VB'ers! Wie heeft er zin om samen een ENORME MUD te maken???
  • 52 views sinds 30-01-2008
Hallo, en welkom!
Ik ben een jonge maar toch best wel ervaren VB coder, en ik was een tijd bezig met MUD's bedenken en maken, etc..
Nu leek het me wel een leuk idee om met alle GoT'ers een hele grote MUD te programmeren, jullie ok?
Als je zou willen helpen, graag! :)
Hier wat voorbeelden in VB:
Een van de modules die ik gebruik in mijn MUD:
Option Explicit
'> Consts
Public Const BodyMaxHP% = 100
'< Consts
'> Characters information variables
Enum StatusEnum
Admin = 3
Immortal = 2
Mortal = 1
End Enum
Type BodyPartVars
Name As String 'Name of the part
Cond As Integer '100 highest, 0 lowest
AC As Integer '100 highest, 0 lowest
WearVnum As Integer 'Vnum of item weared on this body part
End Type
Type DelayVars
Busy As Boolean
Command As String
PCTarget As Integer
MobItemVnum As Integer
End Type
Public Char() As Character
Public Type Character
Name As String 'Character's name
Gender As String
Race As String 'Character's race
Area As Integer 'The ID of the area Char() is in
locX As Integer ' \
locY As Integer ' > Location on the current area (X,Y,Z)
locZ As Integer ' /
HP As Integer 'Blood in body
HPMax As Integer
'> Char body parts
Head As BodyPartVars
Torso As BodyPartVars
Legs As BodyPartVars
PHand As BodyPartVars
SHand As BodyPartVars
'< Char body parts
Items As String 'Items the char has (Inventory)
Wear As String 'All the items one char wears
Damage As Integer 'Damage char does in a hit
ApproachedPCs As String 'PCs that approached the char
ApproachedMobs As String 'Mobs that approached the char
GameState As String 'GameState defines if some commands will work or not
GameSubState As String 'More common changing states
Data As String 'That's each char unique input string
Record As Recordset 'Thevar holds the Record movement table
Bleeding As Integer 'The amount of blood you bleed every delayed.Bleeding
Delay As DelayVars
Status As StatusEnum 'Admin/Immortal/Mortal
TimeOnline As Integer 'Time online (DUH)
Spy As Boolean 'The admin command to spy after player/s
QdText As String 'The text that doesn't fit to one screen of terminal
End Type
Public PlayerList As PlayerLists
Type PlayerLists
Admins As String
Immortals As String
Mortals As String
Spy As String
FreeIndex As String 'Stores the indexes of people that quited
End Type
'< Characters information variables
Function OpenEmoteTags(ByVal Str$, Index%, Arguement$, Optional Targeted%) As String
'\B/------------------------------Open PC related tags------------------------------
If Targeted > 0 Then Str = Replace(Str, "<target>", Char(Targeted).Name): Arguement = Replace(LCase(Arguement), LCase(Char(Targeted).Name), "")
Str = Trim(Replace(Str, "<arg>", Arguement))
If InStr(Str, "<hisher>") Then Str = Replace(Str, "<hisher>", HeShe(Char(Index).Gender, "HisHer"))
OpenEmoteTags = Str & "."
'/E\------------------------------Open PC related tags------------------------------
End Function
Sub GetCharLook(ByVal NameIndex As Integer, ByRef Condition$, ByRef WearedItemsLook$)
'\B/----------------------------------------See wearing equipment----------------------------------------
WearedItemsLook = WearsItems(SortItemsList(Char(NameIndex).Wear), _
Char(NameIndex).PHand.Name, Char(NameIndex).Gender)
'/E\----------------------------------------See wearing equipment----------------------------------------
'\B/--------------------------------------------See condition--------------------------------------------
Dim HisHer$
With Char(NameIndex)
HisHer = HeShe(Char(NameIndex).Gender, "hisher")
If .Head.Cond < BodyMaxHP% Then _
Condition = Condition & HisHer & " head is " & GetCondition(.Head.Cond, .HPMax) & ", "
If .Torso.Cond < BodyMaxHP% Then _
Condition = Condition & HisHer & " torso is " & GetCondition(.Torso.Cond, .HPMax) & ", "
If .PHand.Cond < BodyMaxHP% Then _
Condition = Condition & HisHer & " " & .PHand.Name & " is " & GetCondition(.PHand.Cond, .HPMax) & ", "
If .SHand.Cond < BodyMaxHP% Then _
Condition = Condition & HisHer & " " & .SHand.Name & " is " & GetCondition(.SHand.Cond, .HPMax) & ", "
If .Legs.Cond < BodyMaxHP% Then _
Condition = Condition & HisHer & " legs are " & GetCondition(.Legs.Cond, .HPMax) & ", "
If Condition <> "" Then Condition = Proper(Left(Condition, Len(Condition) - 2)) & "."
End With
'/E\--------------------------------------------See condition--------------------------------------------
End Sub
Sub DoMobHit(ByVal Index%, Mnum%, ByRef HittedBodyPart As BodyPartVars)
Dim Damage%, BleedMaxTemp%
Damage = Char(Index).Damage
If HittedBodyPart.Name = "head" Then If Int(Rnd * 2) + 1 = 2 Then Damage = Damage + 3
If Damage <= HittedBodyPart.AC Then
If HittedBodyPart.WearVnum > 0 Then Send Index, "Your blow falls on " & .Name & "'s " & Item(HittedBodyPart.WearVnum).Name & " but doesn get throu."
If HittedBodyPart.WearVnum = 0 Then Send Index, "Your hit hardly touches " & .Name & " " & HittedBodyPart.Name & "'s skin."
Exit Sub
End If
End Sub
Function HeShe(Gender$, GenderType$) As String
GenderType = LCase(GenderType)
If Gender = "male" Then
Select Case GenderType
Case "heshe"
HeShe = "he"
Case "hisher"
HeShe = "his"
End Select
Else
Case "heshe"
HeShe = "she"
Case "hisher"
HeShe = "her"
End Select
End If
End Function
Function AllUsers() As Variant
AllUsers = AddToString(PlayerList.Mortals, AddToString(PlayerList.Admins, PlayerList.Immortals))
End Function
Function PcIsHere(Index As Integer, Name As String) As Integer
'Returns the index of the found char (PcIsHere>0)
Dim I As Integer
Dim Arr As Variant
PcIsHere = 0
Arr = StringToArray(PCs(Index))
If UBound(Arr) > 0 Then
For I = LBound(Arr) To UBound(Arr)
If Arr(I) <> Index And LCase(Char(Arr(I)).Name) = Name Then PcIsHere = Arr(I): Exit Function
Next I
End If
End Function
'Function that checks if what index of array is equal to LookFor
Function SearchCharName(ArrayName() As Character, LookFor As String) As Integer
Dim Arr$(), I%
SearchCharName = 0
For I = LBound(ArrayName) To UBound(ArrayName)
If ArrayName(I).Name = LookFor Then SearchCharName = I: Exit Function
Next I
End Function
Sub ApproachRemoval(Index As Integer)
With Char(Index)
Dim Arr As Variant, I As Integer
'\B/------------------------If approached PCs then retreating------------------------
If Len(.ApproachedPCs) > 0 Then
Arr = StringToArray(.ApproachedPCs)
Char(Arr(I)).ApproachedPCs = RemoveFromString(Char(Arr(I)).ApproachedPCs, Index)
Next I
.ApproachedPCs = ""
End If
'/E\------------------------If approached PCs then retreating------------------------
'\B/-----------------------If approached mobs then retreating-----------------------
If Len(.ApproachedMobs) > 0 Then
Arr = StringToArray(.ApproachedMobs)
Mob(Arr(I)).ApproachedPCs = _
RemoveFromString(Mob(Arr(I)).ApproachedPCs, Index)
Next I
.ApproachedMobs = ""
End If
'/E\-----------------------If approached mobs then retreating-----------------------
End With
End Sub
Function IsApproached(Index%) As Boolean
With Char(Index)
If Len(.ApproachedPCs) + Len(.ApproachedMobs) > 0 Then _
IsApproached = True Else IsApproached = False
End With
End Function
Function GetBodyPart(NameIndex%, MobItemVnum%) As BodyPartVars
If CheckMPI(NameIndex) Then
'Where the blow falls
Select Case Int(Rnd * 21) + 1
Case 1 To 10
GetBodyPart = .Torso
Case 11 To 13
GetBodyPart = .PHand
Case 14 To 16
GetBodyPart = .SHand
Case 17 To 20
GetBodyPart = .Legs
Case 21
GetBodyPart = .Head
End Select
End With
Exit Function
End If
If CheckMPI(MobItemVnum) Then
With Mob(MobItemVnum)
Case 1 To 10
Case 11 To 13
Case 14 To 16
Case 17 To 20
GetBodyPart = .Legs
Case 21
GetBodyPart = .Head
End Select
End With
Exit Function
End If
End Function
Sub LetBodyPart(NameIndex%, MobItemVnum%, HitPart As BodyPartVars)
Select Case HitPart.Name
Case .Torso.Name
.Torso = HitPart
Case .PHand.Name
.PHand = HitPart
Case .SHand.Name
.SHand = HitPart
Case .Legs.Name
.Legs = HitPart
Case .Head.Name
.Head = HitPart
End Select
End With
Exit Sub
End If
Case .Torso.Name
.Torso = HitPart
Case .PHand.Name
.PHand = HitPart
Case .SHand.Name
.SHand = HitPart
Case .Legs.Name
.Legs = HitPart
Case .Head.Name
.Head = HitPart
End Select
End With
Exit Sub
End If
End Sub
Function ACDefended(Index%, NameIndex%, Damage As Integer, HittedBodyPart As BodyPartVars, _
Optional MissMsgSelf$ = "", Optional MissMsgTarget$ = "", Optional MissMsgOthers$ = "") As Boolean
ACDefended = False
ACDefended = True
Send Index, MissMsgSelf
If NameIndex > 0 Then Send NameIndex, MissMsgTarget
TransmitLocal Index, MissMsgOthers, NameIndex
End If
End Function
Function DoDamage(NameIndex%, Damage%, HittedBodyPart As BodyPartVars) As Integer
Dim BleedMaxTemp As Integer
DoDamage = Damage
HittedBodyPart.Cond = HittedBodyPart.Cond - Damage + HittedBodyPart.AC
.Bleeding = Abs(.Torso.Cond + .Head.Cond _
+ .Legs.Cond + .PHand.Cond + .SHand.Cond - BodyMaxHP% * 5) / (BodyMaxHP% / 5)
If .Bleeding > 0 And frmMain.tmrBleeding(NameIndex).Enabled = False _
Then frmMain.tmrBleeding(NameIndex).Enabled = True
'\B/--------------------------Setting the bleeding interval--------------------------
BleedMaxTemp = Int((BodyMaxHP% * 5 - .Bleeding * 5) / 25)
frmMain.tmrBleeding(NameIndex).Interval = BleedMaxTemp * 1000
'/E\--------------------------Setting the bleeding interval--------------------------
'\B/---------------------------Lowering the overall health---------------------------
.HP = .HP - Damage + HittedBodyPart.AC
'/E\---------------------------Lowering the overall health---------------------------
End With
End Function
Function DoDamageMob(TargetMnum%, Damage%, HittedBodyPart As BodyPartVars) As Integer
DoDamageMob = Damage
With Mob(TargetMnum)
+ .Legs.Cond + .PHand.Cond + .SHand.Cond - .MaxHP * 5) / (.MaxHP / 5)
If .Bleeding > 0 And frmMain.tmrBleedingMob(TargetMnum).Enabled = False _
Then frmMain.tmrBleedingMob(TargetMnum).Enabled = True
BleedMaxTemp = Int((.MaxHP * 5 - Mob(TargetMnum).Bleeding * 5) / 25)
frmMain.tmrBleedingMob(TargetMnum).Interval = BleedMaxTemp * 1000
Mob(TargetMnum).HP = Mob(TargetMnum).HP - Damage + HittedBodyPart.AC
End With
End Function
Sub DelayedAttack(Index%, HittedBodyPart As BodyPartVars, _
Optional MissMsgSelf$ = "", Optional MissMsgOthers$ = "", Optional MissMsgTarget$, _
Optional MsgSelf$ = "", Optional MsgOthers$ = "", Optional MsgTarget$ = "")
Dim NameIndex% 'Holds the found Index of a Name
Dim TargetMnum As Integer 'Holds the found Vnum of the mob
Dim DamageDone As Integer 'The damage that was done
NameIndex = Char(Index).Delay.PCTarget
TargetMnum = Char(Index).Delay.MobItemVnum
If TargetChanged(Index, NameIndex, TargetMnum) Then Exit Sub 'Is the target here?
'\B/-----------------------------------PC to PC hit-------------------------------------
With HittedBodyPart
MissMsgSelf = GlobalOpenTags(MissMsgSelf, Index:=NameIndex)
MissMsgTarget = GlobalOpenTags(MissMsgTarget, Index:=NameIndex)
MissMsgOthers = GlobalOpenTags(MissMsgOthers, Index:=NameIndex)
MsgSelf = GlobalOpenTags(MsgSelf, Index:=NameIndex, BodyPartName:=HittedBodyPart.Name)
MsgTarget = GlobalOpenTags(MsgTarget, Index:=NameIndex, BodyPartName:=HittedBodyPart.Name)
MsgOthers = GlobalOpenTags(MsgOthers, Index:=NameIndex, BodyPartName:=HittedBodyPart.Name)
End With
If ACDefended(Index, NameIndex, Char(Index).Damage, HittedBodyPart, MissMsgSelf, _
MissMsgTarget, MissMsgOthers) Then Exit Sub
DamageDone = DoDamage(NameIndex, Char(Index).Damage, HittedBodyPart)
'\B/-----------------------------------Transmiting-----------------------------------
Send Index, MsgSelf
Send NameIndex, MsgTarget
TransmitLocal Index, MsgOthers, NameIndex
'/E\-----------------------------------Transmiting-----------------------------------
End If
'/E\-----------------------------------PC TO PC hit-------------------------------------
'\B/-----------------------------------PC to MOB hit-------------------------------------
If CheckMPI(TargetMnum) Then
MissMsgSelf = GlobalOpenTags(MissMsgSelf, Mnum:=TargetMnum, BodyPartName:=HittedBodyPart.Name)
MissMsgTarget = GlobalOpenTags(MissMsgTarget, Mnum:=TargetMnum, BodyPartName:=HittedBodyPart.Name)
MissMsgOthers = GlobalOpenTags(MissMsgOthers, Mnum:=TargetMnum, BodyPartName:=HittedBodyPart.Name)
MsgSelf = GlobalOpenTags(MsgSelf, Mnum:=TargetMnum, BodyPartName:=HittedBodyPart.Name)
MsgTarget = GlobalOpenTags(MsgTarget, Mnum:=TargetMnum, BodyPartName:=HittedBodyPart.Name)
MsgOthers = GlobalOpenTags(MsgOthers, Mnum:=TargetMnum, BodyPartName:=HittedBodyPart.Name)
End With
Call DoDamageMob(TargetMnum, Char(Index).Damage, HittedBodyPart)
'\B/-------------------------------------Mob AI-------------------------------------
Call AIGotHitMob(TargetMnum, DamageDone, Index)
'/E\-------------------------------------Mob AI-------------------------------------
Send Index, MsgSelf
End If
'/E\-----------------------------------PC TO MOB hit-------------------------------------
'Updating the body part
With Char(Index).Delay
Call LetBodyPart(.PCTarget, .MobItemVnum, HittedBodyPart)
End With
End Sub
Sub Attack(Index%, Arguement$, NotHere$, Busy$, TooFar$, _
PreparingSelf$, PreparingTarget$, PreparingOthers$, DelayCommand$, Seconds%, _
Optional CheckForApproach As Boolean = True)
Dim NameIndex%, Mnum As Integer
If Arguement = "" Then Send Index, "What?": Exit Sub
NameIndex = PcIsHere(Index, LCase(Arguement))
Mnum = MobIsHere(Index, LCase(Arguement))
'Checking if the char can hit at all
If Not CheckMPI(NameIndex) And Not CheckMPI(Mnum) Then Send Index, NotHere: Exit Sub
'\B/--------------------------------Checking if busy--------------------------------
If .Busy = True Then Send Index, Busy: Exit Sub
End With
'/E\--------------------------------Checking if busy--------------------------------
If CheckMPI(NameIndex) Or CheckMPI(Mnum) Then
PreparingSelf = GlobalOpenTags(PreparingSelf, Index:=NameIndex)
PreparingTarget = GlobalOpenTags(PreparingTarget, Index:=NameIndex)
PreparingOthers = GlobalOpenTags(PreparingOthers, Index:=NameIndex)
End With
If CheckForApproach Then _
If InStr(QteMe(Char(Index).ApproachedPCs), QteMe(NameIndex)) = 0 Then Send Index, TooFar: Exit Sub
Send Index, PreparingSelf
Send NameIndex, PreparingTarget
TransmitLocal Index, PreparingOthers, NameIndex
ElseIf CheckMPI(Mnum) Then
With Mob(Mnum)
PreparingSelf = GlobalOpenTags(PreparingSelf, Mnum:=Mnum)
PreparingOthers = GlobalOpenTags(PreparingOthers, Mnum:=Mnum)
End With
If InStr(QteMe(Char(Index).ApproachedMobs), QteMe(Mnum)) = 0 Then Send Index, TooFar: Exit Sub
End If
Call AddDelay(Index, Seconds:=Seconds, CommandName:=DelayCommand, Mnum:=Mnum, NameIndex:=NameIndex)
End If
End Sub
Iemand zin?
Come join! :*)
-ALD
  • Brent
  • Laatst online: 11:39
double?
Sorry, double post.. :S
  • Okyah
Okyah
wespachterrrrrfilm..
Double topic, more like it :)
Alone at last
Just nostalgia and I
We were sure to have a blast
  • The Will
  • Registratie: Mei 2001
  • Laatst online: 15-10 14:02
/double
There is no magic.
