Thunderbird stabiliteits probs opgelost
  • Stephan Oudmaijer
  • Laatst online: 16-08-2023
M`n systeem was vet instabiel dus had ik hardware monitor van Via geinstalled en zag ik dat me cpu boven 60 graden kwam als ik bootte...
daarna ff dit gelezen en et is gefixed:
Why is my CPU running so hot?
If your CPU temperature is over 70 degrees C you have a cooling problem.
By far the most common cause of this is the improper removal of the protective square over the pre-applied thermal paste. Removing the "tab" at the base of the processor doesn't always remove the blue square to which it is attached. This blue square must be removed otherwise the Orb will not cool your processor. You should be left with a small, thin layer of pink "chewing gum".
Many people report better performance if this "chewing gum".is removed with solvent (e.g. oil-free nail varnish remover) and standard thermal compound or Artic Silver applied instead.
