Asus A7V8X - RAID Controller vraagje
  • 34 views sinds 30-01-2008
  • WhiteDog
  • Laatst online: 22:09
WhiteDog
met zwarte hond
Wil graag dit bordje kopen, maar vroeg me af of ik de RAID controller ook kan gebruiken om gewoon 2 extra hd's aan te hangen zonder raid?
Hier de specs van het bord:
http://www.asus.com.tw/mb/socketa/a7v8x/specification.htm
RAID (optional)
RAID 0 support by two to three Parallel ATA or Serial ATA connectors. RAID 1 support by two Parallel or Serial ATA connectors.
Volgens deze review is het een PDC 20376 controller:
http://www.lostcircuits.com/motherboard/asus_a7v8x/5.shtml
"The Promise PDC 20376 controller drives the single PATA connector where P stands for parallel as well as two serial connectors. The parallel (standard) ATA connector is angled at 90 degrees which makes it very easy to run off the cable off the mainboard without being anywhere in the way. The two SATA150 connectors show their typical staggered pin configuration for future hot-plugging of HDDs."
kan maar 1 paralelle hdd aan.
