TwwT Proxy Probleem 2
  • 146 views sinds 30-01-2008
Krijg de volgende foutmelding:
[Apr 20 05:22:55 UTC] 0 RC5 packets (0 work units) remain in buff-in.rc5
[Apr 20 05:22:55 UTC] 100 RC5 packets (121 work units) are in buff-out.rc5
.....10%.....20%.....30%.....40%.....50%.....60%.....70%.....80%.....90%....100
[Apr 20 05:26:58 UTC] Completed RC5 packet 9FA15AEA :90000000 (1*2^28 keys)
0.00:04:02.23 - [1,108,147.62 keys/sec]
[Apr 20 05:26:59 UTC] Connected to 212.187.63.14:80
via HTTP proxy 192.168.1.12:3128
[Apr 20 05:26:59 UTC] NetUpdate::Unable to assert handshake integrity.
[Apr 20 05:27:00 UTC] NetUpdate::Unable to assert handshake integrity.
[Apr 20 05:27:00 UTC] Loaded RC5 random 1*2^28 packet 9FB6170B :D0000000
[Apr 20 05:27:00 UTC] Summary: 168 RC5 packets (274*2^28 keys)
0.16:37:22.75 - [1.22 Mkeys/s]
[Apr 20 05:27:00 UTC] 0 RC5 packets (0 work units) remain in buff-in.rc5
[Apr 20 05:27:00 UTC] 101 RC5 packets (122 work units) are in buff-out.rc5
[Apr 20 05:28:38 UTC] Connected to 212.187.63.14:80
[Apr 20 05:28:38 UTC] NetUpdate::Unable to assert handshake integrity.
[Apr 20 05:28:39 UTC] NetUpdate::Unable to assert handshake integrity.
Wat is er aan de hand!
  • StarLite
  • Laatst online: 12-10 16:21
StarLite
'ON ERROR RESUME NEXT
Proxy is bij mij ook down :(((
tyrips, tywreps, tiewreps, tiereps, tie raps, ripties, taiwraps, kabelbindbandjes » Tie Wraps
\o/
  • Floor-is
  • Laatst online: 20:17
Floor-is
5.2
Ehm ook nog random packets... Dat is niet OK!
Ik heb een ander probleempje:
Completed RC5 packet 9DE97A15:30000000 (32*2^28 keys) 0.01:42:18.80 - [1,399,473.68 keys/sec]
Kijk die Mkeys/s is wel OK, maar de grootte van het eerste packet is niet dezelfde als de 2e en derde etc, kijk maar:
Loaded RC5 1*2^28 packet 9DE972FC:F0000000
Summary: 22 RC5 packets (132*2^28 keys) etc.
Daar moet ik nog even aan werken, eerst zo maar even de nieuwe client downloaden en installeren, misschien llopt die ook wel sneller op de P3, je weet maar nooit...
Plezier
Bericht hierboven
  • redwing
  • Laatst online: 13:47
Dat de packets verschillende groottes hebben is normaal. Bij het fetchen vraag je in principe aan distributed een bepaalde grootte van packets, als deze er niet genoeg zijn komen er ook kleinere tussendoor.
[removed]
  • [eNeRGy]
  • Laatst online: 24-04-2025
Als je problemen hebt met een proxy, dan pak je toch gewoon een andere ?
Er zijn er genoeg.. zie http://dpc.tweakers.net
Greetinx [eNeRGy]
ps. en loop TWWT nou niet heel de tijd af te katten, wees blij dat ie de moeite neemt !
(edited 20-04-2000).]
Same shit...
[Apr 20 09:15:06 UTC] Automatic processor detection found 1 processor.
[Apr 20 09:15:11 UTC] NetUpdate::Connect handshake failed. (0.168)
[Apr 20 09:15:11 UTC] Automatic processor type detection found
an Intel Pentium III processor.
[Apr 20 09:15:11 UTC] RC5: using core #2 (RG class 6).
[Apr 20 09:15:11 UTC] Loaded RC5 random 1*2^28 packet 9EB9BAD7:50000000
[Apr 20 09:15:11 UTC] 0 RC5 packets (0 work units) remain in buff-in.rc5
[Apr 20 09:15:11 UTC] 18 RC5 packets (39 work units) are in buff-out.rc5
[Apr 20 09:15:11 UTC] 1 cruncher has been started.
[Apr 20 09:15:21 UTC] NetUpdate::Connect handshake failed. (0.168)
.....10%.
[Apr 20 09:15:48 UTC] NetUpdate::Connect handshake failed. (0.168)
.....10%...
[Apr 20 09:15:58 UTC] NetUpdate::Connect handshake failed. (0.168)
[Apr 20 09:19:16 UTC] Completed RC5 packet 9EB9BAD7:50000000 (1*2^28 keys)
0.00:04:04.51 - [1,097,810.24 keys/sec]
[Apr 20 09:19:21 UTC] NetUpdate::Connect handshake failed. (0.168)
[Apr 20 09:19:22 UTC] Loaded RC5 random 1*2^28 packet 9ECB3772:50000000
[Apr 20 09:19:22 UTC] Summary: 1 RC5 packet (1*2^28 keys)
0.00:04:04.51 - [1.09 Mkeys/s]
[Apr 20 09:19:22 UTC] 0 RC5 packets (0 work units) remain in buff-in.rc5
[Apr 20 09:19:22 UTC] 19 RC5 packets (40 work units) are in buff-out.rc5
Hier gaat alles goed...volgens de logs issi ook niet down geweest.
  • StarLite
StarLite
[Apr 20 15:13:42 UTC] The perproxy says: "RC5 proxy, Dutch Power Cows! MOOH }:O"
\o/
  • StarLite
StarLite
http://212.187.63.14:81/rc5/e4/index.html :
Last Updated GMT:
18 Apr 2000 22:22
Dat zegt toch genoeg he¿
Bijna 2 dagen niet ge-update...
\o/
dat zijn de stats...niet de proxy...
vanwege een vage tijdzone update dat niet goed
Het was niet de bedoeling om TwwT af te kraken hoor [eNeRGy]!!!!
Stats zijn weer normaal zie ik! Beter :)
