Het grote ABIT IT7-MAX2 v2.0 topic
  • Ainnir
Post hier je ervaringen met dit mooie bordje!
Ik heb m al besteld en hij komt hopelijk morgen aan :D
Het bord:
Afbeeldingslocatie: http://202.168.194.118/abit/upload/products/it7max2-large.jpg
Afbeeldingslocatie: http://img.hexus.net/MAX2v2/Back.jpg
De specs:
Processors
* Supports all Socket 478 CPUs (400FSB & 533FSB)
Chipset
* North bridge: Intel I845PE MCH
* South bridge: Intel ICH4
System Memory
* 3 x 184-pin DDR SDRAM
* DDR200 / DDR266 / DDR333 support @ 2.5v
* 2GB maximum system RAM
Slots
* AGP slot, 4x AGP compliant (1.5v support only)
* 4 x 32-bit PCI 33MHz slots
On-board peripherals - I/O
* 1 floppy port supports 2 FDD
* 3 Audio Jacks for Realtek ALC650 sound chipset
* RJ-45 LAN Port (Realtek 8100BL)
* 6 USB2.0 connectors
* 2 IEEE 1394a Firewire ports
* S/PIDF-OutA
* Headers for another 4 USB2.0 ports as well as a 3rd Firewire portdio
* PS/2 ports
On-board IDE
* An IDE controller on the ICH4 chipset provides IDE HDD/CD-ROM with PIO, Bus Master and Ultra DMA/100/66/ operation modes
* Highpoint HPT374 - 2 independent channel RAID controller
* Ultra DMA/ATA133, 100, 66, 33 operation modes
* RAID 0, 1, 0+1 support
* Can connect up to 4 IDE devices
* Hot swap capability
* Marvell Serial ATA 2-channel interface capable of 1.5Gbps
Integrated Components
* Realtek RTL8100BL 10/100 Base-T Fast Ethernet Controller
* Realtek ALC650 6-channel sound
* Texas Instruments Firewire chip.
BIOS & Voltages
* ABIT Softmenu III
* FSB speeds of 100Mhz - 250Mhz (quad-pumped)
* 1.1v - 1.70v Vcore adjustable in 0.025v increments (1.725v for C1 CPUs)
* 2.5v - 2.8v Vmem adjustable in 0.1v increments
* 3/1, 4/1 FSB:PCI dividers. Fix PCI options at 33MHz, 37MHz and 44MHz
Other features
* Custom backplane
* 2 digit debug LCD
* On / off power buttons on motherboard
* 5 fan headers
* Serial ATA to ATA converter, dubbed Serillel.
Form Factor
* 305mm x 245mm
Reviews:
* Hexus.net
Waar te koop?:
* Alternate
  • DJT
  • Laatst online: 09-09 21:03
DJT
Ik ben tegenwoordig ook trotse eigenaar van dit stukje hardware! :D
Nu heb ik één probleem: In MSN en spelletjes (Yuri en Generals) hapert het beeld soms, er gebeurd gewoon ff twee sec. helemaal niets. In spelletjes is het vooral tijdens het scrollen.
Even de verdere specs:
P4 2,4 @ 2,7
512MB PC3500 CAS2
2x WD800JB in Raid (performance)
Radeon 9700Pro
Audiotrak Maya44 geluidskaart
DMA staat (automatisch) aan, dat is het dus niet.
Zelf denk ik dat het iets met de Raid-config te maken heeft, maar hier kan ik vrijwel niets aan veranderen.
[ Voor 5% gewijzigd door DJT op 11-02-2003 15:54 ]
  • sharkzor
  • Laatst online: 05-09 12:36
DJT schreef op 11 February 2003 @ 15:54:
P4 2,4 @ 2,7
512MB PC3500 CAS2
Radeon 9700Pro
probleem komt me bekend voor. ik heb dat soort geintjes vroeger ook gehad.
probeer een bios update en dan de drivers van de abit site en niet van highpoint-tech.com (of juist wel? ).
