[Coldfusion]Probleempje met een loop *
  • 48 views sinds 30-01-2008
Hey hallo...
Het volgende stukje code heb ik al geschreven
<cfset volume_totaal = 0>
<cfset TOTAL=0>
<CFQUERY datasource="#request.datasource#" name="qOrder">
    SELECT  * FROM qGetAllOrder
</CFQUERY>
<CFQUERY datasource="#request.datasource#" name="qOrderCount">
    SELECT  COUNT(*) AS TOTAL
    FROM qGetAllOrder
</CFQUERY>
2 queries, 1 voor resultaten uit de database, 1 voor het max aantal records te tellen.
Vervolgens:
29
30
31
32
33
34
35
36
37
38
39
40
<form action="replenishment_calculate.cfm" method="POST" >
  <table border="1" cellpadding="0" cellspacing="0" style="border-collapse: collapse; border-width: 0" bordercolor="#111111" width="100%" height="61">
<cfloop from=1 to="#qOrderCount.TOTAL#" index="i">
  <cfoutput query="qOrder">
 <tr>
     <td width="12%" height="22" bgcolor="##FFFFFF">
    <font face="Arial" size="1">#qOrder.EAN_code#</font></td>
    <td width="32%" height="22" bgcolor="##FFFFFF">
    <font face="Arial" size="1">#qOrder.description#</font></td>
    <td width="5%" height="22"  bgcolor="##FFFFFF">
    <b><font face="Arial" size="1">#qOrder.pot_size#</b></td>
    <b><font face="Arial" size="1">&#8364; #qOrder.retail#</font></b></td>
    <td width="8%" height="22" bgcolor="##FFFFFF">
    <b><font face="Arial" size="1">#qOrder.lst_wk_sales#</font></b></td>
    <td width="10%" height="22" bgcolor="##FFFFFF">
    <b><font face="Arial" size="1">#qOrder.stock#</font></b></td>
    <b><font face="Arial" size="1">#qOrder.onroad# / #qOrder.onord#</font></b>
    </td>
    <font size="1" face="Arial">
           <input type="text" name="quantity_#i#" value="#evaluate("Form.quantity_"&i)#" size="4">
     </td>
      <td>#qOrder.Volume_plant#</td></tr>
      <cfset volume_per_orderregel = qOrder.Volume_plant * qOrder.quantity>
      <cfset volume_totaal = volume_totaal + volume_per_orderregel>
</cfoutput>
</cfloop>
</table>
<cfoutput>
     <font size="1" face="Arial">Your current volume is:
       <input type="text" name="volumetot" size="18" value="#volume_totaal#">
    #i# </font><br>
         <input type="button value="recalculate" name="submit">
  </cfoutput>
</form>
</body>
</html>
Een stukje code waarin door de resultaten wordt geloopt.
Alleen.....
Als ik deze code uitvoer, zal hij de loop uitvoeren voor elke rij uit de database...
Dus ik krijg 63 dezelfde info per rij...
Iemand enig idee wat ik fout doe?!
thnx in advance!
  • drm
  • Laatst online: 09-06-2025
drm
f0pc0dert
Ja, uitroepteken in je titel. Da's behoorlijk storend, moet ik zeggen.
Music is the pleasure the human mind experiences from counting without being aware that it is counting
~ Gottfried Leibniz
excuses :D
  • jochemd
  • Laatst online: 28-08 15:41
Je probleem zou een stuk leesbaarder zijn als je alle font-meuk en style-shit er uit gooide.
  • mulder
  • Laatst online: 23:57
mulder
ik spuug op het trottoir
Je loopt over qOrder met cfloop, en je gebruikt cfoutput query="qOrder". Dat is dubbel op
oogjes open, snaveltjes dicht
Don Facundo schreef op 05 December 2002 @ 13:27:
Yup, maar als ik de <cfoutput query=qOrder> vervang met <cfoutput>
krijg ik alleen de eerste record uit mn database...
Zit ik nu zo krom te denken dan?
  • jochemd
Verwijderd schreef op 05 December 2002 @ 14:07:
Verwijder de cfloop en vervang verwijzingen naar #i# door verwijzingen naar #currentrow#.
jochemd schreef op 05 december 2002 @ 14:17:
ff proberen!!
jochemd schreef op 05 December 2002 @ 14:17:
De oplossing! ;)
Mijn dank is groot!!
B) :>
  • drm
drm
f0pc0dert
volgende keer editknop, ajb
~ Gottfried Leibniz
drm schreef op 05 December 2002 @ 14:40:
ja hoor...
pfff... slecht geslapen ofzo!?
  • D2k
  • Laatst online: 09-01 11:25
D2k
nee tegen techposts scoren
is beleid
Doet iets met Cloud (MS/IBM)
