[MySQL] gethostbyname_r error tijdens make
  • Prutser_IA
  • Laatst online: 03-06-2021
Ik probeer hier op me server Apache/tomcat met mysql en php te installeren, maar ik ga al fout bij de installatie van MySQL.
tijdens de make krijg ik de error:
warning: passing arg 5 of `gethostbyname_r` from te incompatible pointer type
to few arguments to function `gethostbyname_r`
warning: assignment makes pointer from integer without a cast
en daarna klapt hij eruit..
nou heb ik via de search enkele treads gevonden van mensen die hetzelfde probleem hadden.. Maar nergens vondt ik een oplossing.
Mijn systeem:
* Mandrake 9.0
* MySQL 3.23.53
* GCC 3.2
Heeft iemand deze problemen ook en zo ja, hoe hebben jullie dan opgelost??
42
man gethostbyname
mysql.com verteld dit...
Compiler Advisory: Several of our users have reported random crashes and table corruption with MySQL binaries compiled with gcc 2.96 on the x86 Linux platform. Although we were unable to duplicate the problems ourselves or understand their exact cause, we suspect with a great degree of confidence that the problem was compiler related. Replacing the faulty binary with our binary always eliminated the problem.
We recommend that MySQL be compiled with gcc 2.95 if you have to compile your own binary at all. It is also acceptable to compile it with gcc 2.91 - builds with these compilers have been tested extensively. We would suggest, however, that you stay away from gcc 3.0 series until we have had some time to do some more extensive testing.
The best solution in terms of stability and performance for most users is to use our binary instead of compiling their own. Please visit http://www.mysql.com/ to obtain an Official MySQL binary.
To determine if you should be concerned about this compiler issue, execute gcc -v from the command prompt on your system. If the compiler reports version 2.96, then there is a problem (this is the case, for example on RH 7.x series or Mandrake 8.x). In this case, you should not try to compile your own binary before downgrading to one of the compilers mentioned above. You should also NOT use the MySQL server provided with your distribution -- as this copy of MySQL was compiled with the same ill-advised compiler version.
The recommended solution in this case is to uninstall your distribution's MySQL and replace it with the one of the MySQL binaries from http://www.mysql.com/.
[ Voor 99% gewijzigd door Verwijderd op 01-12-2002 22:10 ]
