Upgraden samsung t100 naar t108 dmv datakabel
  • 140 views sinds 30-01-2008
  • Tinuske
  • Laatst online: 08-02 20:43
Gisteren wat rondgespeurd op het internet over mijn telefoon de samsung t-100
Zo kwam ik terecht op wat sites , met software waar je mee de samsung t100 kon upgraden dmv de bijgeleverde datakabel naar versie t108, hiermee zijn enkele bugs verwijderd , is het menu grafischer geworden , opstartschermen en afsluitschermen zijn veranderd, nieuwe ringtones , ingebouwd antwoorapparaat etc. Heeft iemand dit toevallig hier al gedaan ?
En zo ja, werkt dit goed ?
Alvast bedankt!!
hieronder de FAQ bij de software :
SGH-T108 FAQ:
Where can I download the upgrade software from?
You can download it by clicking on the link below:
http://www.mobile-universe.org/software/t100-t108.rar
I can't extract/deflate the zip file?
You will need the latest version of WinRar (version 3.0)
You can download it on this link: http://www.rarlab.com/
What parameters of the program would I need to set?
Mode Selection=Binary+Ogm
File Selection: Main Flash=T18BJVC8.axf, Second Flash=T18BJVC8.ogm
Setting: Port=COM1 (default), Baud Rate=115200 (default)
Option: Uncheck all checkboxes as other users have experienced problems with this
Just press the start button and your off. Make sure that your phone is connected and is off.
How long does the whole process take?
About 5 to 8 minutes.
I have download the software but now my phone is all in Chinese/Non-english. How can I fix this?
The language is set to Non-english by default. To change the settings back to english, do the following:
1. Press left softkey for menu
2. Press right arrow key 4 times to get to setting
3. Press 1 for phone setting
4. Press 3 for language
5. Press 1 for text language. This is the point where you change your language, 1 for english, 2/3/4... are for other languages
What additional features or enhancements does the T108 have?
From my understanding, the following enhancements/features have been added:
- AnswerPhone: allows your phone to have an inbuilt answering machine where you can record your own messages, interrupt the answering machine and talk to the user if needed to. Unlike voicemail, this does not divert your calls. When the other person leaves a message this gets stored in the phone (limited storage time).
- Animated Menu graphics
- Different Turn On/Off animated pictures
- Selectable delivery reports (Orange users only)
- Fixes bugs relating to setting bookmarks on WAP
- New ringtones (30 built-in, 3 download, 2 user, 12 upload)
Which obvious enhancements were not added?
- Games do not run at a faster frame rate (still the same speed)
- You cannot edit received text messages (still!)
- Number/ABC/Eng/Symbol formatting is still the same access (Have to press the ABC button and press 1 for ABC, 2 for Number, 3 for English, 4 for Symbolic)
What languages are supported in the software?
English and Chinese only. No support for the German or French or any other language as yet.
My WAP doesn't seem to work anymore. How do I fix it?
Press *2767*927#
This will enable/disable WAP.
If this does not fix the problem try the following:
Do a WAP reset *2767*927# as before.
Then put your WAP settings into proxy #5 (or #3 for others - try both)
For WAP settings on 02, click on the following link for more info:
http://www.o2.co.uk/produ...t/setupwap/0,,131,00.html
Will this void my warranty?
Check with your Service Provider regarding this.
Is there a User Manual available for this?
Yes, click on the following link:
http://www.samsungelectro...ds/400043_4486_file3.html
Will the original software that came with the phone that enables wallpaper/ringtone uploads still work?
Yes
Will my other programs previously compatible with the SGH-T100 still work?
This is entirely dependant on the program. PSM Player (latest version) I believe, still works. Not sure about the others though.
I cannot connect to my phone. How do I fix this?
This is a problem that Samsung have addressed regarding connectivity. A patch will be available to fix this problem on the Samsung website. Go to:
http://www.SamsungElectronics.com
I have tried to upgrade but it tells me incorrect file name. What do I do?
Try the following:
1. Uncheck all the checkboxes of the options in the program.
2. You may have problems with your phone connection.
3. Files may be corrupted. Download the files again.
I get the message "Flash Write error". Now my phone won't turn on. What do I do?
Download Samsung Toolbox v4 and follow the details on the pdf file to fix the problem.
The software is available on the this link: http://www.mobile-universe.org/toolbox4.zip
G.Ziakkas (Moderator/Administrator) has written a manual for it. LInk: http://www.mobile-universe.org/ToolBox_V4_Manual.zip
What do the T108 screenshots look like?
There are screenshots taken which can be accessed on this link:
http://www.threegmobile.net/gallery/samsungt100/index2.html
Can I revert back to the original T100 software?
Yes. Here is a link that provides downloads for the different software/firmware for each country/network that the original Samsung T100 is released.
http://www.mobile-univers...bb=get_topic;f=9;t=000152
  • Octopuz908
  • Laatst online: 07:16
Ja ik heb het gedaan maar heb hem weer terug geflashed naar de T100.
Het is na de upgrade allemaal veel beter alleen Nederlands zit er niet in :(
En dat is met name lastig bij de T9
Maar als jou dat niks uitmaakt raad ik het je beslist aan :)
  • T-Blizzard
  • Laatst online: 05-08 15:52
Hmmzzz ziet er wel interresant uit.... Alleen jammer dat die games nie sneller zijn geworden... leuk een fps van 1 :(
  • Octopuz908
T-Blizzard schreef op 08 december 2002 @ 22:33:
Bij de T108+ zijn ze wel sneller!
  • T-Blizzard
Octopuz schreef op 08 December 2002 @ 22:34:
Is dat zo??? zou wel gaaf wezen maar in bovenstaande:
  • Xandrios
  • Laatst online: 05-08 20:24
Dit soort flash-files zijn niet echt legaal.
