Ut werk nog steeds niet.
  • eppie
(overleden)
Het lukt me nog steeds niet om ut aan de gang te krijgen onder Debian sarge
de ini (gedeelte)
29
30
31
32
33
34
35
36
37
38
39
40
[URL]
Protocol=unreal
ProtocolDescription=Unreal Protocol
Name=Player
Map=Index.unr
LocalMap=CityIntro.unr
Host=
Portal=
MapExt=unr
SaveExt=usa
Port=7777
Class=Botpack.TMale1
[FirstRun]
FirstRun=436
[PackageRemap]
UnrealShare=UnrealI
[Engine.Engine]
GameRenderDevice=OpenGLDrv.OpemGLRenderDevice
WindowedRenderDevice=OpemGLDrv.OpemGLRenderDevice
AudioDevice=ALAudio.ALAudioSubsystem
NetworkDevice=IpDrv.TcpNetDriver
DemoRecordingDevice=Engine.DemoRecDriver
Console=UTMenu.UTConsole
Language=int
GameEngine=Engine.GameEngine
EditorEngine=Editor.EditorEngine
DefaultGame=Botpack.DeathMatchPlus
DefaultServerGame=Botpack.DeathMatchPlus
ViewportManager=SDLDrv.SDLClient
Render=Render.Render
Input=Engine.Input
Canvas=Engine.Canvas
[Core.System]
PurgeCacheDays=30
SavePath=..\Save
De log
Log: Log file open, Wed Nov 20 15:33:55 2002
Init: Name subsystem initialized
Init: Version: 436
Init: Compiled: Oct 30 2000 11:53:24
Init: Command line: -log
Init: Base directory:
Init: Character set: ANSI
Log: Bound to Core.so
Log: Bound to Engine.so
Init: Object subsystem initialized
Init: CPU Speed=505.923292 MHz
Init: Unreal engine initialized
Log: Bound to SDLDrv.so
Init: Joystick [0] : Unknown Joystick
Init: SDLClient initialized.
Log: Bound to Render.so
Init: Lighting subsystem initialized
Init: Rendering initialized
Log: LoadMap: Entry
Log: Bound to Fire.so
Log: Case-insensitive search: Botpack -> ..\System\BotPack.u
Exit: Exiting.
Uninitialized: Name subsystem shut down
Uninitialized: Allocation checking disabled
Uninitialized: Log file closed, Wed Nov 20 15:33:57 2002
Het is UT GOTY 436 en er waren geen nieuwe updates. Ook he ik de OpenGL en SDLGL drivers gebruikt allebij geven het zelfde.
Uitvoer
Bound to SDLDrv.so
appError called:
Couldn't initialize SDL: No available video device
Executing UObject::StaticShutdownAfterError
Executing USDLClient::ShutdownAfterError
Signal: SIGIOT [iot trap]
Aborting.
Exiting.
p500:~/.loki/ut/System# cat log
Bound to SDLDrv.so
Bound to Render.so
LoadMap: Entry
Bound to Fire.so
Signal: SIGSEGV [segmentation fault]
Aborting.
Exiting.
Alvast bedankt
  • Zwerver
wat staat er in je map directory in de UT map? eindigen die op .gz ? want dan zijn de maps niet uitgepakt met de install.... daar moet wel ergens een fix voor zijn... moet je even zoeken hier op GoT
Woonachtig Down Under. Ik negeer je insults niet, maar tegen de tijd dat ik ze lees zijn ze meestal niet relevant meer
  • Zwerver
goed omdat ik zelf niet de lulligste ben:
#!/bin/sh
# FILENAME: convert.sh
# Change this to YOUR install-dir of UT
INSTALLDIR=/usr/local/games/ut
cd $INSTALLDIR/System
for i in ../Maps/*.unr.uz
do
  ucc decompress $i -nohomedir
done
mv *.unr ../Maps
cd ../Maps
for f in *.unr
do
  rm $f.uz
done
echo "..:: Done! ::.."
dit deflates de unr.gz mapjes... maak wel ff een backuppertje... mocht dit niet het probleem zijn:
lees deze faq ff:
http://icculus.org/lgfaq/
suc6
  • eppie
(overleden)
Dat is niet het probleem omdat ik die al heb opgelost, en ook de faq heb ik gelezen en kwam er nog niet uit :)
  • wzzrd
  • Laatst online: 24-05 21:44
wzzrd
The guy with the Red Hat
zwerver, ik weet ook het antwoord niet, maar om nou met die maps aan te komen :? :?
Hij krijgt een segfault. Een héél ander probleem dan dat die maps niet zijn uitgepakt. Heel andere foutmelding dus ook. Misschien even googlen op unreal tournament linux segfault / segmentation fault. You get the idea. Kan je verder niet helpen, sorry en succes verder!
  • Zwerver
wzzrd, ik kreeg de segfault eerst ook, in combi met de entry.uz foutmelding, vandaar. Ik kan me eigenlijk niet herinneren dat ik toen iets anders gedaan heb dat dat.... of het moet zijn dat ik mijn nvidia-drivers ge-update heb :S
  • wzzrd
wzzrd
Conar, het gaat om Unreal Tournament, niet om UT2K3.
  • eppie
(overleden)
Bedankt voor de reply's ik zal wel is de nieuwste nvidia drivers proberen, jullie horen het wel :)
wzzrd schreef op 20 November 2002 @ 17:11:
Woeps ik ook in de haast |:( |:(
Staat ulimit af? Redelijk belangrijk want een UT server heeft veel resources nodig bij het opstarten.
  • NaliXL
  • Laatst online: 30-07 19:19
Ik zie daar staan :
Oftewel : je moet waarschijnlijk ergens een base-directory opgeven, aangezien 'ie niet lijkt te weten waar 'ie staat.
Genoeg is meer dan veel, en tart den overvloed
  • wzzrd
wzzrd
Mensen, dat ding segfault! Dat zou wel met een limit te maken kunnen hebben denk ik, maar niet met een verkeerde base-dir...
Definitie segfault: An error in which a running program attempts to access memory not allocated to it and core dumps with a segmentation violation error. This is often caused by improper usage of pointers in the source code, dereferencing a null pointer, or (in C) inadvertently using a non-pointer variable as a pointer.
Of een geheugen allocatie die mislukt, of een foute config file value waar de applicatie niet op berekend is...
Ik installeerde gewoon UT en kon direct spelen, zonder configuratie whatsoever... Probeer dat eerst eens, misschien werkt dat wel?
Hoe dikwijls ga ik het nog moeten herhalen? CHECK ULIMIT !!!
