[redhat 8 en bind 9] domein niet te pingen....
  • DPLuS
Ik ben een domein op aan het zetten op mijn pc, nl: easyspace.bogus
Ik wil dus ook dat ping een ip resolved als ik easyspace.bogus ping.
Maar #ping easyspace.bogus zegt:
[root@dplus named]# ping easyspace.bogus
ping: unknown host easyspace.bogus
Terwijl alle andere A-adressen in mijn zone-file wel werken:
[root@dplus named]# ping -c 1 www.easyspace.bogus
PING www.easyspace.bogus (62.111.22.83) from 62.111.22.83 : 56(84) bytes of data.
64 bytes from www.easyspace.bogus (62.111.22.83): icmp_seq=1 ttl=64 time=0.058 ms
--- www.easyspace.bogus ping statistics ---
1 packets transmitted, 1 received, 0% loss, time 0ms
rtt min/avg/max/mdev = 0.058/0.058/0.058/0.000 ms
[root@dplus named]# ping -c 1 ns2.easyspace.bogus
PING ns2.easyspace.bogus (192.168.0.1) from 192.168.0.1 : 56(84) bytes of data.
64 bytes from ns2.easyspace.bogus (192.168.0.1): icmp_seq=1 ttl=64 time=0.050 ms
--- ns2.easyspace.bogus ping statistics ---
rtt min/avg/max/mdev = 0.050/0.050/0.050/0.000 ms
Dit is mijn /etc/named.conf:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
[root@dplus named]# cat /etc/named.conf
// generated by named-bootconf.pl
options {
        directory "/var/named";
         * If there is a firewall between you and nameservers you want
         * to talk to, you might need to uncomment the query-source
         * directive below.  Previous versions of BIND always asked
         * questions using port 53, but BIND 8.1 uses an unprivileged
         * port by default.
        // query-source address * port 53;
// a caching only nameserver config
controls {
        inet 127.0.0.1 allow { localhost; } keys { rndckey; };
zone "." IN {
        type hint;
        file "named.ca";
zone "localhost" IN {
        type master;
        file "localhost.zone";
        allow-update { none; };
zone "0.0.127.in-addr.arpa" IN {
        type master;
        file "named.local";
zone "easyspace.bogus" IN {
        type master;
        file "easyspace.bogus";
zone "0.168.192.in-addr.arpa" IN {
        type master;
        file "192.168.0";
zone "22.111.62.in-addr.arpa" IN {
        type master;
        file "62.111.22";
include "/etc/rndc.key";
Dit zijn de zone-files:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
[root@dplus named]# cat 192.168.0
$TTL    86400
@       IN      SOA     easyspace.bogus. root.easyspace.bogus.  (
                                      1          ; Serial
                                      28800      ; Refresh
                                      14400      ; Retry
                                      3600000    ; Expire
                                      86400 )    ; Minimum
        IN      NS      ns1.easyspace.bogus.
        IN      NS      ns2.easyspace.bogus.
1       IN      PTR     ns2.easyspace.bogus.
[root@dplus named]# cat 62.111.22
$TTL    86400
                                      1          ; Serial
                                      28800      ; Refresh
                                      14400      ; Retry
                                      3600000    ; Expire
                                      86400 )    ; Minimum
83      IN      PTR     ns1.easyspace.bogus.
83      IN      PTR     easyspace.bogus.
83      IN      PTR     www.easyspace.bogus.
[root@dplus named]# cat easyspace.bogus
$TTL    86400
                        1               ; serial (d. adams)
                        3H              ; refresh
                        15M             ; retry
                        1W              ; expiry
                        1D )            ; minimum
                NS      ns1.easypace.bogus.
                MX      10 easyspace.bogus.
localhost       A       127.0.0.1
easyspace.bogus A       62.111.22.83
ns1             A       62.111.22.83
ns2             A       192.168.0.1
www             A       62.111.22.83
[root@dplus named]# cat localhost.zone
$TTL    86400
$ORIGIN localhost.
@                       1D IN SOA       @ root (
                                        42              ; serial (d. adams)
                                        3H              ; refresh
                                        15M             ; retry
                                        1W              ; expiry
                                        1D )            ; minimum
                        1D IN NS        @
                        1D IN A         127.0.0.1
[root@dplus named]# cat named.local
$TTL    86400
                                      1          ; Serial
                                      28800      ; Refresh
                                      14400      ; Retry
                                      3600000    ; Expire
                                      86400 )    ; Minimum
1       IN      PTR     localhost.
Wat doe ik fout?
  • rvm
rvm
Je hebt dit staan in de zonefile easyspace.bogus:
www             A       62.111.22.83
Moet zijn (punt achter bogus):
easyspace.bogus. A       62.111.22.83
www              A       62.111.22.83
Of misschien wel beter:
@               A       62.111.22.83
www             CNAME   easyspace.bogus.
  • DPLuS
Inderdaad :)
Ik heb helemaal over die punt heen gekeken!
Ik had al vantevoren dat "@" moeten gebruiken.
Nu werkt 'ie prima!
Dankjewel...
