[IE6]Hoe volldig op pc te krijgen zonder internet
  • 52 views sinds 30-01-2008
  • TeH_oNe
  • Laatst online: 15-06-2024
TeH_oNe
YEAH RIGHT
ik heb dus 4 pc's met win98sec edition
daar moet alle 4 Internet explorer 6 op.
maar er zit op geen van 4 internet.
aleen op de 5e ( xp bak )
hoe kan ik de IE6 voor windows 98 volledig downloaden
en vervolgens op cd branden.
what?
  • F_J_K
F_J_K
Moderator CSA/PB/AI
Front verplichte underscores
Dit hoort thuis in Software Algemeen, maar is daar al heel vaak langsgekomen en:
[google=site:microsoft.com download-only internet explorer 6]
[google=network download internet explorer 6 site:microsoft.com]
On the following Internet Explorer download page, click the appropriate language version to download the Ie5setup.exe or Ie6setup.exe file:
http://www.microsoft.com/windows/ie/
Click Save to Disk (or Save), and then save the file in a folder on your computer.
Click Start, and then click Run.
Click Browse, browse to the folder in which you saved the Ie5setup.exe file or Ie6setup.exe file, click to highlight the file, and then click Open.
In the Open box, click at the end of the command, add a space, and then type the following command for Internet Explorer 5 or 6.
NOTE: Double quotation marks around the variable #e are required, because #e designates the source path, including executable, of the Ie5setup.exe or Ie6setup.exe as appropriate.
/c:"ieXwzd.exe /d /s:""#E"
For example, if you saved the IE setup file (Ie5setup.exe or Ie6setup.exe) file in the C:\Windows Update Setup Files folder, the command looks like:
"C:\Windows Update Setup Files\ie5setup.exe" /c:"ie5wzd.exe /d /s:""#E"
The following is an explanation of the command line switches used:
/d - Downloads Internet Explorer for the current platform only. However, if you would like to download all platforms, you can use the /d:1 switch value to get all platforms. There are only two values for this switch, /d and /d:1.
/s:""<#e>"" - Designates the source path of Ie5setup.exe. The ""<#e>"" value refers to the full path and name of the .exe file. Note that two pairs of double quotation marks must surround the path.
Press ENTER. Choose the appropriate items for the operating system.
NOTE: To download Internet Explorer to a network drive, you must map the network drive to a drive letter on your computer. You cannot download Internet Explorer to a Universal Naming Convention (UNC) path.
:Y)
