
printing = cups
browseable = yes
printable = yes
public = yes
[webdav]
comment = Read Only - Internet Shared Folder
path = /home/webdav/files
writable = no
public = yes
printable = no
Wat doe ik fout?
  • leo2222
  • Laatst online: 22-08 20:09
Het komt waarschijnlijk omdat die map aan een andere gebruiker is toegewezen.
Als dit zo is kan het mischien hier mee worden opgelost
# create mode = 0664
directory mode = 0775
[ Voor 5% gewijzigd door leo2222 op 14-12-2002 00:08 ]
  • blaataaps
Wat zijn de rechten op de directory van je ftp-dir?
ls -ld /var/ftp dus.
Je kunt via samba wel schrijfrechten geven, maar als de user als wie je probeert te schrijven dat niet mag, zal dat via samba net zo goed niet mogen.
en hoe verander je ook alweer dat het niet meer read-only is?
ja, dat is heel leuk, maar die directory kan ik dus niet veranderen. Of als newbie doe ik weer eens iets fout. Wat moet ik dan intijpen dat de usergroup nobody ook schrijfrechten krijgt in die directory?
  • Fatal-Error
Installeer windows en klik op een paar checkboxes in de properties van die "map".
(Of lees bovenstaande links eens gedeeltelijk door en probeer het te snappen.)
Welcome to the desert of the real.
  • Liam
  • Laatst online: 29-12-2023
Liam
Wat nou 1 proc is genoeg.. :P
gewoon chmod 777 op die map doen dus :)
If it bleeds, we can kill it!! |Werkbak specs|CCNP, bezig met Master.
Liam_xi schreef op 14 December 2002 @ 06:19:
:X.
Hoe ver heen was NOS nou ook alweer? :{.
ok ok, begrepen, hij kan dicht van mij
Liam_xi schreef op 14 december 2002 @ 06:19:
Dit is absoluut niet wat wij willen hebben in NOS. Dit antwoord is fout en ik zou maar eens nadenken wat de gevolgen zijn als je dit zo doet ...
Burlap: zakt wel weg als niemand replied ;)
[ Voor 8% gewijzigd door Verwijderd op 14-12-2002 11:45 ]
  • Liam
Liam
Met alle respect hoor, maar zoveel weet ik er zelf ook niet vanaf?
Het lijtk mij dat als je een chmod op die map doet met 777 dat iedereen alles kan in die map, althans als ik het stukje goed heb gelezen?
Wat is er fout aan dan? Het gaat dan toch werken?
De gevolgen zijn dan dus dat iedereen alles kan op je ProFTP map, toch?
Ik wou dus alleen maar een tip geven nadat ik het stukje had gelezen kwam ik tot de conclusie dat het zo zou moeten.
Bedankt i.i.g.
Het is erg onverstandig een FTP server te draaien met een directory waar iedereen alle rechten heeft. En dat is wat je doet met de oplossing van Liam_xi. Dat is vragen om misbruik van je machine en daarom een beveiligingsrisico.
Aangezien de topicstarter al aangegeven heeft dat deze dicht mag doe ik dat maar bij deze.
