Fout in de Round functie
Round(2.5) levert bij mij 2 op. Round(2.51) levert wel netjes 3 op.
Ziet iemand hier de logica van?
Die maakt een INT van een FLOAT
Gevonden met GoogleThe native VB6 Round is problematic:
VB6 Round rounds 1/2 to nearest the even number (aka 'Banker's rounding')
Round(1.5) => 2
Round(2.5) => 2 !! should be 3 in 'Other people's rounding'
VB6 Round does *not* support numDecimalPlaces to be negative, eg:
Round(123.45, -1) => 120 !! run-time error 5 in VB6
Digitaal onderwijsmateriaal, leermateriaal voor hbo
* gorgi_19 blijft copy pasten..
29
30
31
| ... some people think "Banker's rounding" is bad,
but it is not the case. This "Banker's" method uses the Gauss
rule that if you are in an perfect half case, you must round to the
nereast digit that can be divided by 2 (0,2,4,6,8). This rule is
important to obtain more accurate results with rounded numbers after
operation.
Now, an example :
2 digits 2 digits
Unrounded "Standard" rounding "Gaussian" rounding
54.1754 54.18 54.18
343.2050 343.21 343.20
+106.2038 +106.20 +106.20
503.5842 503.59 503.58
Which one is nearer from unrounded result ? The "Gaussian" one
(Difference of 0.0042 with "Gaussian/Banker" and 0.0058
with "Standard" rounding.)
Another example with half-round cases only:
1 digit 1 digit
Unrounded "Standard" Rounding "Gaussian rounding"
27.25 27.3 27.2
27.45 27.5 27.4
+ 27.55 + 27.6 + 27.6
82.25 82.4 82.2
Again, the "Gaussian" rounding result is nearer from the unrounded
result than the "Standard" one. |
Doet iets met Cloud (MS/IBM)
VB6 != VBscript; weet niet of ze hier een andere functie voor hebben geschreven...Kermit schreef op 13 November 2002 @ 10:54:
Dat is stom, check ff m'n zojuist gemaakt ASP pagina:
ASP pagina
Kermit schreef op 13 november 2002 @ 10:54:
ASP pagina
Het is allebei ROUND...D2k schreef op 13 November 2002 @ 10:55:
zet even de acties erbij
het ene is VB round? en het andere?
| <% afrond1 = Round(1.5) afrond2 = Round(2.5) Response.write("1<B>.</B>5 wordt: " & afrond1 & "<BR>") Response.write("2<B>.</B>5 wordt: " & afrond2 & "<P>") afrond3 = Round(1,5) afrond4 = Round(2,5) Response.write("1<B>,</B>5 wordt: " & afrond3 & "<BR>") Response.write("2<B>,</B>5 wordt: " & afrond4 & "<P>") %> |
Exact expert nodig?
Zeg nooit nooit: 2.5 kan toevallig wél exact opgeslagen worden, als: (1 + (1/2) ^ 2) * (2 ^ 1). Dit geldt voor alle getallen die (binnen het redelijke) met een eindig aantal machten van 2 genoteerd kunnen worden. De exponenten daarvan moeten wel een beetje dicht bij elkaar liggen, though.Verwijderd schreef op 13 november 2002 @ 20:43:
je moet ook niet vergeten dat floats nooit precies opgeslagen zijn, door de interne binaire representatie ervan
SA007 schreef op 13 november 2002 @ 22:03:
In plaats van de Round functie kun je ook doen
<code>
Int(Getal +0.5)
</code>
Dat doet het wel goed
