[Kernel 2.4.20] Error onder make modules
  • iZi
  • Laatst online: 12-08 14:55
iZi
Leuker kan ik het niet maken..
Ik ben bezig om een nieuwe kernel te compilen.
tijdens het compilen stopt hij met deze error:
cp: cannot stat `arp_tables.o': No such file or directory
cp: cannot stat `arptable_filter.o': No such file or directory
cp: cannot stat `ip_conntrack.o': No such file or directory
cp: cannot stat `ip_conntrack_ftp.o': No such file or directory
cp: cannot stat `ip_conntrack_irc.o': No such file or directory
cp: cannot stat `ip_nat_ftp.o': No such file or directory
cp: cannot stat `ip_nat_irc.o': No such file or directory
cp: cannot stat `ip_nat_snmp_basic.o': No such file or directory
cp: cannot stat `ip_queue.o': No such file or directory
cp: cannot stat `ip_tables.o': No such file or directory
cp: cannot stat `ipt_DSCP.o': No such file or directory
cp: cannot stat `ipt_ECN.o': No such file or directory
cp: cannot stat `ipt_LOG.o': No such file or directory
cp: cannot stat `ipt_MARK.o': No such file or directory
cp: cannot stat `ipt_MASQUERADE.o': No such file or directory
cp: cannot stat `ipt_MIRROR.o': No such file or directory
cp: cannot stat `ipt_REDIRECT.o': No such file or directory
cp: cannot stat `ipt_REJECT.o': No such file or directory
cp: cannot stat `ipt_TCPMSS.o': No such file or directory
cp: cannot stat `ipt_TOS.o': No such file or directory
cp: cannot stat `ipt_ULOG.o': No such file or directory
cp: cannot stat `ipt_ah.o': No such file or directory
cp: cannot stat `ipt_conntrack.o': No such file or directory
cp: cannot stat `ipt_dscp.o': No such file or directory
cp: cannot stat `ipt_ecn.o': No such file or directory
cp: cannot stat `ipt_esp.o': No such file or directory
cp: cannot stat `ipt_helper.o': No such file or directory
cp: cannot stat `ipt_length.o': No such file or directory
cp: cannot stat `ipt_limit.o': No such file or directory
cp: cannot stat `ipt_mac.o': No such file or directory
cp: cannot stat `ipt_mark.o': No such file or directory
cp: cannot stat `ipt_multiport.o': No such file or directory
cp: cannot stat `ipt_owner.o': No such file or directory
cp: cannot stat `ipt_pkttype.o': No such file or directory
cp: cannot stat `ipt_state.o': No such file or directory
cp: cannot stat `ipt_tcpmss.o': No such file or directory
cp: cannot stat `ipt_tos.o': No such file or directory
cp: cannot stat `ipt_ttl.o': No such file or directory
cp: cannot stat `ipt_unclean.o': No such file or directory
cp: cannot stat `iptable_filter.o': No such file or directory
cp: cannot stat `iptable_mangle.o': No such file or directory
cp: cannot stat `iptable_nat.o': No such file or directory
make[2]: *** [_modinst__] Error 1
make[2]: Leaving directory `/usr/src/linux-2.4.20/net/ipv4/netfilter'
make[1]: *** [_modinst_ipv4/netfilter] Error 2
make[1]: Leaving directory `/usr/src/linux-2.4.20/net'
make: *** [_modinst_net] Error 2
Ik heb Redhat 7.3 draaien op een Celeron 400mhz
Kernel 2.4.19 staat al geinstalleerd.
Iemand een idee wat ik hieraan kan doen?
  • mpol
  • Laatst online: 19-01 18:45
mpol
root@localhost
Welke stappen heb je precies gedaan tot aan dit punt?
https://timelord.nl
  • ACM
ACM
Software Architect
Werkt hier
je hebt wel netjes:
make mrproper (niet noodzakelijk, vooral handig als je de kernelsource-dirtree weer schoon wilt hebben)
make [een of andere config, oldconfig, menuconfig, xconfig, config]
make dep
make clean (niet noodzakelijk)
make bzImage
make modules (hier gaat het bij jou mis, neem ik aan?)
make modules_install
enzo gedaan?
  • iZi
iZi
ja ik heb eerst gedownload in /usr/src gegooit en daaruit uitgepakt, toen naar dir linux-2.4.20 gegaan en make menuconfig uitgevoerd en alles aan/uit gevinkt wat moest voor mijn pc. Na menuconfig gesaved te hebben heb ik make dep; make clean; make bzImage; make modules; make modules_install.
hij gaat dus of bij make modules fout of bij make modules_install
  • iZi
iZi
ik heb op verzoek van een vriend iptables als module gezet en niet als mee compileren.
Nu krijg ik deze melding:
make[2]: *** [sched.o] Error 1
make[2]: Leaving directory `/usr/src/linux-2.4.20/kernel'
make[1]: *** [first_rule] Error 2
make[1]: Leaving directory `/usr/src/linux-2.4.20/kernel'
make: *** [_dir_kernel] Error 2
  • ACM
ACM
Software Architect
Werkt hier
doe dan eerst eens make mrproper, dan opnieuw menuconfig en de rest (liefst op losse command regels, zodat je beter kan zien waar het fout ging)
  • G33rt
  • Laatst online: 22-06-2022
tsja deze eroor had ik ook bij kernel recompilen:
cc1: warning: unable to locate [een of andere file]
dat dus... en geen backup van mn vmlinuz, ofwel stukke linux en format gedaan met een nieue install
weet iemand daar een oplossing voor
  • Arzie
  • Laatst online: 13-09 07:44
iZi: heb je wel een /usr/src/linux naar je /usr/src/linux-2.4.20 laten wijzen?
  • iZi
iZi
Het blijkt dus al bij make dep verkeerd te gaan
dan krijg ik deze melding:
make[6]: *** [fastdep] Error 139
make[6]: Leaving directory `/usr/src/linux-2.4.20/drivers/media/radio'
make[5]: *** [_sfdep_radio] Error 2
make[5]: Leaving directory `/usr/src/linux-2.4.20/drivers/media'
make[4]: *** [fastdep] Error 2
make[4]: Leaving directory `/usr/src/linux-2.4.20/drivers/media'
make[3]: *** [_sfdep_media] Error 2
make[3]: Leaving directory `/usr/src/linux-2.4.20/drivers'
make[2]: *** [fastdep] Error 2
make[2]: Leaving directory `/usr/src/linux-2.4.20/drivers'
make[1]: *** [_sfdep_drivers] Error 2
make[1]: Leaving directory `/usr/src/linux-2.4.20'
make: *** [dep-files] Error 2
  • iZi
iZi
Arzie: hoe bedoel je?
ik heb gewoon de tar file uitgepakt in de directory /usr/src/ en daar maakt hij zelf dan een dir aan genaamd linux-2.4.20
iZi schreef op 08 December 2002 @ 18:00:
Leer jezelf aan om "&&" te gebruiken, niet ";". Dan stopt hij als er iets foutgaat, nu gaat ie door met het volgende commando als de vorige foutging, die dan ook weer foutgaat, met als gevolg dat....blablabla etc.
  • _nethack
  • Laatst online: 12-09 11:03
_nethack
We're all MAD here
Of doe gewoon 'make dep && make bzImage modules modules_install' dat heeft het zelfde effect :)
Sometimes you just have to sit back, relax, and let the train wreck itself
  • iZi
iZi
het is mij al gelukt waarschijnlijk verkeerde optie aangevinkt in menuconfig.
En Beelzebubu bedankt voor de tip!
en bedankt allemaal voor het meedenken
  • PowerSp00n
  • Laatst online: 06:11
PowerSp00n
There is no spoon
G33RT schreef op 08 December 2002 @ 19:15:
Werkende kernel overschrijven is dus het stomste wat je kunt doen :O
