Ik kan niet inbellen onder MD9
  • Wolfboy
Wolfboy
ubi dubium ibi libertas
Ik heb een Dynalink Extern 56E V92 modem
In suse heb ik al wel eens geinternet met dit modem maar bij mandrake krijg ik elke keer een fout.
Als ik op connect druk dan gaat ie verbinding maken maar zodra er verbinding is dan krijg ik "ppp deamon died".
Dit is het debug rapport:
Dec  8 00:44:28 Rick pppd[3688]: pppd 2.4.1 started by rick, uid 501
Dec  8 00:44:28 Rick pppd[3688]: using channel 2
Dec  8 00:44:28 Rick pppd[3688]: Using interface ppp0
Dec  8 00:44:28 Rick pppd[3688]: Connect: ppp0 <--> /dev/tts/0
Dec  8 00:44:28 Rick pppd[3688]: sent [LCP ConfReq id=0x1 <asyncmap 0xa0000> <magic 0xbef23f23> <pcomp> <accomp>]
Dec  8 00:44:31 Rick pppd[3688]: sent [LCP ConfReq id=0x1 <asyncmap 0xa0000> <magic 0xbef23f23> <pcomp> <accomp>]
Dec  8 00:44:31 Rick pppd[3688]: rcvd [LCP ConfReq id=0x1 <mru 1524> <asyncmap 0x0> <auth chap MD5> <pcomp> <accomp> <mrru 1524> <endpoint [local:52.54.42]>]
Dec  8 00:44:31 Rick pppd[3688]: sent [LCP ConfRej id=0x1 <mrru 1524>]
Dec  8 00:44:31 Rick pppd[3688]: rcvd [LCP ConfAck id=0x1 <asyncmap 0xa0000> <magic 0xbef23f23> <pcomp> <accomp>]
Dec  8 00:44:31 Rick pppd[3688]: rcvd [LCP ConfReq id=0x2 <mru 1524> <asyncmap 0x0> <auth chap MD5> <pcomp> <accomp> <endpoint [local:52.54.42]>]
Dec  8 00:44:31 Rick pppd[3688]: sent [LCP ConfNak id=0x2 <auth pap>]
Dec  8 00:44:31 Rick pppd[3688]: rcvd [LCP ConfReq id=0x3 <mru 1524> <asyncmap 0x0> <auth pap> <pcomp> <accomp> <endpoint [local:52.54.42]>]
Dec  8 00:44:31 Rick pppd[3688]: sent [LCP ConfAck id=0x3 <mru 1524> <asyncmap 0x0> <auth pap> <pcomp> <accomp> <endpoint [local:52.54.42]>]
Dec  8 00:44:31 Rick pppd[3688]: sent [PAP AuthReq id=0x1 user="Rick.webfreak" password=<hidden>]
Dec  8 00:44:31 Rick pppd[3688]: rcvd [PAP AuthNak id=0x1 "Authentication failure"]
Dec  8 00:44:31 Rick pppd[3688]: Remote message: Authentication failure
Dec  8 00:44:31 Rick pppd[3688]: PAP authentication failed
Dec  8 00:44:31 Rick pppd[3688]: sent [LCP TermReq id=0x2 "Failed to authenticate ourselves to peer"]
Dec  8 00:44:31 Rick pppd[3688]: rcvd [LCP TermAck id=0x2]
Dec  8 00:44:31 Rick pppd[3688]: Connection terminated.
Dec  8 00:44:31 Rick pppd[3688]: Exit.
Blog [Stackoverflow] [LinkedIn]
Het lijkt alsof je aanmeldnaam en/of je wachtwoord niet goed zijn ingevuld.
  • Buffy
  • Laatst online: 13-09 19:41
Buffy
Fire bad, Tree pretty
Heb je niet toevallig "rare" tekens in je password staan.
zo had ik een password met een '#' erin gekozen.
Duurde een aantal dagen voordat ik door had waarom dat een slecht idee is :|
Je kan de show-password optie gebruiken om je password in je log te laten zien (zoals het verzonden wordt).
That which doesn't kill us, makes us stranger - Trevor (AEon FLux)
When a finger points at the moon, the imbecile looks at the finger (Chinese Proverb)
  • Wolfboy
Wolfboy
ik heb inderdaad een # in mijn pass staan.
Maar ik heb het ook geprobeerd met een andere account zonder # en dat deed het ook niet.
Ik probeer het nog even
  • RickDB
  • Laatst online: 18-05 21:17
Je zou er een linmodem in kunnen stoppen ;)
Maar effe serieus mandrake en redhat hebben nou eenmaal minder drivers, suse is namelijk stukken groter(4.8gig).
Zou dus gewoon brakke drivers kunnen zijn die standaard bij mandrake zitten(die de info niet goed vertaald).
Edit: maar de instellingen zullen het wel zijn, zo niet dan lijkt me het toch echt een driver(module) probleem.
[ Voor 131% gewijzigd door RickDB op 08-12-2002 03:51 ]
  • Wolfboy
Wolfboy
als je met een linmodem een modem met linux ondersteuning bedoelt dan heb ik die dus :D
  • Wolfboy
Wolfboy
ik denk eerder dat dit aan de instellingen liggen dan aan meer drivers :/
  • Buffy
Buffy
RickvanHattem schreef op 08 December 2002 @ 03:32:
Bedenk dan wel dat het '#' teken vaak als commentaar teken wordt gebruikt in unix bestanden.
Zo ook in het pap-secret bestand. Als je daar je password inzet zonder een '\' voor het '#' teken dan wordt alleen het gedeelte van je password voor het '#' teken als password opgestuurd.
Wat je dus kan zien als je de optie 'show-password' gebruikt :)
  • epias
Dawns_sister schreef op 08 December 2002 @ 03:51:
Kun je oplossen door bv.
set authkey "secret#"
