zit vast in sof2, level: the bunker
  • 44 views sinds 30-01-2008
Ik zit dus vast bij zo'n kerel die je niet op een normale manier neer kunt knallen.
Het is bij allemaal stellages waar dozen in staan en die kerel zit daar achter van dat gaas. Weet iemand hoe ik die kerel kan doden?
  • Hahn
  • Laatst online: 24-10 17:09
Zo ver ben ik helaas nog niet met SoF2, maar met deze Walkthrough moet het wel lukken :)
Je drukt op CTRL + F en dan typ je 'the bunker' in en je komt vanzelf bij het gedeelte waar je nu dus vast zit.
Blijkbaar werkt die link niet overal dus quote ik het stukje wel :)
Vergara's Mansion: Bunker:
Go down the stairs and through the doorway. To your left behind the
box's is some health and armor, to your right is the way you want to
go. Head through the next room and into the open doorway. Head to
your right and proceed forwards. The guy taunts you some more and then
flees, go through the doorway, head to the left and kill the sniper
around the next turn. Head back past the last doorway and around the
hallway to the left. A big explosion greets you so wait for the dust
to clear and then head through the doorway on the left. Kill the guard
and open the door to the left, then head right through the next room.
Go across the hallway, and clear out the next room. The exit is on the
right side of the far wall. Clear out the next hallway and then head
through the door to the right (It's right next to the one you entered
the hallway through) Your obj will be updated when you get near the
door with a scanner. Keep going past it until you loop around and see
a pipe by a puddle of water on the ground. Follow the pipe. Now comes
the part a LOT of people have problems with. Recommended to save
before this guy. Basically, there is a ton of shelves in the way, and
a fence, and a mounted machine gun protects him. The easiest way I've
found to kill him is this. RUN straight through the room past the
pillar and hide (crouch) against the concrete wall (usually will get
hit by 1 bullet when doing this. Now keep your back against the wall
and look between the out struck wall and the shelf. You will see a
half brick half-concrete wall. Pull out your nades and throw them so
it hits the top of the bricks and bounces towards the bad guy. You
will need to throw 2 nades and then he will be fried by the power box
in the corner. Basically any way to damage the power box until it
overloads is the way to kill him. Now go to where he died, get the red
key card and head back to that locked door with the scanner. Don't
forget to get the armor and health. Now you get to watch another cool
cut-scene... what's with people killing themselves in these games?
[ Voor 80% gewijzigd door Hahn op 23-11-2002 13:21 ]
The devil is in the details.
  • M@NIC
  • Laatst online: 23-09 09:24
Zie MaRc0, volgende keer eerst zelf een walktrough zoeken.
Als de link niet werk, plak 'm dan in je adres balk.
Dicht :)
