[Debian] dist-upgrade
Ik wil een dist-upgrade doen van me systeem echter dist-upgrade wil emacs installeren en ik niet... hoe kan ik dit uit me dist-upgrade krijgen dat hij dit NIET installeerd???
Emacs is nog niet geinstalleerd en wil ik niet geinstalleerd hebben ook.
echter ik vind al wel diverse emacs bestanden...
zie hieronder output van apt-get en van locate emacs...
laptop:/# apt-get -u dist-upgrade
Reading Package Lists... Done
Building Dependency Tree... Done
Calculating Upgrade... Done
The following NEW packages will be installed:
  aptitude coreutils dselect emacs20 emacsen-common libdb4.0 libsigc++0
  libxaw7 xfree86-common xlibs
The following packages will be upgraded
  base-config base-passwd bash bin86 bind9-host binutils bison bsdmainutils
  cvs debianutils dhcp-client dnsutils dpkg e2fsprogs exim file fileutils flex
  gettext-el groff-base gzip iptables less libdb2 libdb3 libdns5 libfreetype6
  libgcc1 libisc4 libldap2 libltdl3 libltdl3-dev liblwres1 libpam-modules
  libpam0g libpng2 libwrap0 lilo logrotate mailx make man-db mutt nano
  nfs-common pppoe psmisc screen shellutils ssh tcpd telnet textutils vacation
  whois zlib1g
56 packages upgraded, 10 newly installed, 0 to remove and 0  not upgraded.
Need to get 29.4MB of archives. After unpacking 41.8MB will be used.
laptop:/# locate emacs
/etc/emacs
/etc/emacs/site-start.d
/etc/emacs/site-start.d/50cxref.el
/etc/emacs/site-start.d/50gettext.el
/usr/lib/emacsen-common
/usr/lib/emacsen-common/packages
/usr/lib/emacsen-common/packages/install
/usr/lib/emacsen-common/packages/install/cxref
/usr/lib/emacsen-common/packages/install/gettext-el
/usr/lib/emacsen-common/packages/remove
/usr/lib/emacsen-common/packages/remove/cxref
/usr/lib/emacsen-common/packages/remove/gettext-el
/usr/share/emacs
/usr/share/emacs/site-lisp
/usr/share/emacs/site-lisp/cxref
/usr/share/emacs/site-lisp/cxref/cflow.el
/usr/share/emacs/site-lisp/cxref/cxref.el
/usr/share/emacs/site-lisp/gettext
/usr/share/emacs/site-lisp/gettext/po-mode.el
/usr/share/keymaps/atari/atari-de-emacs.kmap.gz
/usr/share/keymaps/i386/qwerty/emacs.kmap.gz
/usr/share/keymaps/i386/qwerty/emacs2.kmap.gz
  • Hagar
  • Laatst online: 14-10-2025
Hagar
Diabootic
Moet je de dependencies van emacs ff opzoeken en kijken door welke package emacs wordt geinstalleerd.
apt-cache show emacs-common
Nu ook zonder stropdas
  • active2
  • Laatst online: 13-09 21:19
active2
Google is your friend
Kijk eens wat je van emacs op je systeem geinstalleerd hebt staan en verwijder dat!
Dat kun je doen met:
dpkg -l | grep ii | grep emacs
En om het te verwijderen doe je dit:
apt-get remove --purge emacs
En anders installeer je emacs en verwijder je het erna.
Google, Het mirakel van de 21e eeuw!!!!
Active2:
laptop:/# dpkg -l | grep ii | grep emacs
laptop:/#
Zo te zien wordt de packages emacs-common / emacs20 niet door andere packages gebruikt...
laptop:/# apt-cache show emacs-common
W: Unable to locate package emacs-common
laptop:/#
laptop:/# apt-cache show emacs20
Package: emacs20
Priority: optional
Section: editors
Installed-Size: 27892
Maintainer: Rob Browning <rlb@defaultvalue.org>
Architecture: i386
Version: 20.7-13.1
Provides: emacsen, info-browser, mail-reader, news-reader, www-browser
Depends: emacsen-common (>= 1.4.10), dpkg (>= 1.9.0), libc6 (>= 2.2.4-4), liblockfile1 (>= 1.0), libncurses5 (>= 5.2.20020112a-1), libxaw7 (>> 4.1.0), xlibs (>> 4.1.0)
Suggests: emacs20-el
Conflicts: emacs20-el (<< 20.7-13), w3-el
Filename: pool/main/e/emacs20/emacs20_20.7-13.1_i386.deb
MD5sum: 6368868bb46d18d6e8f84b085c0ded4b
Description: The GNU Emacs editor.
 GNU Emacs is the extensible self-documenting text editor.
Task: unix-server
laptop:/#
  • 0siris
  • Laatst online: 13-09 19:02
en wat laat gewoon "dpkg -l | grep emacs" zien?
ach...in een volgend leven lach je er om!
0siris:
laptop:/# dpkg -l | grep emacs
laptop:/#
  • deadinspace
  • Laatst online: 20-09 13:27
deadinspace
The what goes where now?
"apt-cache showpkg emacs" is misschien ook handig, die laat de reverse dependancies zien.
Een andere mogelijkheid is om de upgrade dmv dselect te doen, daarmee kun je de dependancies van grote hoeveelheden packages beter controleren. Als je in dselect emacs deselecteert dan zal dselect zeggen welke packages dat niet gaaf vinden.
de boosdoener was gettext-el....
inprincipe foutje van Debian :) gettext-el zat naar mijn weten of vanaf de cd af op mijn systeem of na een dist-upgrade... raar dat toen emacs niet ook erop gezet is...
  • deadinspace
deadinspace
In Potato dependde gettext-el nog niet op emacsen (hij recommendde het wel, maar recommends kun je negeren), dus als je vanaf Potato ge-distupgrade hebt dan kan het wel kloppen dat emacsen nu pas problemen gaf.
