jedi knight 2
  • 56 views sinds 30-01-2008
ik heb een error bij het proberen starten van de game zelf, het menu systeem werkt maar zodra ik een game laad of ik click new game crasht het.
het vliegt dan naar desktop en displayed alleen nog de engine console met de error erop.
JK2: v1.03 win-x86 May 3 2002
Initialising zone memory .....
----- FS_Startup -----
Current search path:
C:\Program Files\LucasArts\Star Wars JK II Jedi Outcast\GameData\base\assets5.pk3 (4 files)
C:\Program Files\LucasArts\Star Wars JK II Jedi Outcast\GameData\base\assets2.pk3 (289 files)
C:\Program Files\LucasArts\Star Wars JK II Jedi Outcast\GameData\base\assets1.pk3 (8011 files)
C:\Program Files\LucasArts\Star Wars JK II Jedi Outcast\GameData\base\assets0.pk3 (6674 files)
C:\Program Files\LucasArts\Star Wars JK II Jedi Outcast\GameData/base
14978 files in pk3 files
execing default.cfg
execing jk2config.cfg
couldn't exec autoexec.cfg
...detecting CPU, found Intel Pentium IV
------- Input Initialization -------
Skipping check for DirectInput
Joystick is not active.
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
--- Common Initialization Complete ---
Working directory: C:\Program Files\LucasArts\Star Wars JK II Jedi Outcast\GameData
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\SYSTEM\opengl32.dll' ): succeeded
...setting mode 4: 800 600 FS
...using colorsbits of 32
...calling CDS: ok
...registered window class
...created window@0,0 (800x600)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...57 PFDs found
...hardware acceleration found
...PIXELFORMAT 5 selected
...creating GL context: succeeded
...making context current: succeeded
Initializing OpenGL extensions
...GL_S3_s3tc available
...GL_EXT_texture_compression_s3tc available
...no tc preference specified
.....using GL_EXT_texture_compression_s3tc
...using GL_EXT_texture_env_add
...GL_EXT_texture_filter_anisotropic available
...using GL_EXT_texture_filter_anisotropic
...Using GL_EXT_texture_edge_clamp
...using WGL_EXT_swap_control
...using GL_ARB_multitexture
...using GL_EXT_compiled_vertex_array
...using GL_EXT_point_parameters
GL_VENDOR: NVIDIA Corporation
GL_RENDERER: GeForce3/AGP/SSE2
GL_VERSION: 1.3.1
GL_EXTENSIONS: GL_ARB_depth_texture GL_ARB_imaging GL_ARB_multisample GL_ARB_multitexture GL_ARB_shadow GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_transpose_matrix GL_S3_s3tc GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_paletted_texture GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_shared_texture_palette GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_compression_s3tc GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_cube_map GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_vertex_weighting GL_HP_occlusion_test GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square GL_NV_copy_depth_to_color GL_NV_evaluators GL_NV_fence GL_NV_fog_distance GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_texgen_reflection GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_program GL_NV_vertex_program1_1 GL_SGIS_generate_mipmap GL_SGIS_multitexture GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_WIN_swap_hint WGL_EXT_swap_control
GL_MAX_TEXTURE_SIZE: 4096
GL_MAX_ACTIVE_TEXTURES_ARB: 4
PIXELFORMAT: color(32-bits) Z(24-bit) stencil(8-bits)
MODE: 4, 800 x 600 fullscreen hz:N/A
GAMMA: hardware w/ 0 overbright bits
CPU: Intel Pentium IV
rendering primitives: single glDrawElements
texturemode: GL_LINEAR_MIPMAP_LINEAR
picmip: 0
texture bits: 32
lightmap texture bits: 0
multitexture: enabled
compiled vertex arrays: enabled
texenv add: enabled
compressed textures: enabled
compressed lightmaps: disabled
texture compression method: GL_EXT_texture_compression_s3tc
anisotropic filtering: enabled
Initializing Shaders
----- finished R_Init -----
------- sound initialization -------
Initializing DirectSound
locked hardware. ok
----- Sound Info -----
sound system is muted
1 stereo
32768 samples
16 samplebits
1 submission_chunk
22050 speed
0xd5f12000 dma buffer
No background file.
--- ambient sound initialization ---
Sound memory manager started
UI menu load time = 1702 milli seconds
Loading game "jkii03"...
------ Server Initialization ------
Server: kejim_post
RE_Shutdown( 0 )
------- Game Initialization -------
gamename: base
gamedate: May 3 2002
Parsing ext_data/NPCs.cfg
------ ICARUS Initialization ------
ICARUS version : 1.33
Couldn't find image for shader [NoMaterial]
Corrupt JPEG data: premature end of data segment
----- CL_Shutdown -----
RE_Shutdown( 1 )
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL ): success
...deleting GL context: success
...releasing DC: success
...destroying window
...resetting display
...shutting down QGL
...unloading OpenGL DLL
----- Server Shutdown -----
==== ShutdownGame ====
... ICARUS_Shutdown
... Reference Tags Cleared
... Navigation Data Cleared
... Ghoul2 Models Shutdown
Unsupported marker type 0xb6
die unsupported marker type 0xb6 blijft dan flashen als titel van venster.
kent iemand hier iets van en weet wat het probleem is? thx
Geef als eerst wat specs + driverversie.
Down de nieuwste videokaart driver ook even.
  • Hahn
  • Laatst online: 17:09
Zoals in Strenger modbeleid in SPV! staat voldoet jouw startpost niet aan de eisen. Je moet inderdaad je specs geven en ook zelf dingen proberen zoals drivers downloaden :)
The devil is in the details.
zie de post van marc0 :)
en kijk ook eens naar die tekst die je post: 50% is overbodig en zou jezelf best even mogen weghalen :+
