gigabyte bus speed switchen
  • 49 views sinds 30-01-2008
als ik mijn bus speed wil swichten van 100 naar 133 dan start mijn computer wel op maar pakt ie de video kaart niet. heb een geforce2 mx400 en bij tnt2 m64 deed ie hetzelfde. kunnen de videokaarten het niet aan? of ligt het aan wat anders? kan er niets over vinden in de manual.
hier wat specificaties van het moederbord:
GA-7DX+
AMD-761™ AGPset
PROCESSOR
Socket A for AMD Athlon™/AMD Athlon™ XP/Duron™ 200/266MHz FSB processors
Supports 500MHz ~ 2000+ and faster
Auto/1.5V/1.525V/1.55V...1.85V(15 scales / 0.025V per scale) CPU Voltage adjustable
Supports CPU multiplier 5.0/5.5/.../12.5
CHIPSET
AMD 761™ north bridge and VIA 686B south bridge
AC97 codec
MEMORY
Supports up to 3GB DDR SDRAM (2GB unbrffered memory)
2.5V/2.7V/2.9V DDR memory voltage adjustable
3 DIMMs of 184-pin DDR sockets
Supports either PC1600/DDR200 or PC2100/DDR266 DDR memory
Supports 72bits ECC type DRAM integrity mode
SLOT
1 x AGP 4X
1.5V/1.6V/1.8V AGP Pro voltage adjustable
5 x PCI slots support 33MHz and PCI 2.2 compliant
1 x AMR (Audio Modem Riser) slot
I/O
2 x UDMA ATA 66/100 bus master IDE ports on board
1 x FDD, 2 x COM, 1 x LPT, PS/2 Keyboard, PS/2 Mouse on board
1 x joystick, 1 x line-in, 1 x line-out and 1 x MIC on board
2 x USB 1.1 ports on board, 2 x USB 1.1 ports by cable
IrDA TX / RX header
POWER
ATX power connector
Power-on by LAN, RTC, Modem and Switch
Power-off by Windows® 95/98/Me/2000/XP/NT shut down and Switch
FORM FACTOR
ATX form factor, 4 layers PCB (30.5 x 24.4 cm)
H/W MONITORING
4 cooling fan connectors
System health status detect and report by BIOS
H/W detect and report Power-in voltage, CPU voltage and CMOS battery status
BIOS
Dual AWARD BIOS, 2 x 2M bit flash ROM, enhanced ACPI feature for PC98/Win98/Win2000/WinMe compliance, Green, PnP, DMI, INT13 (>8.4GB) and Anti-Virus functions
IDE#1~#4, SCSI, LS120, ZIP and CD-ROM bootable
AC recovery ON/OFF control
Auto-detect and report system health status
Supports DualBIOS™ and @BIOS™
OTHER FEATURES
Suspend-To-RAM (STR); Supports Wake-On-LAN (WOL)
Supports Internal / External Modem Ring On
Supports USB KB Wake up from S3
Provides 4 fan power connectors
Poly fuse for keyboard over-current protection
Supports EasyTune III™ and Q-Flash
DRIVER
AMD service pack utility
AC97 driver
The specifiction and pictures are subject to change without notice.
All trademarks and logos are the properties of their respective holders.
  • LopeZ
  • Laatst online: 08:54
LopeZ
Too much is never enough
Basic vraag, of je geheugen kan geen 133mhz aan of je moet je agp devider goed zetten (2/3)
