DVD LG5183..kan video cd?
hey.
heb net een Lg dvd5183 (strand-alone dvd speler) binnengekregen en op de doos staat niet dat het videocd(vcd) ondersteunt en als ik een videocd erin doet geeft hij een error.
maar kan ik iets met dtt ding doen waardoor ik het wel kan afspelen?
thanx
Dit kan wel ik wel een mooie hack voor jou.
wat bedoel je precies?
Letop ik heb het onderstaande ook toegepast en het werkt echt.
Follow these instructions very carefully.
Power on the player with no disk in the drive
Press "PAUSE" on the remote
Enter "1472" on the remote (the characters 01 47 should appear on the display)
[If your player is a non UK model, this number will probably be different - don't worry]
Press the UP arrow three times (the characters 04 Fd should appear on the display)
[This number may be different depending on the configuration of your specific model - don't worry]
Press "PROGRAM", "6", "PROGRAM", "5" (the characters 04 FE should now be displayed)
Press "ENTER" (the display should flash briefly)
Press "RETURN"
Power the player off and then back on
Play a VCD!
If you are having trouble getting the hack to work, try pressing "STOP" on the remote before you press "PAUSE" for the first time.
The above hack will also enable the 5.1 Speaker Setup menu which is of no use on players which do not have an in-built Dolby Digital decoder (e.g. DVD-3000E and DVD-4730). Therefore on these players perform the above procedure but exchange steps 4 and 5 for:
Press the UP arrow three times (the characters 04 9C should appear on the display)
Press "PROGRAM", "4", "PROGRAM", "5" (the characters 04 dE should now be displayed)
Will it now play SVCDs, XVCDs, XSVCDs, or mini-DVDs?
No and it is unlikely that it ever will. It is indicated in the Service Manual that the specification of one of the decoder chips only supports VCD (thanks chuck).
kun je me ff toevoegen op msn? phellah17@hotmail.com
thanx
  • ajhaverkamp
  • Laatst online: 13-10 13:12
ajhaverkamp
gewoon Arjan
Voor meer info, bv regiocodefix
http://www.area450.co.uk/lg5083hack.htm
This footer is intentionally left blank
thanx zal dat ff proberen
heb namenlijk gedaan wat chuck zei...en nog steeds geen vcd maar als ik nu een dvd erin doe zijn alle kleuren groen LOL hoop dat het een grapje was van hem wat ik makkenlijk kan oplossen
ok het is gelukt, thanx allemaal
Dat zei ik toch
  • Novah
  • Laatst online: 26-09 12:29
Kan hij nu ook SVCD spelen? VCD sux, maar SVCD is wel interesant, ik zag die dvdspeler ook staan en als je met die trick dan SVCD kan afspelen is het een goede aankoop. :)
Ja svcd's no problemo!
