windows 2000 opstartfiles eruit knikkeren
  • 38 views sinds 30-01-2008
Bij xp kan ik start--- uitvoeren---- msconfig en dan kan ik dus kiezen welke programma`s ik kan kan laten opstarten wat is dat in windows2000???
bvd
  • sdomburg
  • Laatst online: 03-09-2024
General Information -
Windows 2000 does not have the MSCONFIG program that was provided with Windows 98.
1) You can try using the older Windows 98 version of MSCONFIG.
Copy the file msconfig.exe from the c:\windows\system folder to the Windows 2000 c:\winnt\system32 folder.
Download the msconfig.exe Windows 98 file from our site if you do not have it easily accessible.
Click | Start | Run | and type msconfig on the text box and click the OK button to start MSCONFIG
ignore the error messages you get about not finding the following files
config.sys
autoexec.bat
win.ini
system.ini
Click the startup tab
Check or Uncheck the check boxes of the programs you want to run or not run
2) The web site 'thetechguide.com' also has a download link for the XP version of MSCONFIG which they say will work with win2000. We also have it available via email.
Simpele Google search :)
  • blackd
9000Wp o/w SolarEdge SE6K - Panasonic 5kW bi-bloc - gasloos sinds 17-7-2023
