probleem: geheugen of mobo?
  • Super_Grover
  • Laatst online: 09-09 15:13
Super_Grover
Gaat niet.......bestaat niet!!
Ik ben bezig met een pc te upgraden met dit mobo:
GA-7IXE4
AMD® 750 Chipset
PROCESSOR
Socket A for AMD® -K7 Athlon™ & Duron™ 200MHz FSB processors
90*/95*/100/105*/110*/115* MHz FSB
AUTO detect CPU voltage
CHIPSET
AMD® 751 (Irongate) North Bridge
AMD® 756 (Viper) South Bridge
Winbond W83977 I/O set
Winbond W83782 health chip
MEMORY
16MB to 768MB DRAM size
3 x 3.3V DIMM sockets
Supports 64/128/256 MB SDRAM DIMM module
Supports ECC type DIMM module (72bits)
SLOT
1 x AGP slot supports 2X mode
5 x PCI slots support 33MHz & PCI 2.2 compliant
2 x ISA slots
I/O
2 x Ultra DMA 33/66 Bus Master IDE ports on board
1 x FDD, 2 x COM, 1 x LPT, PS/2 Keyboard, PS/2 Mouse on board
2 x USB ports on board
2 x USB ports by cable (optional accessary)
IrDA TX / RX header
POWER
ATX power connector
Power-on by K/B, PS/2 Mouse, LAN, RTC, modem & switch
Power-off by Windows® 95/98/2000 Shut down & Switch
AC Recovery ON/OFF control
3 level ACPI LED support
FORM FACTOR
ATX , 4 layer PCB (30.5*20.8cm)
H/W MONITORING
3 fan power & speed detection connectors
Case open detection
System health status detect & report by Gigabyte Windows Utility Manager
H/W detect ¡Ó5V, ¡Ó12V, CPU voltage & CMOS battery status
BIOS
2Mbit flash RAM
AMI BIOS with enhanced ACPI feature for PC98/Win98/Win2000 compliance, Green, PnP, DMI, INT13 (>8.4GB) & Anti-Virus functions
IDE#1~#4, SCSI, LS120, ZIP & CD-ROM bootable
Auto-detect & report system health status
OTHER FEATURES
Includes Wake-On-LAN header (WOL)
Includes Wake-On-Ring (WOR)
Poly fuse for keyboard & USB over-current protection
DRIVER
AMD® AGP miniport driver
AMD® bus master IDE driver, supports UDMA 33/66
Mijn buurjongen heeft geheugen gehaald en volgens de winkel zou het moeten werken, maar wat ik ook probeer, het werkt niet! alle combinaties met het oude geheugen (128 md sdram) in verschillende banken werkt niet!
Het nieuwe geheugen is van: JetRam 256 mb sdram 133 Mhz
Op het stickertje staat: 256M PC133 CL3 SDRAM
Dit reepje geheugen alleen in de pc werkt niet, geen piepjes, geen beeld op monitor, helemaal niets! In combinatie met het bestaande geheugen start de pc wel normaal op maar wel met 128mb geheugen ipv 128+256.
Waar zit nu het probleem: Is het gewoon slecht geheugen, ligt het aan de snelheid van het geheugen??
  • Pazzi
  • Laatst online: 21:53
Pazzi
Koffiemokken en bierglazen
Ben er bijna zeker van dat je geheugen kapot is. Heb je de mogelijkheid om het reepje te proberen in een andere computer? Als ie het daarin ook niet doet, kun je er zeker van zijn dat het geheugen kapot is.
"When the shit hits the fan, make sure you don't get splattered" - Carol Thompson
"It's the story, not he who tells it" - Stephen King
"If you hate freedom, get married" - Vusumuzi Gumede
"Women can fake orgasms, men can fake love" - Bo Burnham
  • Super_Grover
Super_Grover
Is het niet mogelijk dat het iets te maken heeft met instellingen als cas 2;3, of de fsb??
Op dat eerste reepje, dus dat wat er al inzit staat 16*64 en is 128mb groot
  • WhistlerNL
  • Laatst online: 05-09 21:53
als je dat wilt proberen al denk ik niet dat het daar wat mee te maken heeft. moet je ff je computer opstarten en dan in de bios alles op standaard/zo traag mogelijk instellen. Alles bedoel ik dan alles wat met je geheugen te maken heeft. De rest heeft geen zin :)
Maar verder zou ik ook denken dat je mem kapot is
  • BalusC
BalusC
Carpe diem
Hoeveel chips zitten er op het reepje?
Check Technische PMG FAQ hoeveel/welk geheugen je mobo maximaal aankan..
  • Super_Grover
Super_Grover
BalusC schreef op 30 November 2002 @ 19:47:
Er zit de volgende chipset op:
CHIPSET
Het geheugen wat er al in zit heeft 16*8 = 8 chips
het nieuwe geheugen heeft ook 8 chips en is 256 mb groot
het mobo kan het volgende geheugen aan:
MEMORY
En of dit nu wel of niet werkt is mij eigenlijk onduidelijk :?
  • BalusC
BalusC
Carpe diem
Technische PMG FAQ : Geheugen >> hieruit volgt dat jouw nieuwe reepje een 256Mbit exemplaar is, terwijl de AMD750 maximaal 128Mbit aankan. Je zou dus een 256MB reepje met 16 chips ipv 8 chips moeten hebben :)
[ Voor 13% gewijzigd door BalusC op 01-12-2002 12:41 ]
